Arduino with SD Card Memory Leak
22 posts / 0 new
I would like listing files on Arduino with SD card.
#include <MemoryFree.h>
#include <SD.h>
String current_directory;
File directory;
File filesystem_member;
void list_files(void)
  Serial.print("Directory: ");
  Serial.print(current_directory);
  while (filesystem_member = directory.openNextFile())
    Serial.write('\n');
    Serial.print(filesystem_member.name());
    if (!filesystem_member.isDirectory())
      Serial.write('\t');
      Serial.print(filesystem_member.size());
      Serial.print(F(" byte"));
      Serial.write('\n');
    filesystem_member.close();
  directory.rewindDirectory();
void setup()
  Serial.begin(9600);
  SD.begin();
  list_files();
  Serial.println(freeMemory());
  directory = SD.open("/");
void_loop()
  list_files();
  delay(2000);
But, the code has memory leak problem. Free memory are decreasing.
Has Arduino a bug?
Thanks for replies.
Maybe because there are two filesystem_member.close() statements?
No. I tried it just.
Have you asked on the actual Arduino forums?
If you do cross-post the same question in multiple places, always gives links between them.
Your usage seems quite different to this example:
https://www.arduino.cc/en/Refere...
In this they do the SD.begin() but then they use root = SD.open("/") (where "root" is a File) then root is used as the "input" to .openNextFile(). You have no apparent connection between the SD instance and the file operations then performed?
BTW the code you posted clearly isn't the code you are using:
String currnet_directory;
So "current_directory" will be an unknown symbol. It's also curious that nothing in the code ever seems to set that String anyway ?? Neither initialize it nor update it.
The key thing in the example from the manual is probably not only that root = SD.open("stuff") but it ends:
  root.close();
Your equivalent of "root" is "directory". As I say I see you directory.openNextFile() (even though no connection to SD means it presumably just takes some default?) but you never appear to do directory.close(). I don't think directory.rewindDirectory() implies the same thing at all.
Oh and by the way I tried a google for "arduino sd file memory leak" and there's quite a number of threads on the Arduino forum about it but almost all seem to boil down to wrong usage. (I figured that if there really were a bug in a core bit of Arduino at least 50 others would have hit it/reported it before you got there!)
I updated my code.
I updated my code.
NEVER DO THAT!!!
It makes it impossible to follow the flow of the thread.  Instead, make a new post with the changes.
I updated my code.
joeymorin wrote:
NEVER DO THAT!!!
+999
Indeed!
Just to be absolutely clear, that means that you should add a reply in this thread - not start a new thread!
It's still wrong anyway - I don't see the directory being closed after open.
Is this FatFS? I've never used fatfs myself, but as far as I know it can only handle one open file at any time, because it os optimizxed for space and only has one buffer for data.
A file has to be closed first before another can be opened.
My best/first guess is to compile this project on a PC and simulate the uSD card / routines.
(There probably already is some plugin for this from the fatfs development team).
Then step through the code to find your leak.
This may also be easily done with an Amel ICE, but I do not have that.
What are the contents of the leaked memory?
If you dump all ram to the serial port, does that give hints of the origin of the leak?
Does your file system use malloc() / free() combination? They should always be matched.
(And are generally advised against using them at all for small uC's, but uC's are getting bigger...).
Still, I probably prefer static memory allocation.
Paulvdh wrote:
Is this FatFS?
Nope, these are the "SD" and "File" classes in Arduino.
Source is here:
https://github.com/arduino-libra...
The (c) seems to suggest it was developed by Sparkfun
As it's implemented in C++ I rather imagine that by instantiating more than one object you can have more than one thing open at a time as everything is in classes rather than relying on anything global.
It's interesting to read the code to see that, for example, it's doing malloc() in the c'tor for File. The matching free() appears to be in the File::close() method. I don't see anything in SD.cpp doing malloc()s though.
Obviously one could pepper this code with Serial.println()s to note when things were being malloc()d or free()d to spot any inbalance.
Doesn't GCC have a feature to do that automatically - rather than do the peppering manually ... ?
something to do with "wrappers" ... ?
Yup, a thread about that in the last two weeks - as usual Georg-Johan had the skinny on how to do it.
I agree.
Which environment use am I instead of Arduino?
Sorry,  I think that got lost in translation. What are you asking?
I think the point so far is that the problem is in your code, not in Arduino.
So the answer is to fix your code - not switch to another environment.
Sorry for my mistake.
Which environment use I instead of Arduino?
Well you can just write plain C (or C++ if you prefer) in Atmel Studio 7 and then that would let you use "FatFs" as the library for SD/MMC work.
But as others have said I am firmly convinced that there isn't a bug in the Arduino code and all this is simply an error in your use of the functions - I don't think you are balancing opens/closes so when the Arduino library does malloc()s it is not doing matching free()s to balance things because you simply aren't calling the right functions.
I already explained where to look at the code for the File/SD classes. You must have a copy locally - just modify that so that it uses Serial.println() to say when malloc()s and free()s are being called and you will see where it is you are doing malloc()s without free()s
Sorry,  that's no clearer.
Thanks for replies. I changed my code that is given below. This code hasn't  memory leak problem.
#include <SD.h>
File directory;
    Serial.write('\n');
      Serial.write('\t');
      Serial.write('\n');
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
  SD.begin();
void loop() {
  // put your main code here, to run repeatedly:
list_files();
directory.close();
delay(2000);
I forgot directory.close(); line.
As clawson noted in post #9.
Please mark the solution - see Tip #5.
It was #5 where I mentioned the .close() thing.
so it was - I think I just scrolled backwards til the first mention I saw.
