Like boot_page_fill() - can I call this function with interrupts enabled, or must I disable them first or use an atomic block?
Do the boot.h functions require using atomic/cli ?
Do you even need to have interrupts turned on during boot load?
In the last one I did, I didn't have interrupts turned on (or even in interrupt table because I wanted to save the room!), but in this one the uart/i2c drivers are already working and interrupt based so I used IVSEL to get it to use the bootloader interrupt table. It is working great. I was flashing it and it would work most of the time, but sometimes fail. I found that one of the words didn't get programmed out of a 64 word page! I wrapped all of the boot_ commands with an atomic block and that fixed the issue.
