Hello freaks!
Today my dishwasher finally decided to give up after acting erratically for a while (turning off and back on randomly), after lurking for a bit I found the control board and a resistor looks burned, but apart from that I don't see anything else (visibly) burned.
One side of the resistor is connected to one side of a relay (possibly ground, the big green area), the other side is amongst other connections connected to a connector on the edge of the board, there are a load of connectors with many wires in the same color, so I'm not certain what is "out there" that is hooked up to the resistor or why it has burned.
Any idea why it burned in the first place? Under dimensioned? Are faults elsewhere probable?
What was the value of the resister, I'm reading it as brown-black-brown-black -- white (101 ohms ??? % or possibly 100 ohms?)
What is the rating? 2W?
Best regards, I hope you can help me solve my puzzle!
Geronimo
