LED switch in stk600 with atemega2560
4 posts / 0 new
Hello everyone,
I'm a beginner and use stk600 with atemega2560. Switch is connected with PORTD and LED is connected with PORTB.
if each switch is down illuminate the led properly. but the problem is when the switch is up turn still the LED on.
I want to make LED off once switch up.
Code is followed as:
unsigned char val=0;  //senses the switch pressed
 DDRB=0xff;           //define PORTB as output
    if(!(PIND & 0x01))
           val=0xfe;
    else if(!(PIND & 0x02))
           val=0xfd;
    else if(!(PIND & 0x04))
           val=0xfb;
    else if(!(PIND & 0x08))
           val=0xf7;
    else if(!(PIND & 0x10))
           val=0xef;
    else if(!(PIND & 0x20))
           val=0xdf;
    else if(!(PIND & 0x40))
           val=0xbf;
    else if(!(PIND & 0x80))
           val=0x7f;
    switch(val)
        case 0xfe:
             PORTB=val;
             break;
        case 0xfd:
             PORTB=val;
             break;
        case 0xfb:
             PORTB=val;
             break;
       case 0xf7:
             PORTB=val;
            break;
      case 0xef:
             PORTB=val;
            break;
     case 0xdf:
             PORTB=val;
            break;
     case 0xbf:
             PORTB=val;
             break;
    case 0x7f:
             PORTB=val;
            break;
   default:
             PORTB=0xff;      //initially all LEDs are off
             break;
before while(1), I want to add it in current code (without any change in other parts) to make it work. But currently I have no idea to fix it.
I'd like to appreciate it if anyone would give me any comments.
The STK600 has active low switches(pushbuttons) if you are using those.  The LES's are also active low meaning they illuminate on a logic low so it kinda throws off many new folks.
Why so complicated a program?
Try this:
    DDRB = 0xff;    //all outputs
        uint8_t inputs = PINB;
        PORTD = inputs;
untested.
   val=0x7f;
else  val=0xff;  // no switches pressed  <-- Add this line
switch(val)
    case 0xfe:
             PORTB=val;
             break;
all leds stay on and switch doesn't work with this code.
