Problem compiling gcc 4.0.2 with latest patch (0.99.2)
12 posts / 0 new
Hi there,
I'm trying to recompile my gcc crosscompiler with the current patches in order to test and possibly work with the Qtopia port. Unfortunally, I'm stuck with the following error:
/home/correa/avr32/gcc/build-avr32-linux-gcc/gcc/xgcc -B/home/correa/avr32/gcc/build-avr32-linux-gcc/gcc/ -B/usr/local/avr32-linux/bin/ -B/usr/local/avr32-linux/lib/ -isystem /usr/local/avr32-linux/include -isystem /usr/local/avr32-linux/sys-include -O2 -DIN_GCC -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -isystem ./include -I. -I. -I../../gcc-4.0.2/gcc -I../../gcc-4.0.2/gcc/. -I../../gcc-4.0.2/gcc/../include -I../../gcc-4.0.2/gcc/../libcpp/include -g0 -finhibit-size-directive -fno-inline-functions -fno-exceptions -fno-zero-initialized-in-bss -fno-unit-at-a-time -mrelax \
-Dinhibit_libc -c ../../gcc-4.0.2/gcc/crtstuff.c -DCRT_BEGIN \
-o crtbegin.o
as: unrecognized option `--pic'
make[1]: ** [crtbegin.o] Erro 1
make[1]: Saindo do diretrio `/home/correa/avr32/gcc/build-avr32-linux-gcc/gcc'
make: ** [all-gcc] Erro 2
correa@correa-desktop:~/avr32/gcc/build-avr32-linux-gcc$
Have anyone got this? Or hopefully got past this issue? Thanks.
Any issue with --pic tends to mean that for some reason an i386 compiler is being called with AVR32 options. Did you use the correct ./configure line? If unsure check the Getting Started page on avr32linux.org
Cheers,
-S.
That's what I have used, verbatim :P
It looks like I had to rebuild binutils, even thought having the .deb of all packages from BSP 2.0beta installed in my Kubunto. It did build ok with the threads option disabled (as if I was to bootstrap) but it won't work in the final config (C++ enabled).
So I started recompiling everything but I got stuck again with uClib:
make[2]: Entering directory `/home/correa/avr32/sources/uClibc-0.9.28/ldso/ldso'
gcc -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-stack-protector -Os -funit-at-a-time -DUCLIBC_LDSO=\"ld-uClibc.so.0\" -mcpu=ap7000 -fPIC -DUCLIBC_RUNTIME_PREFIX=\"/usr/avr32-linux-uclibc/\" -fno-builtin -nostdinc -D_LIBC -I../../ldso/include -I. -I../../include -isystem /usr/lib/gcc/i486-linux-gnu/4.1.2/include -Wa,--noexecstack -c avr32/resolve.S -o avr32/resolve.o
`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
avr32/resolve.S:0: error: bad value (ap7000) for -mtune= switch
make[2]: *** [avr32/resolve.o] Error 1
make[2]: Leaving directory `/home/correa/avr32/sources/uClibc-0.9.28/ldso/ldso'
make[1]: *** [ldso] Error 2
make[1]: Leaving directory `/home/correa/avr32/sources/uClibc-0.9.28/ldso'
make: ** [_dir_ldso] Erro 2
If you build uClib it must execute avr32-linux-gcc instead of gcc. So something wrong here.
If you follow "Getting Started" - it must work.
Usually erasing all sources and starting over helps (but sometimes does not:) )
"Getting Started" had an error, it said to simply run make when one has to actually run "make CROSS=avr32-linux-"... I've changed it in the wiki.
After building uClib I finally got GCC to fully build! Yay :P
I'm still puzzled thought why I had to rebuild all of those stuff if I had the binaries properly installed from the .deb packages.
If you follow
GettingStarted wrote:
Configure uClibc by running make menuconfig. Make sure you specify AVR32 as the target architecture as well as avr32-linux- as a cross-compilation prefix.
then you shouldn't need to specify it on the command line.
Yeah, I wonder why you had to rebuild everything too. Odd, it has worked for me on a number of machines.
-S.
hehe, I thought so. Despite having in menuconfig set it to AVR32 (it was even the default value actually), I still had to check the INSTALL to figure what was the variable.
I did manage to get gcc to build, but now I'm struggling with the install part *g*. Apparently automake didn't substitute the @mkdir_p@ in the makefiles... Updated to 1.8, and rebuilding.... :)
These are in different places, in fact the cross compilation prefix is pretty much the last thing in the menu.
As for why you still have @mkdir_p@s in your Makefile, that just ain't right either!
-S.
Yeah... well... I'm using Kubunto, latest stable, hopefully some other brave soul using it could try to build those packages so we have a second opinion... but I couldn't manage to get around the @mkdir_p@ after installing all avaliable versions of autoconf, automake. In the end I end up editing the makefiles by hand since what I really wanted was to try out Qtopia :P
I guess I will try the uClib again more carefully just for the sake of testing.
I also had a mkdir_p problem on two machines and used vim to replace it with mkdir -p. Somewhat boring but works.
Or use perl
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/uc/libstdc++-v3/src/Makefile
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/uc/libstdc++-v3/libsupc++/Makefile
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/libstdc++-v3/src/Makefile
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/libstdc++-v3/libsupc++/Makefile
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/avr32_ap/libstdc++-v3/src/Makefile
perl -pi -e 's/mkdir_p = \@mkdir_p\@/mkdir_p = mkdir -p/' avr32-linux/avr32_ap/libstdc++-v3/libsupc++/Makefile
Those were the ones I found in my history.
Hans-Christian
Actually now I think about it, I had some of these at some stage too. I wonder where they're coming from..? I seem to remember using sed to fix em, but whatever roger's your hammerstein.
-S.
