Removing files with bad filenames from project
6 posts / 0 new
I accidentally had 3 files with a space in their file name (late at night etc.)
Now I can't remove them from the project, right or left clicking on the file or sneaking up on the file name with the cursor brings up this screen and I can do nothing about that. AS 7.0.1188
The project file is just XML so if you are careful you can just remove the "dodgy bits" using a text editor. In fact Visual Studio itself (and hence I assume AS7 too) makes pretty good XML editor. The only issue is that if you try to load/edit a proj file then Studio will tend to treat it as an actual project file so you may need some kind of "open with" to make sure it just opens it for text editing. Alternatively just use Notepad++ or similar to edit it separately.
I tend to use Notepad++ for this - it "understands" XML, so gives you the syntax highlighting, section collapsing, etc., etc
To get AS to edit it as XML, I would probably rename <project>.cproj to <project>.cproj.xml  - and back again when done ...
The "fix", late last night, was to create dummy files with the bad filenames including the %20 (space but space not allowed). Studio was then happy to delete the non existing files.
I just stumbled on a way to do this!
In the 'Solution explorer', right-click the Project, and choose 'Unload'
When it's unloaded, you can right-click it and choose, 'Edit <whatever>.cproj' - this will open it as an XML file for manual editing.
smiley
Yup, that's the way I do it in Visual Studio with .vcxproj files all the time.
