controlling 6 servos using atmega128a
20 posts / 0 new
hello all i'm trying to control 6 servos "50hz" by using all the o/p channels of atmega128a i read the data sheet and here is the code but it doesn't work can anyone tell me what i'm missing in the servo_init function and thanks in advance
void servo_init(void)
    DDRB|=(1<<PB5)|(1<<PB6)|(1<<PB7); //making OC1A, OC1B, OC1C as o/p
    DDRB|=(1<<PE3)|(1<<PE4)|(1<<PE5); //making OC3A, OC3B, OC3C as o/p
    TCNT1=0;
    ICR1=4999;
    TCNT3=0;
    ICR3=4999;
    TCCR1A=(1<<COM1A1)|(1<<COM1B1)|(1<<COM1C1)|(1<<WGM11);
    TCCR3A=(1<<COM3A1)|(1<<COM3B1)|(1<<COM3C1)|(1<<WGM11);
    TCCR1B=(1<<WGM13)|(1<<WGM12)|(1<<CS11)|(1<<CS10);
    TCCR3B=(1<<WGM33)|(1<<WGM32)|(1<<CS31)|(1<<CS30);
void servo_write(unsigned char degree)
    switch(degree)
    {case 0:
    OCR1A = 65;    /* Set servo shaft at -90° position 'OCR=output compare register */
        break;
    case 45:
    OCR1A = 120;
    break;
    case 90:
    OCR1A = 175;    /* Set servo shaft at 0° position */
    break;
    case 180:
    OCR1A = 300;    /* Set servo at +90° position */
    break;
    default:
    //Default code
    break;}
Have you remembered to disable the M103 compatibility mode fuse that is the default for the M128?
no , is that necessary ??
also i'm using the uart without disabling M103 compatibility mode fuse and it works fine
amrbadr wrote:
s that necessary
Read the DS and see if you need any of the resources disabled by the M103 fuse.  If so, yes it is necessary.
maybe that's why eclipse doesn't get the registers and giving errors ??
See Tip #1 for how to embed your image in the post - where we can see it
Yes, M103 has no Timer3.
I'm intrigued, how could Eclipse know that to underline refs to xxx3 in red ?
Did you actually tell Eclipse this was a project being built for atmega103 instead?
There would have to be a Project setting somewhere that said "M103 mode only" - and excluded the definitions that are not available in "M103 mode"
Is it just Eclipse - or are you getting actual build errors?
I'm guessing the "32 errors" shown in the picture suggest these are real errors, not just source browsing errors. As iom128.h has:
D:\atmel_avr\avr8-gnu-toolchain\avr\include\avr>grep TCCR iom128.h
#define TCCR2     _SFR_IO8(0x25)
#define TCCR1B    _SFR_IO8(0x2E)
#define TCCR1A    _SFR_IO8(0x2F)
#define TCCR0     _SFR_IO8(0x33)
#define TCCR1C    _SFR_MEM8(0x7A)
#define TCCR3B    _SFR_MEM8(0x8A)
#define TCCR3A    _SFR_MEM8(0x8B)
#define TCCR3C    _SFR_MEM8(0x8C)
then I'm guessing the build system is possibly using iom103.h:
D:\atmel_avr\avr8-gnu-toolchain\avr\include\avr>grep TCCR iom103.h
but that would only happen if the project is set to "mega103" rather than "mega128" so that -mmcu=atmega103 is being passed
No - browsing errors do get included in that list.
So it is possible to have that list showing errors, and yet the build succeeds!
But we can't tell from the images shown whether that does apply here.
i've changed the target hardware to M103 then M128 again and the errors are gone
You didn't answer the question: were they actual build errors, or just the Eclipse browser complaining ?
No it's look like eclipse just complaining but servos on OCR1A ,OCR1B ,OCR1C are working well
but those on OCR3A ,OCR3B ,OCR3C are not is there is any thing i'm missing in servo_init() function ???
Is Eclipse smart enough to detect the 103 compatibility fuse status and provide different -mmcu= switches?
This is easy to confirm: either the build works, or it doesn't!
If the build works - then it is just the Eclipse editor/browser complaining.
Otherwise, the build fails - with actual compiler errors for these symbols
That would mean that it would have to actually query the hardware ...
DDRE not DDRB.
/Lars
