Get "this" reference into static pointer array
5 posts / 0 new
Hello guys,
I am a newbie so take me easy
I want to get "this" address and store it in a static array of class itself pointers.
In the header file I have:
class Usart
    public:
    void Init();
    private:
    static Usart *ptrUsart[USART_NUM];
    uint8_t usartNumber;
In the cpp file:
Usart *Usart::ptrUsart[] = {0, 0, 0, 0, 0};
Usart::Usart(uint8_t num)
    this->usartNumber=num;
void Usart::Init()
    Usart::ptrUsart[this->usartNumber] = this;
When I debug with Atmel studio 7 the ptrUsart array values remains always 0. Seem that the Usart::ptrUsart[this->usartNumber] = this;​ statement doesn't works.
If I try to do ​void *foo=this; seem to work correctly
Can you help me?
With CPP there is very little difference between a class and a structure.
The only diference is that members in a structure are by default public, and in a class the default is private.
You can simple take the address of a class just like of any other variable.
#include <stdio.h>	// My best cpp :)
class Usart {
public:
	int Number;
	void Init(void);
void Usart::Init( void) {
	printf( "%d\n", Number);
Usart SerialPort1;
Usart SerialPort2;
Usart SerialPort3;
Usart * Array[] = {&SerialPort1, &SerialPort2, &SerialPort3};
int main (void) {
	Array[0]->Number = 12;
	Array[1]->Number = 34;
	Array[2]->Number = 56;
	SerialPort2.Init();
	for( int Cnt=0; Cnt < sizeof Array/sizeof Array[0]; ++Cnt) {
		Array[Cnt]->Init( );
Save the above as: asdf.cpp and then:
paul@dualcore:~$ make asdf
g++     asdf.cpp   -o asdf
paul@dualcore:~$ ./asdf
34
12
34
56
P.s:
"make" can do a lot of things without a makefile by using a bunch of default rules.
Make guesses that ".cpp" files should be compiled with a cpp compiler and lots of other stuff...
llisotti, the code you posted looks correct for me, so the issue is apparently in the part of the code you didn't post. Please post the complete code.
Thank you guys for your replies.
I'm trying to make a generic Usart library in C++. For the scope i would like implement this solution: https://waterproofman.wordpress.com/2007/02/07/avr-interrupts-in-c/. The object have to be accessed from ISR routine through static array above. I tried loopback test  (TX -> RX) and seem the code works well !! Maybe it's an Atmel studio debug problem with static variables? I don't know
Have you looked at how Arduino does this?
