Reflowing a previously soldered board
90 posts / 0 new
In a week or two I'm going to bring up a new board I've designed based on an ATMega32A.  It has a 5V regulator fed from an external 12V supply, 16 MOSFETS, an RS485 driver, and some connectors.  It's all surface mount.  This is a large board for me, and with my previous, smaller boards, I'd hand-solder a piece (like the regulator), test, then hand-solder some more.  Once I'd validated the board, I'd make more by reflowing them in a toaster oven.  With this one, it would be nice to not have to hand-solder all those MOSFETs, so I was wondering what would happen if I reflowed them after hand-soldering other parts?  Would the hand-soldered parts come unsoldered and, if so, would it matter?  They're just going to be sitting there on their pads and the solder would solidify again once the board cooled.  I could also reflow the MOSFETS first, but I'd prefer not to do that since I may encounter a problem somewhere else on the board before I need those parts.  Thanks for any thoughts.
Post a schematic & we can look for trouble now...if none spotted,, just solder em all at once.
The solder should hold things in place, even with a reflow.
On my boards, after hand soldering, I hand re-flow using hot-air, the result looks like a board house built unit!
Good luck.
Jim:  Hadn't thought about using hot air.  I can do that, I guess, though I prefer using it for removal, since you don't care about the temperature in that case.  For reflowing, you don't know what you're subjecting the part to.  Even if it works when you finish, you'd only see a problem in reduced lifespan, so that wouldn't show up for an unpredictable period.  At least in my oven (which uses a reflow controller), I have some semblance of a proper reflow profile.
avrcandies:  Thanks for the offer.  Always appreciate feedback.  I've attached the two pages of the schematic, plus the PCB.  Be brutal.  ;-)
The 1k pull down resistor are a bit strong.
That is 16 * 5 = 80mA if all the MOSfet's are on.
And the only use for them is to hold the gate down during reset of the AVR.
They can easily be 100k or 1M.
Add some big pads to the voltage regulator (especially when using the 1k resistors).
Replace the 7805 with a small SMPS circuit. 12V -> 5V is quite a voltage drop, waste of energy.
This also more than halves the supply current to your circuit, which helps a lot if you use long cables (As I do with power over CAT-5).
A buck convertor has an inductor between input and ouput. This helps a lot in keeping conducted EMI through the power supply wires far away from your ATMEGA.
I would also add a Polyfuse in the 12V power supply. They are cheap and wonderfull.
How much current do your MOS fets switch? To they also need a thermal pad?
The GND trace to all the MOSfets is quite thin.
Ah: note of 2.7A...
It looks like that the GND trace to your MOSfet's has a lot of via holes drilled in it, which also make it thinner locally.
I would like to see a big fat continuous GND plane at least around the uC and the power supply section.
For the high current traces I would not trust a single via.
You need some way of making sure that the RS485 levels are within spec.
RS485 only has a common mode voltage level between -7 and +12V.
Normally this is done by adding a third GND wire (possibly with a power resistor in series.
I have used standard CAT-5 +RJ-45 for RS485 an dused 2 wires for distribution of 24Vdc.
Small SMPS on each AVR board, and you can power a lot of boards from a single power supply.
Putting Poly fuses in series with A & B make your RS485 robust against hard DC voltages (such as wrong 24V connection).
I would also not use RS485 any more witout added Transzorbs or at least very rugged RS485 drivers.
Pin 2 & 3 are both permanenty connected to Vcc. You can not switch between sending and receiving this way.
KiCad user here, unfamiliar with Eagle.
Why do some component numbers have a "$" in the middle, but your resistors and capacitors don't ???
I do not see a buffer capacitor on the board. Use something between 10uF and 100uF.
Oops, now I see it (10 minutes later).
For drawing schematics: they are a lot easier to read (especially for others, but also for yourself) if you keep to some conventions, as much as possible:
- Voltages from top to bottom.
- Signal flow from left to right.
- Schematic symbol pins grouped in logical order, not by physical pin location (You can always do a text search to find pin AF46 of a big BGA on page 23 of a big schematic).
For example:
Power input connector, then buffer cap, voltage regulator, decoupling caps Vcc & GND labels all neatly in a row (with the GND trace on the bottom.
Look at your GND trace wrapped all around your ATMEGA. GND pins should be on the bottom of your ATMEGA symbol.
All those "$" in components and even in symol pin names makes it hard to read.
Which of pin 2 or pin 3 is the enable for the driver and which is for the receiver in your RS485 chip?
Put the polarity of your diode on the silk screen.
C5 C9 C10 U$24 should all be physically close together, connected through a fat GND plane.
Your pcb design looks like you have just let an autorouter rip through it without giving it further thought.
Some people here think I am feeling "superior" and want to "show of" or "get a kick out of" pointing out other peoples mistakes.
I see it as having some experience and trying to help others to build better stuff.
It's up to you whether you want to implement any or all of the suggestions I mentioned.
By soldering iron or hot air pencil can have a repeatable and controlled profile such that parts aren't damaged.
Why :
The Science of Component Heat Damage
How Overheating Damages I.C.s
http://web.archive.org/web/20121016080444/http://www.emsciences.com/HTML/Heat.html
soldering iron training :
http://www.emsciences.com/training.html
hot air :
BGA Rework Station, BGA Hot Air System, BGA Alignment, BGA, Protoyping, SMD, Hot Air Station
Zephyrtronics®
Two Critical Benchtop Processes
by David Jacks
http://www.zeph.com/pap1.html
(pre-heat, cool down)
Ah yes, I forgot:
Original question was about the soldering.
Hot air is not uncommon, and the closed loop feedback from your eyes & brain from when the solder melts is a quite good indication of temperature.
Pre-heating the PCB helps.
Also the direction in which you blow the heat.
If there are parts you do not want to heat too much you can cover them with aluminimum foil and a few pieces of kapton tape.
A lot (most?) reliability problems are not from the peak temperature, but from a too fast heating profile.
The idea is that a lot of plastic's absorb a bit of moisture.
I have received orders from mouser in sealed plastic bags with a dessicant and a moisture indicator inside.
If the indicator is discolored you have to bake the components for SEVERAL HOURS at temperatures of around 120 to 150 Celcius to let all the moisture evaporate out of the plastic.
(Do not trust my numbers, do some research yourself). Different baking procedures are recommended for different components.
The regural black epoxy seems to be fairly moisture proof.
It is often clear components such as leds that are affected more by this.
(Also sensitive stuff, such as IC's for measurment equipment, very low offset opamps / inamps etc).
Don’t worry Paul, your observations are on the money. I would not consider that pcb viable. It looks like its been done by an autorouter.
If you consider the pcb as a means of interconnect, then everything is connected, but the pcb is actually a vital part of the circuit. Consider if you draw some considerable current through the gnd tracks. What voltage drops can you expect? Would they affect other parts of the circuit? Most likely.
Also consider the power disipation of the regulator - the 485 transceiver can draw over 100mA, so what will this do to your regulator?
Wow, Paul!  Thanks so much for your detailed reply.  It feels like a master class in circuit design and PCB layout, both of which I could certainly benefit from.  I don't feel you're showing off at all, but, rather, sharing your experience, which is precisely what I asked for, and what a lot of people seek from online forums.  Unfortunately, some here only offer *destructive* criticism, not *constructive*.
Comments and questions below.
First, to add some context, the application is a piece of kinetic sculpture consisting of 1024 12VDC relays arranged in a square array of 64 panels, each containing 16 relays in a 4 x 4 array (something like in the attachment, though there are only about 600 in that render).  Each panel will contain (on the back) a 12VDC power supply (converting 110 - 220 VAC) and the board we're discussing here.  The relays are supplied with 12VDC from the power supply, and low-side driven via the MOSFETs (to which they're connected via the two RJ45 connectors).  Each relay only draws 170 mA, and will be on for no more than 1 sec. at a time.  The piece will be controlled by a master controller communicating with the panels via an RS485 bus at 300 kbps.
Good point.  Changing.
> Add some big pads to the voltage regulator.
I expanded the pad already with a filled area, plua another one underneath it on the other side of the board.  That's what all those thermal vias are for.  How bigh should it be (see next)?
That was my original plan, but 95% of the time the RS485 trasceiver (MAX3061E) will be inactive, making the MCU the main power consumer, drawing, worst case, 20 mA.  The RS485 trasceiver will be active the rest of the time, bringing total power consumption up to, maybe 70 mA.  The only time the circuit will draw more than that is if the RS485 bus shorts out, at which point the transceiver will max out at 250 mA.  That may never happen, but, of course, I have to plan for it anyway.  Unfortunately, all the SMPS circuits I looked at (admittedly not an exhaustive search) are very inefficient at the low end of their output power range.  So, it seemed to me that an SMPS would add cost and complexity for little or no gain in efficiency compared to a linear regulator (500 mA rated in this case) the vast majority of the time.  Does that make sense?
The power supply will be within six inches of everything it's powering.
What rating would you suggest?
As I said above, 170 mA.  It's not scientific, but I can hold one on a breakout board in my hand for the one second max. on time and it doesn't get warm.
I was concerned about this, too.  I checked with a couple of online trace width calculators (e.g. http://www.4pcb.com/trace-width-...) and got the same number:  170 mA through 1 ounce copper yields a trace wdith of 1 mil.  I was going to bounce this off a forum, but forgot and ended up going off of the calculated numbers.  So, to be "safe" (and to stay within the PCB house's design rules), I used 8 mils for drain and source, 27 mils (21 calculated) for each of the two ground busses running to all the MOSFETs, and 56 mils (47 calculated) for the ground bus feeding these two back to the 12V input and regulator.
True, but how else should traces connect to it?
I could extend the thermal pad that's already under the regulator, as that's connected to ground.  It would be hard to do for the MCU, though, given all the routing going on within its footprint.  At least I'm notusing any analog functions.
Please explain.
The MAX3061E claims to be reliable as-is (https://www.maximintegrated.com/...).
This is my first RS485 application, but I haven't seen anything about this.  There has been mention of using shielded twisted pair cabling with the shield grounded at one (and only one) end.
I thought about using a single supply for the whole piece, as I'm not wild about running AC to all the panels (even if using proper cords and sockets), but that would require a 174A, 2.1KW supply (without derating for margin); a $700+ single point of failure.  Another advantage of my approach is that I can split the AC into two circuits, allowing each to be supplied by a separate 15A AC circuit (there's no way to power it off even a single 20A circuit).  Of course, I could use multiple, smaller 12V supplies, and put half on one AC circuit and the others on another one, though I'd still run the risk of losing a large chunk of the piece if one of the supplies failed.  ALso, the piece is going to be 8' wide by 9' - 10' tall, so the voltage drop in the cables becomes a consideration, given their length and current.
I'll have to look into that.
Ditto.
I'm aware.  These are all only being used as receivers. I'd originally thought I might want to go both ways, changed my mind, but didn't change the part.
Eagle does that automatically.  It's been a while since I've read that section of the manual (and I'm using a very old version of Eagle), but I *think* it uses the $ sign for complex dvices that might have multiple gates (e.g. a 7400); then the $ helps designate different gates within the device.  It doesn't know an MCU doesn't work like that.  Some of my connectors have a $ in their names because I screwed up when I created the part.  I've gone back to fix it, but the fix doesn't propagate to the schematic and board when I force an update, for some reason.
At least I did this right.  It's the white line to the right of the left pad.
I thought the bulk capacitor (C5) could be anywhere on the board.  I guess not.
Sad to say, no.  This is my doing as the autorouter in Eagle (at least my version) does worse.
Thanks again.
Karl
You have no reservoir caps on your AVR supply, pins, just some measly 0.1uf caps...what will supply trasients at the avr & IO circuits (such as fet gate pulses)?
Double all of your fet trace widths they are too small, especially when you have multiple heaters packed together.  75 mil for the 2.8amp fets  Otherwise you are just pouring your copper down the drain...why?  Trace calculators aim to prevent the traces from burning up, not for high performance.
That's an absolutely horrible fet (STN4NF20L), unless you need to switch 200V...do you?
There are many other multi channel fets that will do a much better low voltage job...Also, what are you doing about short circuits?
All your fets should connect to a gnd plane section on the bottom...put your gate traces on the top.  Other arrangements are possible...but lots of current totals up into your gnd
It's a ridiculous layout to put all the gate resistors way over ...there....why are you creating a million extra traces?  Put each resistor at the fet where is connects to G & S!!  Note the big center tab is also D
The labeling of the MAX3061 is complete bogus...you can't tell what those pins do, same for the AVR...label the pins with their functions.  $P3$38 doesn't cut it!
Why is the 12V  connector 2 inches above the 5V regulator? Shouldn't it feed INTO the regulator?  If it is an input connector it belongs on the left side of the schematic.
Why would you control 1000 relays using fets?  Could you simply use the fets?  Of course in some cases the relay is needed...but you should check carefully.
I'd add a 1-2ma led at each gate, so you can tell what is going on...later you could simply stop populating them.  But you will probably find they are too valuable to get rid of.
The trace calculators only tell you the trace width for a given temp rise. They don't factor in inductance which is critical in your application. Just recently I was debugging a pcb (8 layer) that had bad power routing and the mosfet would oscillate at around 60MHz when switched with a load. This was due to the inductance of the ground track to the mosfet. This caused what is known as ground bounce. You also need to consider what happens when the loads are drawing current and you get a voltage drop across your ground wiring and your microcontroller is in the middle. Bad juju is what happens. So, keep your load ground separate from the ground to your ics. Also consider the paths the ground follows from your connectors - like the RS485.
A regulator like the Recom R785 series is a 7805 drop-in that solves the temperature rise problems. It is a miniature switcher. Not super cheap, but it solves a common problem.
If you're using tantalum caps, don't put them on circuits that go to the outside world. They like to go up in flames.
Having input protection on your power is always a good idea. Use a polyfuse in series and transzorb in parallel. That way reverse and over voltage is taken care of.
High value ceramic caps have special considerations - they tend to be voltage and temperature sensitive as in the capacitance decreases with voltage and temperature. Add in ageing too for some fun. The datasheet needs to be read carefully. eg a 100uF 6.3V X5R only gives around 20uF at 4V. Even less if we factor in temperature and ageing.
There's mention of the mosfets controlling relays - the relays will need catch diodes on them. Other solutions are using TPIC6595 chips that have 8 drivers and a shift register in them. These have clamp diodes built in. There's also the ULN2803/4 drivers. These have catch diodes built in. These devices will simplify your pcb design.
Your board looks autorouted as there is strange routing - like around the crystal. These tracks should be short and direct without going through vias if possible. You also want to keep other tracks away from them and have a groundplane on the bottom layer. 90 degree angles on the tracks are a contentious issue. Personally I don't like the look of them, so I use 45degree angles. Most pcb packages do this for you. There were stories of acid traps and impedance problems, but these seem to have been dismissed.
> just some measly 0.1uf caps ...
Standard bypass caps. The fets only draw a few uA, so I thought the .1s would be fine. What would you suggest?
I don’t understand this comment.
I’m more concerned about things burning up than performance. The fets won’t be fired faster than 15 Hz. I’d also like to keep the board as small as possible for cost reasons. Based on your, and other, comments, though, it looks like I’ll be taking another pass at it, and if it has to be larger, so be it.
What’s so terrible about it? It was one of a handful that came up in a parametric search on Digikey. My requirements are logic level gate drive, 12V, 350 mA, 4W capacity, small size, smd, low cost. I don’t need high performance for switching a relay. What would you suggest?
Wouldn’t it be better to put the ground plane on top so I could use it for heat dissipation?
At the time, it seemed like there would be complications wherever I placed the resistors (I even considered using a packaged array). I’ll try as you suggest in the new layout.
Already fixed for the MAX. AVR next.
It’s a kinetic sculpture. The appearance, and sound, of the relays are essential.
Thanks for the feedback!
Karl
Thanks for the tips, Kartman, particularly the ULN2803. Completely forgot about those things, but they could solve a lot of problems (especially cost and size), if they can handle the power of all 8 relays simultaneously. Have to check the data sheet. Btw, don’t MOSFETs have check diodes built in? I’ve been using them for all kinds of inductive loads for years without external diodes for just that reason. Never had a problem.
***Put a 4.7uf cap at the AVR to handle any bulk loads  0.1 good for noise
****when you use thin traces ...where do you think all the etched copper ends up...down the drain (or hopefully recovered).  Thick traces use the copper you were given.  What do you gain by throwing it away?
*** you have plenty of room...you are far far from being size limited.
****So why pick a 200V part...all you get is extremely high ohms (1.5ohms!!!)***...even 0.1 ohm is pretty poor these days.
****almost any other fet will be better...pick again  (search for around a 40V part)
also see ZXMS6004 dual & ZXMS6005 protected fets...higher resistance, but no burn out!
https://www.mouser.com/ProductDetail/Diodes-Incorporated/ZXMS6004DT8TA?qs=sGAEpiMZZMshyDBzk1%2fWi8Ex7o5z%2f%252bUs%2fymCgplIxYg%3d
**** could be, but you'll get plenty cooling on the bottom.   Keep room on top for your traces.  Use a 0.1 ohm fet or less & heat will be 15x lower than 1.5 ohm fet
**** goody
**** the question is , why use relays at all...MUCH less reliable...maybe they are already present & no choice.
**** You will likely not need diodes, the fet's built in zener should easily handle the flyback, If you were driving 10 amps at 10KHz might be a different story, even then perhaps not.
Have used larger power fets at 40amps for motor PWM, no diodes needed.
****Maybe add some buzzers, which can be made to "click"
Perhaps these are open relays, where you can see them in action? (see 1:50  https://www.youtube.com/watch?v=n3wPBcmSb2U)
Karl
Writing such a post from what I see from a (not so clear) schematic / pcb is quite time consuming.
I am perfectly aware that any sort of GND connection is often "forgotten" on simplified RS485 examles.
Have you looked at documents such as "10 ways to bullet proof RS485" (I believe an old AN from national instruments, but quite good).
Twisting wires is always good for RS485. Shielding is ... not needed for such short runs.
Quite fancy / flashy photo, is each grey blob on the foto a RS485 node? You can not put so many nodes on a single cable.
If you put everything so close together, the ruggedness of the RS485 drivers becomes less of an issue.
170A over distributed power supplies is however a point for carefull consideration.
Solid GND & power connections becomes very important.
You do not want any signal lines to conduct a significant part of that current.
That will melt your wiring and give you a bad name.
But I do not have enough overview here for a complete overview of your product.
About SMPS:
A nice little chip such as for example LM2841 has an quieschent current of 1.5mA and a typical efficiency of 85%.
You do the math :)
I am a bit unpleasantly surprized by the mouser price though.
There are however hundreds (thousands?) of different small SMPS circuits nowadays, and you can buy build PCB's (working, with chip inductor and everything) from prices of 50 cent or so from Ebay / Ali. My guess is that Mouser / Digikey / Farnell / etc have proffit margins of 300% or more or have not seen a need to optimize their workflow costwize for 30 years or so. (I am just guessing here, such a remark can easily backfire). But the price difference with asian shops is ... astounishing.
But compared to your 12V 170Amps the power requirement of your microcontollers is ... almost nothing.
The "bulk" capacitor can indeed be placed almost anywhere on the PCB, I skipped a beat there.
If power consumption of the relays is an issue there are loads of ways around that, such as:
- Switch Relay @ 12 V and then PWM an output to about half that voltage (1/4 of the power to relay).
- Use bi-stable relays.
- Why use relays? What are they switching? Those things are noisy. Is that an issue?
(Too much micro management from my side, probably I should not even ask such questions).
(Poly) fuses should of course be calculated from the current they need to pass. How would I know what fuse you need?
These are wonderfull "self repairing" devices, but have some gotcha's. They open up when heated (Also by an exernal heat source) at quite low temperatures. They are also not very accurate and really only designed for preventing gross faults under severe overload conditions.
Experiment with them before you implement them.
Trace size calculations are often only based on temperature rise of the trace (often 10 Celcius?) You also have to consider voltage drop over the trace etc.
It's very simple: Wide traces are better for big currents.
Narrow traces for high current traces with also a via in the middle is bad practice.
You can very easily draw stubs on the GND trace and move all the vias to the MOSfets to those stubs, to at least preserve the with of your trace.
(Especially small) via's have a limited current handling capability. It is very common to use "via stitching" (Google that) with multiple vias to get a high current trace from one side of the board to another.
But really, the whole PCB design is ... very marginal at best. You clearly have to learn some tricks there.
Browse a bit around. Have a look at other PCB designs.
Optimal PCB design is also an art in itself and the art in decent engineering is far to ofthen not acknowledged.
Or even invisible, which is a compliment in itself (it just works).
It's not the repetition rate that's the problem but the rise-time of edges. Remember that a square wave has a frequency response that extends out to infinity. Think of an inductor (ie length of track) as a bell. Hit it with a hammer (ie edge of a pulse) and it'll ring for a long while.
Now hit that bell 15x per second with a hammer ...
(But don't do that when I am in the neighbourhood).
Something often used here is to use series resistors in the gates.
They form a low pass filter with the internal capacitances of the FET to make them switch slower on purpose to make the switching flanks (and thus frequency content) more gentle.
It's like hitting the bell with a padded rubber hammer instead of a steel hammer.
Yep---I always put some resistance in the fet gate (usually placed at the fet rather than at the micro) , maybe 1K ohm...then if the fet shorts (such as when I drop my screwdriver), it doesn't just blow 20 amps into my AVR.
I believe OP is at 170mA, what's a factor of 1000x between freaks.
I recently saw on a post here (or somewhere) some newer polyswitches that have the tranzorb/zener combined in one...that solves some "issues" since a reacting (very hot) zener then helps to "pop" the polyswitch quickly (before the zener fries).  In the old days, you'd pick a massive zener that could take the heat, waiting around for the polyswitch to kick in.
avrcandies wrote:
... that have the tranzorb/zener combined in one.
Polymer-enhanced Zener diode or PolyZen :
Littelfuse
PolyZen Devices for Overvoltage-Overcurrent Protection
http://www.littelfuse.com/products/polyzen-devices.aspx
Simple and effective especially for signals where some impedance is acceptable.
Rugged Circuits
Rugged Circuits
10 Ways to Destroy an Arduino
https://www.rugged-circuits.com/10-ways-to-destroy-an-arduino
Method #3: Apply Overvoltage to I/O Pins
Yes, those are much better.  It looks like each channel is built around a MOSFET in the datasheet, but they don't show the body diode.  I count on those for protection when using MOSFETs with inductive loads.  Do you know if there is one, or I'd need to provide one?  Also, how do you suppose it would compare to a ULN2803, as Kartman suggested?
Correct.  Like this one.
Whilst the mosfets have a body diode, where does this the energy go? You rely on the impedance of the circuit, but there’s nothing specific to waste the energy. Also consider the loop that is formed by your relay circuit - this will most likely radiate. You’d be better off putting diodes or varistors on the relays themselves.
I know.  And I greatly appreciate the time you've put into helping me.
Not that particular one, but I found it and added it to my stack of reading.
I'll definitely be using twisted pairs, but the runs will only be about 18 inches.  While short, I'm alittle concerned about all the RF radiated by so many relay coils.  Still, swapping the cables for shielded ones, or just starting with them, wouldn't be difficult.
No, each blob is a relay (like this:  http://tinyurl.com/yabsrzst).  Each 4 x 4 arrangement of 16 relays will be a node, 64 nodes total.  Each driver presents a 1/8 unit load, so the bus can handle up to 256 of them, in theory.
The intent (and, hopefully, design and implementation) is that the current consumed by each relay flows from the power supply to the coil to the FET to ground.  It should never come close to a signal line, except at the FET.
> About SMPS:
I'll revisit this.
I agree, and for my own, one-off stuff, I use those little buck/boost boards all the time.  I'd never build one into a product like this, though, due to quality concerns.  Plus, I'm not wild about adding PCBs to my PCBs if I can build the same functionality directly onto the board.
As a piece of kinetic sculpture, the appearance, movement, and sound of the relays are essential components of the piece.  They're actually not switching anything.  Ultimately, I hope to hire a percussionist to compose "music" to be played on it.
Not at all.  There's no telling what may come up from "such questions."  ;-)
It all flows back to my house to help lower my electric billssurprise
Actually, the body diode looks like a zener of the mosfet's rated voltage (say 40V)...so when it avalanches it looks like a 40V drop conducting the current that was previously flowing (say 1.23 amps)  so that V times A  is those watts disappearing. Of course, doing this at 2KHz can heat up the fet (diode), but it is a power fet!  Some smartfets have active clamping to actively quench the transient by slightly turning back on (sort of applying the brakes).  Since the excess energy is doing the turn on, as it dissipates, the fet goes back to being shut off.
Most normal fets seems to do pretty well in this regard, but there are specific "avalanche rated" fets that have toughened (and/or more fully characterized) body diodes....more imperative at high currents/fast repetitions.
https://www.mouser.in/pdfDocs/diodes-inc-automotive-mosfets.pdf
The ZXMS do not require diodes ---they have the active clamping and several other protections:
• Short circuit protection with auto restart
• Over voltage protection (active clamp)
• Thermal shutdown with auto restart
• Over-current protection
• Input Protection (ESD)
• High continuous current rating
also see fig12
https://www.onsemi.com/pub/Collateral/AND8202-D.PDF
As impressive as the ZXMS is, the ULN2803 suggested by Kartman is looking better and better. It takes less space than 8 FETs, has flyback diodes and pulldown resistors built in (further reducing space), requires only two traces per relay (instead of three for a discrete FET, simplifying routing), it’s cheap, and can handle all my current (2.5A rated vs. 1.4A in my application). It takes more current to drive than a FET, but still only 1 mA/IO, or 16 mA total for me, well within the Mega’s ability. Any thoughts about this?
You have to be carefull with the maximum dissipation for the ULN2803.
It can not handle a continuous total current of 2.5A. Where does that 2.5A come from?
Different brands have differences in datasheets, make sure you get the right one.
A motorola datasheet I looked at has no info on this (didn't look to carefully)
A toshiba datasheet https://cdn-shop.adafruit.com/datasheets/ULN2803A.pdf limits power dissipation to 0.5W for the whole package with a Vce saturation voltage of around 1V, which means 1/2A total continous current for the whole package.
I’ve been referring to the TI data sheet for their ULN2803A(http://www.ti.com/lit/ds/symlink/uln2803a.pdf). It implies a max. current sink of 2.5A, thought I’m confirming with TI.
As Paul suggests, you need to be aware of the thermal limitations. You can’t take one spec in isolation. Mosfet specs are one too look out for - the spec might say good for 100A, but do the loss and thermal calcs might suggest it will do 100A on an infinite heatsink for a microsecond!
Also, your relays look like big ones, so you need to consider if the internal catch diode is man enough for the job.
You could always go to 24VDC and halve the relay current.
The ULN2803 seem a bit marginal, if you need to keep the relays all on for any time...maybe ok if just "clicking them"...at 170ma, you'll drop about 1V...relay might take more current, if it's resistance is not precise (or your 12V  becomes 12.5V)
Might consider  active clamp https://www.diodes.com/assets/Datasheets/DMN61D8LQ.pdf  ..it has an awful Rds, but at 170ma, still only about 300mv drop.
It's cheap, small (sot-23) & lets you spread the heat out (plus @5V logic, the total heat is about 1/3 of the ULN part)
There are probably similar parts, with lower Rds
That DMN actually looks like an excellent part for this application, much as I’d miss the simplicity of the ULN. It certainly has a lot more margin than the ULN. (1.8 x .17) x .17 = 52 mW means temperature wouldn’t be an issue, plus the active clamp and integrated pulldown resistor. I ordered some to test. Thanks for the pointer.
note you can also get a dual version:
https://www.diodes.com/assets/Da...
By the way, how will you hook up 1000+ relays with the rs485---it is limited to 32 nodes, are you using multiple uarts?
If the relays are located close together, you could implement a board to board shift register/spi approach.
Jeez, your part search Fu is way better than mine.  ;-)  That part may actually take up more space than individual FETs, though, given the fat traces that have to be routed for drain and source.  I'll play around with it to see.
The piece will be assembled out of modules, each containing 16 relays and a controller board based on an ATMega32A.  16 of the 28 IOs go to the relay FETs, 7 go to a dipswitch to set the RS485 address, and the UART goes to the RS485 transceiver.  The transceiver I'm using presents a 1/8 unit load, so I could have up to 256 modules on the bus; 64 shouldn't be a problem.  A host controller will send 3-byte packets to all the modules on the bus:  1 byte for address, and 2 bytes representing the state of the relays for the associated module.  Worst case, I should only need about 300 kbps (the transceivers handle up to 500 kbps), but I think I can get it much lower.
Think carefully about fault tolerance on your project.
You might well wish to send your data in a small packet, with a Start of Packet character, your three data bytes, and then a CheckSum byte, (or a CRC Byte, instead of the CheckSum).
That would allow the receiver to validate its data reception prior to (re)setting the relays.
The next level of data checking would be to have the remote units send an acknowledgement back to the main controller...
All good ideas.  Just haven't gotten that far into the project.
You can also have an address that commands all units, then easy to clear all, set all, or set all to the same pattern.
You can also have an address/value that sets the specified unit into always rcv (so the selected unit takes action regardless of the address)...you could set a few such modules , then  those modules would respond to all patterns sent out.  some variation  would bring it back to normal address-checking operation.
Bleh....I use a button & store the address identity in the EEPROM...one command says "config unit 19"...any button press & that (or those) units are now marked as being unit 19.  I also have a slightly different command that autoincrements the call #, upon getting a buttonreponse from anyone.  So you give AUTOID13 command & then just start hitting buttons on modules...first one pressed will now be stored as #13, the next as #14,.... #15, ...etc.  Also, certain commands are responded to by all modules, regardless of their address (such as system standby command).
Since the address is being set in software, you could also possibly give a module more than one address (maybe allow a list of up to 8 addresses per module)..so by sending to a shared address, multiple boards couldinstantly  respond (might be an interesting effect).
You MUST  include an led on your module, so you can see that it is responding to the present command.  You will severely regret not having one!  Also add a pushbutton.
I'd prob avoid that initially unless you are using full duplex.  Half duplex requires extra thinking/fiddling, which I did , since it was done by a half-duplex radio link.
Really something to think of before you you have your PCB's manufactured.
The last revision of the PCB I saw was receive only for the "remote" nodes.
Also:
If there is a "master" node who controlls all, I would probably add a bunch of RS485 chips to a single UsART there. ( 8 is a nice round number).
You can tie them all to the same UsART by toggling the driver & receiver enable lines in a smart way.
This will considerably reduce the loading on the RS485 bus and will also simplify trouble shooting.
These are great ideas, avrcandies, and I'd love to get away from the dipswitch.  My concern is that the piece is likely to be assembled and disassembled several times during its life, and I may not be present for each assembly, so I have to anticipate what may go wrong.  Of course, it's essential the modules be installed in the frame in a precise order, but, even though each will be labelled on the back, that may not happen.  If one module is out of order, then two will be out of order, and some (potentially a lot) of disassembly/reassembly will be required.  On the other hand, if each module's address could be changed in the field, via the dipswitch, disassembly/reassembly wouldn't be required.  That said, it might be safer overall to just disassemble/reassemble than have unskilled labor fiddling with dipswitches on PCBs.  Plus, any readdressed board will no longer match the order number printed on their panel.  As you can see, I'm still working through this, so I appreciate the nudge.
As for an LED, I could more easily just use a relay to signal feedback.  Maybe LEDs on the Rx/Tx lines, though I'm bringing those out to test points for debug during development.  Not sure how valuable LEDs would be once the thing is in the field.  If it stops working, and I have to go fix it, I'm going to need a scope and a bunch of other stuff anyway.
I certainly should a button, though.  Thanks for that.
True, as I didn't think I'd have the bandwidth for a resend anyway.  Now I think I will so I'll enable half-duplex.
Excellent idea.  Thanks.
This project seems like a PLC(programmable logic controller). Why not just use one of them? The scale of the project suggests there’s a few dollars involved, so failure or unreliabilty is not going to make the customer happy. Just wiring the system together is a big task, some consideration here is going to save time and money as well as contribute to the overall reliability and maintenance of the system.
Personally, i don’t think RJ45s are going to cut it. I’d be using plug in screw terminals. More expensive, but easier to terminate and more robust.
I’d look at the following:
24V relays to drop the current requirements down.
Pcb mounting - maybe use DIN rail mountings/enclosures. A lot of industrial gear uses this method. Cuts down on screws etc and makes it easier to design, build and maintain.
Serial drivers like the tpic6595. Makes your pcb design easier and less i/o required.
Blinken lights. Add leds so you can see what is working. For rs485, a tx and rx led is a great diagnostic tool.another led for ‘heartbeat’ is also another great diagnostic tool.
Consider the implications of managing the relay back EMF. Having a diode across the fet protects the fet, but shunts the energy back into the supply. Multiply that by 100 relays and you’ve got a recipe for disaster. Best to put a diode or varistor on each relay on its terminals. The energy gets wasted as heat and is spread over the number of relays. Your board never gets to see it.
Voltage drops can ruin your day.don’t discount the amount of current that might be flowing that will cause voltage drops. The size of the conductors and how your system is wired is crucial to reliability. A star technique is useful here.
As the Doc mentions, your serial protocol is inadequate. You might want to look at an industrial protocol like Modbus.
If you’re in the western world, you’ll most likely have to consider EMC. If your system radiates and causes interference, then you’re in for trouble. I’ve had the regulatory body knock on my door.. Seems the cell providers don’t like interference with their frequencies. Seems a pcb track and mosfet can make a nice transmitter. It was only meant to switch a relay.
I'm aware of PLCs but have never used them.  I'm not sure something like this would be a good learning exercise for them.  While this will certainly be the biggest thing I've ever made, more of it is within my range of experience than if I went with PLCs.
As for PCB mounting, I'm planning on putting them inside off-the-shelf enclosures, tbd pending some idea of how big my board will be.  I haven't decided yet if I'll have the four cable jacks penetrate the enclosure, or just bring all the cables inside through a single cutout and then plug into the jacks on the board.  The former would be easier to assemble/disassemble in the field, while the latter would provide better ingress protection from dust.  In either case, all penetrations of the enclosure will be pointing down.
Don't bet on it...you want to perhaps see a specific condition/thing occurring...an led will tell...listening for a relay to click (out of hundred), you'll wish for an led.  The led can blink, signaling it is ready & waiting for you to push the identity button.
Note, even without a dipsw, each module can be addressed (configured) as previously mentioned & then given to the the assemblers...the address is just read from the EEPROM rather than from the dipsw.
example:
load module with new software
send SETID23 command
led starts blinking
Push button....module has been set & saved as unit #23
All done...remove power & program next module
Optionally, later on (finished system)
Send SETID18 command
All modules start fast blinking
Push button(s) of module(s) desired to have address #18
Send SETID22 command
Push button(s) of module(s) desired to have address #22
Send ENDID  ...all modules leave identity setting mode (no fast blink)
Remember, each relay requires 2 wires..will you bring 2 per from your board...you should if they are  in wide-ranging locations (making daisy chaining a poor choice).
Draw up your PHYSICAL cabling carefully BEFORE designing your connector  system!!!
Spring loaded connection blocks better than screw terminal types...springs won't work loose!  Push the button, insert wire, DONE
I figured each module would have its address flashed per your protocol during assembly (of the module, not the sculpture).  Since I'd be assembling the modules one at a time, and each module only has 16 relays on it, it would be pretty easy to hear the relay.  I was originally thinking this way because I was running out of IO.  If I omit the dipswitch, I'll have plenty (though I could put the LED on one of the relay IOs, I guess).
There will be 16 relays on a board roughly 12" x 12".  My plan was to daisy-chain the 12V through the relays and just bring the other side of the coils back to the PCB.  I was also planning on buying RJ45 cables, cutting them in half, and using two halves to serve as the return lines to the PCB, using the RJ45 connectors to connect to the board.  Much denser than spring-loaded or screw connectors, and the cabling is cheap and already made up (not sure if/how I'd terminate the cut end that attaches to the relays).  Of course, these cables would be heavily strain-reliefed so somebody can't yank them out of either the relays or the PCBs.  Once assembled during manufacturing, though, they wouldn't have to be disassembled (hopefully), unlike the RS485 cabling, which would have to be removed each time the piece gets broken down for transport.  Still not sure about the right connector for that (RJ12?).
AVRCandies,
I just purchased a handful of 4-terminal spring  connectors with through holes mounting pins from Spark Fun.
I looked for them at Mouser and I couldn't come up with the right tern to locate them there.
Do you have a vendor / manufacturer / model number for the spring terminal block you posted the photo of?
Here you go, Doc....$0.54 @100
https://www.digikey.com/products/en?keywords=277-7675-ND
Also, click on terminal blocks, wire to board  at the top to see others
Given a board with, say,32 wires, would you like to change it over? Whilst it is easy in your workshop, removing 32 wires, replacing the board then ensuring you put the correct wires in the correct terminals whilst on site is probably not something you really want to experience. Plugs are more expensive, but there is no comparison when you need to change a board on site. For me, on site usually meant 30+C, having to squat down and having sweat from your brow drip into your eyes and/or whatever you're working on. After sufferering whilst replacing a board with 50+ connections, I made a vow to use plug in connections. I never regretted it.
Is CAT5 cable rated for the current the power supply can source? It is most likely a legal requirement that you follow the local wiring rules. These usually require that the wire and insulation used is suitable for the worst case current flow and temperature of operation. Therefore if your power supply is 10A, any wiring connected to the power supply needs to be suitable for that current. If not, you need to provide a fuse or circuit breaker, again, rated to the capacity of the wire. The relay may only be 170mA, but if your power supply can deliver , say 10A, then wire accordingly. Remember - "a fuse is to protect the wire, not the load".
Consider where the unit is going to be mounted. Who is going to install it? Who is going to maintain it? If there is fixed wiring, then it may require an electrician to install it. If it has mains wiring in it, the enclosure may need to comply with certain regulations. If you look at switchboards in the area you are going to install it in, see what enclosures they use. The electrical regs are in place to ensure you don't burn the building down or electrocute or injure someone. What you do at home won't cut it in a public area. There are 'standard' ways of doing things and products are built around this. Do something different and anyone schooled in the art will be immediately suspicious. You may want to obtain the services of an electrician or suchlike to advise you.
That might be a reason to use something like the ZXMS6004...since it would limit current per output, in case of a short.  Be careful to not use telephone wire that is more like "tinsel"  ...extremely flexible, but wouldn't be much good for current.
It is also avail as a dual device:
(much cheaper at Mouser $0.44, than Digikey $0.74  @100):
https://www.mouser.com/ProductDetail/Diodes-Incorporated/ZXMS6004DN8-13?qs=%2fha2pyFaduinE%252bJ69nksx2pvWRG5ceARoqJwK14HJv8lL%252b7W5miUKA%3d%3d
https://www.digikey.com/product-detail/en/diodes-incorporated/ZXMS6004DN8-13/ZXMS6004DN8-13DICT-ND/5724360
Power-over-Ethernet permits 600 mA/Cat5e pair.  The smallest wires used in Cat5e are 24AWG which is rated at 577 mA.  I'm using 170 mA/wire so it seems OK.  Certainly I'll fuse the main supply line to each panel which will have a nominal consumption of around 3A.  As an artwork that will be doing some travelling, I'm just going to have to take my chances with local regulations, but it's a good idea to run the high-voltage wiring past an electrician, even though it's being designed to just plug into regular mains.
I like that part but I can't figure out from the data sheet if the gate has a pull-down resistor on it like the DMN61D8LQ, which also comes in a dual package.  I left a message for Diodes about this last week and they never called back.  Just tried again and they didn't even answer.  Sent an e-mail to Digikey to see if they can find out.  The dual version also lays out better than the dual DMN61D8LQ, but nobody has stock (in the US) and there'a 16 week lead time.  I also asked Digikey to verify the part is really Active, as they say it is.  The dual DMN61D8LQ has a lot of protection already, so it may be adequate.
24 gauge copper wire is has 84.1976 milliohms per metre.  At 170 mA, one metre will have a voltage drop of 14.3 mV on the positive, and a voltage rise of 14.3 mV on the GND, for a total drop of 28.6 mV.  A 10 metre cable will see 0.286 V drop.  Make sure your gear can deal with that.
"Read a lot.  Write a lot."
My runs will be less than a foot.
Cosider ZXMS6004DT8TA...slightly more $$ but in stock now..I use it in my design...take careful note of the package (SM-8)  on the datasheet (does not compare to digikey website image!)
The other one will be back in stock at mouser June 11 & digikey june 3   Mouser has 60,000 coming in batches.
The internal fet circuit draw about 100uA , so probably acts as a "pull down"...but not needed anyhow, the processor output will be high or low (once out of reset & ports set up).
You might try one as a test--BEST bet!   I'd probably leave a spot for pulldown at GS.  I also like to have some series resistance to help prevent popping the micro should the fet blow.  Probably 1k for this part.
Just spoke to a Diodes FAE. No internal pull-down resistor, so I think I’ll stick with the dual 8LQ if it tests OK.
> (once out of reset & ports set up).  You might try one as a test--BEST bet!
That's the catch.  I've omitted the pull-down in other MOSFET designs only to find it works fine 95% of the time (so I didn't catch it in testing).  Of course, we all want 100%.  I haven't used this specific part, but given the FAE says a pull-down is needed, and I'd like to avoid using one for all the obvious reasons, I'm still leaning toward the DMN61D8L, dual channel part.  The worst-case scenario of going without a pull-down is that all the relays fire briefly at startup.  Not the end of the world, since the piece will be doing that periodically when running, but it could be quite surprising to whoever is flipping the switch.
This is also easily preventable if the uC gets power before the relays do.
By the way, is there one supply for the whole caboodle?  Seems like you need to divide it into four 12V 50 amp supplies.... is a common supply size.
If you could go to 24V relays, it would save you a lot of pain, since currents would be cut in half (thus losses cut by a factor of 4) & any voltage drops are less significant
Do these relays actually drive anything?
Of course, but how to ensure that, since the uC is powered from the same 12V supply?  I could run the 12V through the PCB and gate it with a relay, but an appropriate SSR will be expensive and an electromechanical one will require a driver.  This is certainly doable, but added cost, size, and complexity compared to the DMN61D8L which has integrated pull-downs and active clamping, and was made for the hostile environment of an automobile.  It doesn't have all the protections of the ZXMS6004DN8, but seems adequate.  Am I making the wrong tradeoff?
I'm leaning toward 8 supplies, 400W each.
I'm not committed to the 12V relays.  I can still go with 24V.  The main consideration is the DC-DC converter on the PCB to generate 5V.  At 12V in I can use a linear regulator.  At 24V in I need an SMPS which is more of a pain but not a huge deal.  The voltage drop isn't crucial either, however, since the 12V relays will switch down to 8V, and I calculate less than 1V drop even over 9', the longest a run would be from the power supply to a module, if I mount the supplies at the bottom of the structure.  If I mount them in the middle, the longest run would only be 5'.
Nope.
Actually, I just checked and the 24V version of my 12V relay is about a third more expensive (another $9).  While that's at quantity 1, I've spoken with the company about volume discounts and it's a very flat curve.  That may change if I come to them with an actual order for 1000, but for now I'd need a pretty compelling reason to go to 24V.
If someone is telling you a 24V relay will cost a lot more than 12V...they are pulling your leg, or inept...go talk to someone else.  There are plenty of low cost 24V relays...do you have specific requirements?  I did ask--are you switching high currents?
I bet these 24V relays are $2 to $5 each
https://www.alibaba.com/product-detail/ASIAON-Chinese-Online-Shopping-Cheap-Price_60523602076.html?spm=a2700.7724857.main07.32.636818afTz8YFi&s=p
these beefy relays are less than $2 each:
https://qianji.en.alibaba.com/product/60469383024-803328054/QIANJI_2016_New_Manufacturer_China_Miniature_Mounting_Original_Power_Relays.html?spm=a2700.icbuShop.prewdfa4cf.77.54a139e3dk4ZCJ
Yep, for 24V to 5V a linear is only 20% efficient...bleh, ...however you probably only need 15ma (if that) at 5V , so that's only 1/3 watt drawn & 75mW delivered...so the regulator will barely break a sweat.  You'd need to check you rs485 current needs (but I  assumed they were only a few mils)
Candyman, from what i can gather the relays are only making noise - not actually switching current. I too are surprised about the cost. Generally industrial relays are cheaper at 24VDC as that what most people use.
Laufman - i’d be checking industrial automation/electrical suppliers for their price rather than the likes of Mouser. Over here i’d expect around 30% off list for 100+.
If you want noise, mount the relays on wood.
As for switching regs - https://www.mouser.com/ProductDe...
Drops in place of a 7805. No heatsink needed. I've used zillions of them in 24/7 at 70C application.
... or Altoid tins with lids off.
My problem with Alibaba is I find it very hard to find what I'm looking for, given the crudeness of their search tools.  When I do find something promising, usually it has a huge minimum order.  This is a problem with both your links, though only the second would work for me aesthetically.  It's possible if I dangle the prospect of a 1000 piece order in front of them I can get them to sell me just a few, and I'll give them a shot (thanks for the pointer).  In lieu of a Chinese supplier, I've been dealing with US distributors, hence the high absolute price.  I don't know why they charge so much more for the same relay in 24V.  Given that the relays are the biggest single line item in the BOM (by cost), I'd love to get that cost down.
That's the problem.  Between the MCU and RS485 chip, most of the time I'll be at 40 - 50 mA, which would put me close to 1W if I have to drop 19V.  Plus, the RS485 chip can draw as much as 250 mA if the bus shorts out somewhere, so the regulator/SMPS has to be able to go that high.
Aliexpress is designed for small quantities...
It's a problem being old - one tends to get Altoids!
Actually I have NEVER held one, but know that they are popular project  boxes in the US and "universally" recognised as such.
I've been dealing with Allied Electronics.  Dunno if they're the cheapest, but they certainly have industrial automation covered.  If you have a favorite supplier for this sort of thing, please let me know.
I've got some similar things on order, including from Recom, though not that particular one as I'd prefer to keep everything SMD.
I'll be using marine grade plastic panels.  They'll last forever (even outside, where this machine will be occasionally) and don't need to be painted or sealed.  They're nice and rigid, so should make excellent sound boards.
Ross - my poor attempt at humour altoids == hemroydz!
Laufman - I'm not in the US, so my suppliers are useless to you. I'd try to local suppliers rather than the big distros. The marketing model may be different in the US.
It's worth shopping around. As pickle rick says :- "You're not gonna regret it - the payoff is huge"
Would it not be cheaper to go to mains voltage relays? This way you avoid all the high currents. To drive them you could use opto triacs. This works if the ac relays and optos end up cheaper than using dc relays and power supplies.
I haven't considered it only because I want open frame relays for aesthetics and I don't know how to insulate the coil connectors from inquisitive fingers.
Put a sign up "Nicht GefingerPoken und MittenGraben"!
And maybe some Blinkenlights.
Or:
Well the regulator would get hot & shut off--so not a "huge"  concern.   But the drop in switcher Kartman recommended would be nice.  Bigger issue...if your RS485 bus shorts anywhere, the whole system is kaput! Might use some drivers to split the bus into some branches, though only a partial solution (better to have part working than the whole thing silent??).  I've used some RF modules, which work nicely  www.rfdigital.com  (but extra fiddling & perhaps latency).
this might be a better website for easier ordering...you could get a relay & remove the plastic cover (non-water tight ones usually just snap on)
https://www.aliexpress.com/item/JQX-60F-1Z-60A-High-power-Relay-12V-24V-Bumper-Car-220V-Current-40F-58F-63F/32783586153.html?spm=2114.search0104.3.164.6f5a6189jnGU9f&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_5722813_10344_10068_10130_10324_10342_5722613_10547_10325_10343_5722913_10546_10340_10341_10548_10545_10696_10084_10083_5722713_10618_10307_5711213_10059_308_100031_10103_10624_10623_10622_10621_10620_5722513_5711313_10814_10815,searchweb201603_55,ppcSwitch_7&algo_expid=c5becfbe-4dbe-4589-b62b-f974bf45f4ee-24&algo_pvid=c5becfbe-4dbe-4589-b62b-f974bf45f4ee&transAbTest=ae803_2&priceBeautifyAB=0
nice
https://www.aliexpress.com/item/220VAC-40A-SPDT-Power-Relay-Motor-Control-Silver-Alloy/32216369364.html?spm=2114.search0104.3.141.26c9665bLAaOQZ&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_5722813_10344_10068_10130_10324_10342_5722613_10547_10325_10343_5722913_10546_10340_10341_10548_10545_10696_10084_10083_5722713_10618_10307_5711213_10059_308_100031_10103_10624_10623_10622_10621_10620_5722513_5711313_10814_10815,searchweb201603_55,ppcSwitch_7&algo_expid=5596a53b-9873-4dde-9d6c-d386f9640fd2-20&algo_pvid=5596a53b-9873-4dde-9d6c-d386f9640fd2&transAbTest=ae803_2&priceBeautifyAB=0
HOW ABOUT A SOLENOID--some make a loud click (need a low current type)
https://www.aliexpress.com/item/DC-12V-24V-Open-frame-electromagnet-door-lock-Force-15N-10N-travel-distance-10mm-Lock-Type/32817094427.html?spm=2114.search0104.3.284.55b377eezRcjeH&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10344_10068_10130_10324_10342_5722912_10547_10325_10343_10546_10340_10341_10548_5722612_10545_10696_5722812_10084_10083_10618_5722712_10307_5711212_10059_308_100031_10103_10624_10623_10622_10621_10620_5722512_10814_5711312_10815,searchweb201603_55,ppcSwitch_7&algo_expid=b95565dd-e87f-45ae-a888-00b474e4e455-24&algo_pvid=b95565dd-e87f-45ae-a888-00b474e4e455&transAbTest=ae803_2&priceBeautifyAB=0
Paulvdh previously suggested putting several drivers on the master controller, all connected to a single UART, then enabling them individually to do just that. Sounds like a good idea.
As for the relays and solenoids you pointed to, they’re not the look I’m going for. I really want the beefy, open-frame look.
Oh, I see...maybe this?  Still, maybe not the look
https://chinarelay.en.alibaba.co...
http://www.globalsources.com/gso...
The first one is close, except I need all the h/w to be "silver;" no brass or copper contacts.  Plus, I need double-pole (single- or double-throw doesn't matter), which is what's pictured, though the title says single-pole, so who knows what it is.
This is the one I've been evaluating:  http://tinyurl.com/yabsrzst
Have you looked at Galco? www.galco.com
No, though the ones they carry that are most similar to what I'm looking for have some brass mixed in with them, and I need them to be all "silver."  Also, their pricing seems broken:  $11,694.50 qty. 1?  I'm sure it's a typo, but not worth me chasing down.  I sent an e-mail to this outfit, but haven't heard back yet.
Your google-fu must be broken as I googled the 199x series. Galco was offering the exact same part and various other voltages as well.
The one you linked to isn't all "silver".  It has brass colored contacts.  This appears to be the same relay at a substantially lower price: https://www.automationdirect.com/adc/Shopping/Catalog/Relays_-z-_Timers/Electro-Mechanical_Relays/Power_Relays,_Open-Style,_40A_(AD-PR40_Series)/AD-PR40-2A-12D
As well, looks like automationdirect has 24vdc ones at the same price and their plcs look quite economical-
https://www.automationdirect.com/adc/Shopping/Catalog/Programmable_Controllers/CLICK_Series_PLCs_(Stackable_Micro_Brick)/PLC_Units
I went in through their home page and searched based on the pictures they showed of various types of relays.  The 199X comes up in a different category than the one that has a similar picture.  Go figure.  Anyway, Galco's price isn't significantly different than anyone else's.
That's funny...its "exactly " the same as the other , down to the smallest details...they both come from the same factory in Chaina, which probably also sells them as Goodyang brand for $3
I was speking lossely.  I need the principle sheet metal parts to be silver.  I don't care about the contacts or rivets.
That is, indeed, a find.  And, as Kartman points out, it's even available in 24V.  Think I'll order a couple.  Thanks guys!
Yup.  Hopefully I'll be able to track down some of those "Goodyangs.".
Purchasing 101 - there’s the list price and the price you pay. Many products have significant margin, so there’s room for negotiation. The smaller suppliers are usually more amenable to this. For one item I’ll usually not bother, but if I’m buying a 100 or so, then it is usually worth some negotiation. If the potential savings is $100’s of dollars, spending an hour or so searching and making calls is economically sound. Simply saying ‘i want to buy 100 of these, can you do a better price’? You’ll probably get a10% discount right there.
Note that the price for the 24VDC is the same. For both the 199x and the automation direct one. You should pay digitaldan a spotters fee for finding that one for you!
And then there's this, which looks like the best bet yet.  It's not as square as the other, but for the price, I might be able to make do.  E-mailed them to see if they'd be able to handle my volume.
Off Topic and On Topic:
AVRCandies, thank you for the link to the Digikey page for the little spring connectors, I appreciate it.
Now back on topic, I just assembled 5 PCB's yesterday, 1/2 SMD, 1/2 through hole.
I paste the board, place the SMD components, and then put the board in the electric frying pan.
Four of the Five boards came out great.
One had the micro misaligned in one direction so that the all of the pins on two side of the chip shorted out two pads, instead of lining up correctly.
With this Thread in mind, instead of cutting the legs off the micro and installing a new one by hand, I added some flux and re-heated the board.
It was then easy to lift the micro off of the board.
I then tacked down two pins via hand soldering, added some pasted, and re-heated the PCB for the third time.
Everything appears to have survived just fine.
> Purchasing 101 ...
There are a lot of interconnected pieces during the design phase.  My initial focus has been on identifying an architecture that will work (modules connected via RS485, MOSFETs for the relays (and which ones), which AVR has sufficient IO, how I'll power it (linear regulator or SMPS), etc.).  As we all know, this tends to be kind of a scavenger hunt, with a lot of back-and-forth as different components, capabilities, and considerations become known.  As I pointed out at the start of this thread, I even do some layout at this stage to get a sense for how big a board I'll need.  I knew relays existed and initially only did a cursory scan to find something along the lines of what I'd want to end up with.  I wasn't planning on drilling down on the specific model, and grinding the vendor on price, until later.  Anyway, I appreciate all the suggestions, and if you come across any other cheapos, please let me know.
I've had that happen to me, and for one-offs I often can just reheat the part with a hot air rework gun and nudge it back into place.  If it's too mangled, I replace it with a fresh part.  I've never had a problem with this and have even done it multiple times on a board where I kept bricking the CPU (don't ask).  I had problems with some of the traces lifting, but not with the operation of the part.  My concern is I don't know how I'm affecting the life expectancy of the part.  Obviously, that's not something that appears right away.  It can work fine today, the next day, next year, and even forever.  But it also might die in a couple of months, or a couple of years.  There's no way to know.  I agree, as someone pointed out earlier in the thread, that if you watch the device carefully, heat it slowly, and stop heating it once everything reflows, you're probably just as good as if you'd followed the recommended curve, so maybe I'm needlessly concerned.
