cant get attiny45 to wake up
4 posts / 0 new
ok so it probably a noob mistake but i cant figure it out
#include <avr/sleep.h>
#include <avr/interrupt.h>
	//// turn on interrupts////
	SREG |= 0b10000000;
	//// turn on int0      ////
	GIMSK |= 0b0100000;
	//// pin set 6 as output /////
    MCUCR &= ~(1<<ISC01);
	MCUCR &= ~(1<<ISC00);
	DDRB = 0b00000010;
	PORTB = 0b00000110;
    while (1)
		PORTB = 0b00000100;
		sleep_enable();
		sleep_cpu();
		sleep_disable();
		PORTB = 0b00000110;
		sleep_enable();
		sleep_cpu();
		sleep_disable();
ISR(INT0_vect){
	GIMSK |= 0b0100000;
Not enough zeros.  Look again:
	GIMSK |= 0b0100000;
So you're setting bit 5, but INT0 is bit 6.
Your code is nearly unreadable.  Don't use magic numbers.  Use bit names.  It will at once become much more readable, maintainable, and you'll avoid the problem that got you here in the first place:
int main(void) {
  GIMSK |= (1<<INT0);
  MCUCR &= ~(3<<ISC00);
  DDRB = (1<<PB1);
  PORTB = (1<<PB2) | (1<<PB1);
  sei();
  while (1) {
    PINB = (1<<PB1);
    sleep_mode();
ISR(INT0_vect) {
thanks is it the not using bit names that was just making it hard to read?
also i like how you got two bits set so cleanly nice!!!! any way vary much appreciate it! hopefully now i can get the rest of the code working now
Yup.
