Can you insert a Page Break in the Atmel Studio Editor?
17 posts / 0 new
I would like to print a listing of my program source code, which is about 10 pages long for a Code Review.
I will need to format the listing so the pages break at logical places and I can have one or two functions on a single page, etc.
Is there a Page Break character that Atmel Studio has for this kind of thing?
Obviously, I could always copy the listing to a different editor and insert the page breaks if Atmel Studio does not do this.
I could also insert blank lines to force breaks where I want them, but this is a pain to support.
It would just be easier to do this in Atmel Studio and leave the Page Breaks in the program source.
Thanks for your help,
Paul
You never know where life is going to take you; sit back and enjoy the ride!
I don't know of any IDE or programmer's editor that does this - it's really not what they're for.
You could try putting a FF (Form-Feed) character in a suitably-placed comment?
Paper based code review???
How 20th century!
Keys to wealth:
In the past I've simply inserted as many line feeds as it takes to get a break onto the "next page". But I haven't really printed anything for 15+ years now so haven't really needed look for better ways. Like Andy I can't think of any recent IDE that offers this (that I've noticed anyway). What I'd probably do is use a code coloriser (several online sites offer this) then paste the result into Word then add the breaks there.
PaulieT wrote:
print a listing of my program source ...  for a Code Review.
Trying so do a code review from a printout is very difficult - I've done that as an exercise in a classroom situation and was surprised at the many (deliberate) defects. I missed .
On the other hand  it could be worse; you could hand out punched cards for your code review.
I do occasionally find it useful to print out snippets of code. More that 1 page would be unusual.
What I do is  to select a suitable amount of the code, and then use the editor's 'Print Selection' feature.
I guess that should be doable for 10 pages ... ?
Another option:
Sometimes, when you copy code from a syntax-highlighting editor into Word, the syntax-highlighting gets into the Word doc - so you could then use Word to do the pagination ...
(other word processors are available - they may or may not behave similarly)
Ada has a page pragma (command to compiler) to either insert the FF or as an instruction to other tools.
A guess is likewise by the C pre-processor.
Or, as Cliff has suggested, a C pretty printer.
https://en.wikibooks.org/wiki/Ada_Programming/Pragmas/Page
https://gcc.gnu.org/onlinedocs/gcc-4.8.5/gnat_ugn_unw/Other-Formatting-Options.html#Other-Formatting-Options
-ff
Insert a Form Feed character after a pragma Page.
Yea ... seems to be web based now.
C-to-HTML then the reviewer can operate a web browser because some reviewers (ones in SQA, managers) don't have the IDE.
It's really bad when you drop the punch cards!
Thanks for all your suggestions.
Paul
https://www.avrfreaks.net/forum/what-c-editor-use-novice#comment-2414626
But if you want "source browsing" which involves the concept of "projects" that collect together a bunch of C and H files then you really need an IDE (though "Source Insight" is brilliant, if a little expensive).
IIRC from a skim through part of the Source Insight operator's manual, there's coloring and definitely one mention of "pagination".
The page breaks are displayed, pages can be printed, and HTML can be generated from the source code.
Source Insight
Source Insight Programming Editor and Code Browser
https://www.sourceinsight.com/
https://s3-us-west-2.amazonaws.com/assets.sourceinsight.com/download/v4/doc/SourceInsight4UserGuide.pdf (11.5MB)
via https://www.sourceinsight.com/documentation/
If you want to impress your reviewers, then use Doxygen.
Doxygen can extract comment & code and genereate cross referenced and indexed HTML pages for documenting your code.
A trick I used long ago is to directly input a Form Feed character into the source code comment. (oops, already mentioned)
In the dos age his was easy. You could hold the ALT key and then type the ascii value of the character you wanted (12 in this case) on the numeric keypad.
For work I once had to find a bug in a badly written function. Lots of loops if / else and other stuff. (Written by somebody else of course). After staring at it for several hours I still got lost in the code and to get some overview of that single function I printed the whole thing on paper and glued the pages together (This was after the dot matrix age). It was 7 or 8 pages.
To Awneil: Do you have a multiple monitor setup? In this age & day it would be silly to work from a single monitor, unless you have a really big one (I still want a 34" 4k monitor for code writing & CAD design). Rotating the monitor also helps a lot. I have 2 24" monitors of a pretty common 1920x1200 resolution, which I can rotate at will. Usually Portrait on the left (for code & web sites) Landscape on the right for my logic analyser. (it's off at the moment). I write my code in Qt Creator and I can get 121 lines of easily readable text with this setup. Added a screenshot. It's only 1048 pixels wide so I still have easy accesisble other windows (file browrser, terminal)  next to it.
(Edit: AvrFreaks scales images, so for looking at readability you have to make sure it's 1:1)
Yes, that's the kind of thing where I find paper, pencil, and highlighters help.
Yes
Agree.
Code won't have heavily nested while / if / else if it's regularly checked for cyclomatic complexity (preferably on every push to master)
awneil wrote:
Yes
But now I want one of these:  https://www.youtube.com/watch?v=...
I, one who destroys hinges frown
Thanks though!
Yes, I think that's been the failure mechanism for most of my past laptops!
