Declaration of a cstring causes incorrect behavior
11 posts / 0 new
I am puzzled by this issue I have been running into with avr-gcc on an ATMEGA328P. I am using the USART in my project, and wrote a simple function to send strings. When using a character array initialized per-character, ie.
char str[6] = {'H', 'e', 'l', 'l', 'o', '\0'};
the program works perfectly. If, however, I declare the same string in the same line of main as:
char str[6] = "Hello";
the program does not function at all, and it seems to be stuck in a reset loop. Even if I never use the string, and only try to do things like set an output, the device does nothing. To make things more bizarre, when I try to debug the issue in simavr with gdb, the program works as expected; I can even print the string to a serial terminal. Does anyone have any pointers as to why this is happening?
Not without seeing the code!
Recommend you post a small complete project that demo's the problem, use the "<>" code button when you post.
Tell the toolchain used.
For illustrated instructions, see Tip #1
Are you using a different build configuration for the simulator vs the real chip?
Do you have Atmel Studio?
What if you use the Simulator in that?
What if you use on-chip debug?
This string us a stack frame auto?
How are you doing your objcopy?
Good question - but how would the form of the initialisation make a difference?
Unless one was auto and one wasn't - which is where the requested example would come in ...
Take a look at generated code. Sometimes init us LDI/STs and sometimes it is .data _do_copy_data.
My guess is this is an objcopy without "-j .data"
thanatos2996 wrote:
simavr
You mean this: https://github.com/buserror/simavr ?
Sounds interesting:
simavr wrote:
simavr is really made to be the center for emulating your own AVR projects, not just a debugger, but also the emulating the peripherals you will use in your firmware, so you can test and develop offline, and now and then try it on the hardware.
Seems to have "hooks" to allow external integration - which a few posters have asked about recently ...
EDIT
typo
I found the issue, though I don't know how to solve it. Turns out it has noting to do with strings. Looking at the dissassembled file, the functions in my other file are being put before main, starting at 0x00, so it's running the functions in RS232.c before crashing and reseting. How can I specify the reset vector to point to main?
The compile commands:
avr-gcc -DF_CPU=16000000UL -mmcu=atmega328p -DBAUD=9600 -Os -Wall -c -o bar.o bar.c
avr-gcc -DF_CPU=16000000UL -mmcu=atmega328p -DBAUD=9600 -Os -Wall -c -o RS232.o RS232.c
avr-gcc -o bar.elf bar.o RS232.o
avr-objcopy -O ihex -R .eeprom bar.elf bar.hex
I'll add a pastebin with the code shortly.
Actually, it shouldn't point to main(); it should point to the 'C' startup - which will call main() when it's done
Linking without a -mmcu setting is harmful, and is very likely the root of your problems.
Stefan Ernst
That was it. Now it sets up a vector table and everything. Thanks.
