I have to remember to tell that a google of "frequency tripler circuit" could solve your 70-100 MHz problem ;)
(you can make all odd multipliers, so something like 16*5=80 would be a nice one )
Perhaps you have to gain the output.
And I the first ARM7 layout I made, I put the clk to the clk-input direct, it worked fine but made a lot of RF noise, that chip (2138) wanted a AC coupled input!
add: this is a 10MHz crystal osc with 90MHz output:
The only silicon on my bench that beats XMega for raw IO / SRAM speed is FPGA. Not ARM, not PIC32, not STM.
I wonder if that SAM thing would be any good? I might have to try that next.
Likely to be similar.
What MHz versions did you check ?
At some point, sheer MHz has to compensate for the lower efficiency - but higher MHz Cortex etc, (> 120MHz) also tend to come with many more pins, and more digits in the price too...
Returning to the use all pins part of this topic. Some years ago I built this programmer attachment for a Dragon when I needed to program 325 tiny85s in a music boxes. This had the SPI attached SD card reader. It was easier and more reliable to HIV program them by making a PCB board an filing it to the SD thickness and shape. The programmer ran in batch mode and did not even need to be power cycled as the SD card can be hot inserted. There was one line that needed the probe pin. Clip the pin insert the card, program,verify, unclip pin. Rinse repeat. Simple and effective. For use with other AVRs, In SPI mode the programmer can fit into the adapter sleeve.
I see no writes to the MCLKCTRLB mentioned in #145 ?
TopESD/EFT/lightning suppression is ideally at the edges of the PCBA and away from the MCU; that's not the case on small PCBA.
So, the MCU should have some jitter tolerance for its main clock.
TopI have to remember to tell that a google of "frequency tripler circuit" could solve your 70-100 MHz problem ;)
https://www.eeweb.com/extreme-ci...
TopCorrect, I did not write to MCLKCTRLB. as per my understanding of the following...
My understanding is that if you want the prescaler, then you write to PEN and PDIV.
For no prescaler, don't write either.
I didn't read anything about it being enabled on startup, but I will try writing zero and see what happens.
Brad
TopNote that the reset value of MCLKCTRLB selects division by 6.
And also that to change these registers, they have to be unlocked first:
TopThanks, I missed that one.
I also found that this would not work...
Yet this does...
Seems that "4 instruction cycles" actually means "4 clock cycles).
Assuming that the sts write actually happens on cycle #2, then it would be cycle #5 where it occurs... one too slow.
The speed just went up on my pin toggle, and I will measure it when I am back in my lab.
Thanks for the help, it's so much fun decoding a new chip like this.
Brad
TopGood news and bad news regarding the overclocking of the Tiny-1614.
The Bad...
Seems I fooled myself due to the /6 prescaler enabled by default.
It will indeed clock in at 60 MHz, even 80 MHz, but internally only to 36 MHz.
The Good...
36 MHz is still damn fast! Not as good as the Tiny-85, but as good as the Mega-328.
ST also takes half the time (only 1 cycle), and that is the best instruction to be faster!
With ST only taking one cycle, the Tiny-1814 is actually a lot faster than the Tiny-85, even at slower clock speeds.
Most cycles are eaten by ST in video generation and writing Sprites, so this is really good news.
The T-85 did 204 pixels at 40 MHz, but I am now getting 230 Pixels at 36 MHz from the T-1614.
Seems I can get a lot more Sprite bandwidth as well, and will test that soon.
I am going to start a new thread for Quark-1614 soon, and keep this one going for Quark-85.
Have some new Zeners to try and see if I can share Color and Sync without so much bleeding.
Later, and thanks for the help.
Brad
TopQuark-85 now has an extra pin for sound without requiring any HV programming.
Using a common 4.3v Zener (BZX79-C4V3) like this...
This now leaves one free IO for PWM sound output, offering a lot more versatility for sound effects.
I will update the code soon, but here is how this works...
PINS B.0,1,2 are normally floating and pulled up externally.
When it comes time for Sync, B0,1 are set low, and enabled.
When Sync if over, PINS B.0,1,2 are set back to floating.
When it comes time for Color, B.0,1,3 are set to high, but not enabled.
To set Color Bits, DDRB is sent pixel data to toggle individual IO lines.
This setting of DDRB does not disturb the SYnc or Sound PIN.
When the Zener sees the positive voltage, it passes .68V to the Analog Color lines.
The 1K pullup on Sync does not make it past the diode.
Sound PIN B.4 is driven by PWM, mixed as 4 independent channels.
PIN B.5 is used for programming, and B.3 is the clock input.
I am going to leave this one as Quark-85 Demo Kube, and just create multimedia demos on it.
The Tiny 1614 based version Quark-1614 will evolve into a Game System.
Brad
TopIs it LD and ST or only ST
TopAccording to datasheet, not LD. But SBI/CBI are also 1 cycle and these are also important instructions to speed up.
TopThat's a little more as expected. Usually, newer parts reflect better process control, and less margin to typical...
Did you lower the Vcc a little, to check the margin on the 36MHz ? What is Icc at that speed ?
TopNot yet.
I am going to convert the Quark Engine completely, using 36MHz @ 5V, and then see what happens with lower voltage.
As with the Atmega328, 38MHz is the bleeding edge, sometimes working at even 40 MHz, which is why I chose 36 MHz.
So far, the XMega holds the overclock record, all variants reaching 68MHz / 212% overclocking speed.
Next in line is the Tiny-85 and ATmega88, reaching 40 MHz / 200%.
Tiny-1614 seems good at 36 MHz / 180% along with ATmega328.
Brad
TopLikely to be similar.
TopReturning to the use all pins part of this topic. Some years ago I built this programmer attachment for a Dragon when I needed to program 325 tiny85s in a music boxes. This had the SPI attached SD card reader. It was easier and more reliable to HIV program them by making a PCB board an filing it to the SD thickness and shape. The programmer ran in batch mode and did not even need to be power cycled as the SD card can be hot inserted. There was one line that needed the probe pin. Clip the pin insert the card, program,verify, unclip pin. Rinse repeat. Simple and effective. For use with other AVRs, In SPI mode the programmer can fit into the adapter sleeve.
TopMy electronics workbench is now going on vacation until winter.
Seeing as how spring is almost here, my main website now gets my focus.
I shall trade in my soldering iron for a welder for the next 6-8 months.
Might need a few AVRs for the various HomeSteading projects I am doing, but nothing this complex.
Can't imagine counting cycles to auto shut the greenhouse flaps, or trigger the deer scare alarm!
It has been fun... see y'all again when the snow buries me alive in December!
Cheers!
Brad
TopPages
