Conflicting types for Aes in Wlfssl with ATSAM4E
2 posts / 0 new
Hello All:
Did someone work with Wolfssl library in ATSAM4E devices? I took as an example the ATSAMD21 + WIN1500 Wifi project which comes with ATECC508 + Wolfssl lib.
I tried to port to ATSAM4E but the problem I have is I 'm getting "Conflicting types with 'Aes'" which is defined in both the Wolfssl lib and ATSAM4E drivers. This chip has the AES hardware module so drivers define an Aes structure for it. This problem doesn't occurs in SAMD21 as it doesn't have the AES module.
Any help on this?
Gus
Hello gussabina,
I am trying to use the example AWS IoT Zero touch kit for ATSAMG55 to port to ATSAM4E to connect it to AWS IoT.
I am totally new to FreeRTOS and AWS. I could not find a proper documentation on how to do it. Can you please tell me how to start with the porting (or how you did?).
I would be really grateful if you share link to the project (if it is okay). Else please help me understand how to port it.
FYI , I am using FreeRTOS.
Thanks in advance.
Sudu
