Data visualiser
2 posts / 0 new
Heloo all,
Can the data visualiser work only with Xplained pro boards? I have a Atmega which is a regular chip type and works with ATMEL ICE DEBUGGER.  The problem I face is ,I cannot read the data that I have sent or received on Atmega,with the DEBUGGER. I just want to print the values received on my SPI.
Since the UART program is not -s-o easy , I found about the Data Visualiser. Can this be used with all type of Atmega boards.?
This is a general Atmel Studio question - not specific to AVR.
ISTR that the Data Visualiser protocol is published somewhere - so you could implement it yourself.
I think that more recent versions of Atmel-ICE support the Data Visualiser?
EDIT
Microchip wrote:
The Data Visualizer is a program to process and visualize data. The Data Visualizer is capable of receiving data from various sources such as the Embedded Debugger Data Gateway Interface (DGI) and COM ports
https://www.microchip.com/avr-support/data-visualizer
Documentation for the Atmel Data Protocol:
https://www.microchip.com/webdoc...
The Atmel Data Protocol (ADP) is a content independent protocol intended for transferring data from a target MCU to a host PC through an EDBG based debugger (EDBG, Atmel-ICE, Power Debugger) using the Data Gateway Interface (DGI, see Embedded Debugger's Data Gateway Interface) or directly to the host computer using a serial port. ADP is content independent and the transfer through the debugger is transparent, meaning that the content is not interpreted by the debugger.
EDIT 2
Or perhaps it should be under 'In-System Debuggers and Programmers' ?
