"Failed to Load ELF Executable"... even with the minimal code?
3 posts / 0 new
I just got myself the Atmel-Ice Basic for programming and debugging a Weemos development board I have that uses the SAM D21 G18A, (Link at the end of the post, in case you wanna watch it out) I am actually working with Atmel Studio 7 . I am able to write code on it, the fuses etc. but when I try to do debugging this error always appears:
 I am trying with this code now:
#include "sam.h"
    /* Initialize the SAM system */
    SystemInit();
    while (1)
Uploaded it and all... still doesn't work.
I don't know where this problem could come from... any suggestions?
https://www.banggood.com/Wemos-SAMD21-M0-32-bit-ARM-Cortex-M0-Core-Compatible-With-Arduino-Zero-Arduino-M0-p-1176168.html?rmmds=search&cur_warehouse=CN
Victor
Is the ELF file being generated? Maybe not as you don't really have any code or there is an error, look at the build window.
Hi, sorry for replying this late, now I am trying this code:
#include "sam.h"
#define F_CPU 48000000UL
    SystemInit();
	PORT->Group[0].DIRSET.reg = PORT_PA09;
    PORT->Group[0].OUTSET.reg = PORT_PA09;
	while (1)
	return 0;
At the build window I do get this line:
Building target: samd21gpio.elf
Invoking: ARM/GNU Linker : 6.3.1
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe" -o samd21gpio.elf  Device_Startup/startup_samd21.o Device_Startup/system_samd21.o main.o   -mthumb -Wl,-Map="samd21gpio.map" -Wl,--start-group -lm  -Wl,--end-group -L"..\\Device_Startup"  -Wl,--gc-sections -mcpu=cortex-m0plus -Tsamd21g18a_flash.ld
Finished building target: samd21gpio.elf
And still after it builded the .elf file, I get the same error and can't do debbugging.
Victor
