Solved: Problems with USART (Only sends €)
12 posts / 0 new
Good afternoon everybody.
I've recently tried to program an ATmega16 to do serial communication with my computer using a very simple code of serial communication (just send and receive data). Sadly, when I check how the circuit works it only sends one data, €, which in ASCII is an 1's byte, which crearly shouldn't happen since it isn't a data I am programming to send in any situation. I don't know if it has something to do with the UDR register or if the programmer (USBASP) or the USB to TTL Bridge malfunctions. Any help would be of great appreciation.  My .c file from my AVR Studio project is attached below.
Total votes: 2
Not sure if the mega16 has a div8 fuse but it sounds like your clock is not correct for your baud rate. Not in front of the datasheet so maybe another freak could confirm the div8 fuse existence
Thank you. I didn't find the DIV8 fuse but checked the default clock of the uC and was at 1MHz and after changing it it begun to work correctly.
Atmega16 has four internal oscillators
1, 2, 4, 8 MHz
If you did not change fuses, the chip runs at 1 MHz and you have to write F_CPU = 1000000.
Edit:
For test use a printable character, for example
    send('A');
    _delay_ms(1000);
Visovian wrote:
For test use a printable character, for example while(1) { send('A');
Send 'U'.  Then, at 8-n-1 you get a square wave output, 50% duty cycle, that can be observed (and bit width measured) with a 'scope, or read with a frequency meter.
Hmmm-- I guess we can infer from the attachment that it is GCC.  And then the #define cannot have the =
He may have been talking about AS7. In the project section where you make defines you would enter F_CPU=12345 or whatever and this would then be passed as a -DF_CPU=12345 which has the same effect as a #define without the =.
IF OP does not use Xal, but internal oscillator, -s-he will get some issues (frequency drifts leading to baud rate unstable)  if temperature/MCU/luck changes....
It seems we did not help him at all.
He marked the thread "solved" and did not care to tell us more.
Please read post # 3 again.... carefully.
(Only sends €)
I was hoping to replicate the "problem" and change it so that it would send me AU$ but Euros are OK. cheeky
Well, he edited the title.
For the proper way to mark the solution, see Tip #5 ...
Sorry, I have overlooked #3.
