ATMega328P doesn't work with SSD1306 OLED display
10 posts / 0 new
Hello
I'm having trouble getting an SSD1306 OLED 128x64 display to work with an ATMega1284P. I've tried everything I can think of but the display remains blank. The display works fine when used with the Arduino Uno R3; I can upload and run a "blink" sketch on the ATMega1284P; I've tested all the wires with a DVM for integrity; I've checked and rechecked the wiring.
I'm using a Windows 8 machine. I've had problems using the Uno to upload sketches to the ATMega1284P, so I've been using a USBtiny instead. I use the "Maniacbug Mighty 1284p 16 MHz using Optiboot" board in the Arduino IDE to build the hex file. I then flash the sketch on to the ATMega1284P with the USBtiny by running the following command from a command shell:
avrdude -c usbtiny -p atmega1284p -U flash:w:HelloWorld.ino.hex
The command appears to execute without a problem, but the display remains blank. I'm using the U8g2 library; the full code of the sketch is shown below.
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 22, /* data=*/ 23, /* reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display
void setup(void) {
    u8g2.begin();
void loop(void) {
    u8g2.firstPage();
    do {
        u8g2.setFont(u8g2_font_ncenB14_tr);
        u8g2.drawStr(0,24,"Hello World!");
    } while ( u8g2.nextPage() );
I suspect that I'm incorrectly specifying the SCL and SDA pins in the constructor (pins 22 and 23 respectively) but don't know what else to try.
I'd appreciate any help in moving forward with this. Thank you.
Alan
Searching the first I found a pinout map, SCL = D16, SDA = D17
from this:
worth a try!
Click Link: Get Free Stock: Retire early!
The OP has deliberately chosen a software I2C constructor.    It should work on any GPIO pins.     The I2C bus must have real external pullup resistors e.g. 4k7
The hardware constructor would use the hardware SDA, SCL pins.
Oliver has written the library in C.   With a C++ wrapper for the benefit of Arduino.    I would guess his driver(s) are 100% good.    If you have a problem "olikraus" is active on the Arduino.cc Displays Forum.
That worked. Thanks very much, Jim.
Alan
Mark the solution - see Tip #5
Regardless of whether it uses hw or sw I2c, the constructor probably needs Arduino “PIN numbers”, and not chip PIN numbers.
I marked it as solution yesterday. The button now reads 'unmark solution'. Is there something else I need to do?
Alan
Nope, everyone else reading this sees:
So it is quite obvious that #2 is the chosen solution.
PS forgot to say that possibly even more important is that back in the forum list there is this:
The green tick there says "don't beat yourself up trying to answer this as there's already an acceptable solution contained within".
EDIT2: Oh yeah, and this....
Yes, I now see it as marked.
"The button now reads 'unmark solution'. Is there something else I need to do?"
I suppose you are free to change your mind and , if you realize it was a wrong solution, you are allowed to unmark it .
But, from what I read and understood, seems unlikely.... (but nice to be able to change one's mind)
