usart strange problem
8 posts / 0 new
Hi everybody,
I'm using ATmega128 UASART0 to send data to my PC.
I've written a small test code, to send data, and it works well ( I receive 0x10 0x01 0x11 on the PC ):
while ( ! (UCSR0A & 0x20) );
UDR0 = 0x10;
UDR0 = 0x01;
UDR0 = 0x11;
But I tryed to do the same but in an other way :
unsigned char ack[] = {0x10, 0x01, 0x11};
for ( i = 0; i < sizeof(ack) ; i++ )
   UDR0 = data[i];
But its doesn't work properly. On my PC, I receive 0x10 0x81 0xC4
Can you help me ?
Yann.
What is data? You mean ack?
   UDR0 = data[i];
should that not be
   UDR0 = ack[i];
you're right, this is (bad copy past :-)
   UDR0 = ack[i];
But it's not working.
Yes I mean ack ;)
I've just found the problem. It was an optimization option.
gcc was configured with -O0 and I changed it to -Os and now its work fine.
Wouldn't think -O0 would cause any problems. If anything, I would think the -Os would...
Does the compiler have an issue with:
instead of:
unsigned char ack[3] = {0x10, 0x01, 0x11};
Clancy _________________ Step 1: RTFM Step 2: RTFF (Forums) Step 3: RTFG (Google) Step 4: Post
Both doesn't work if I leave the -O0 option.
There are no warning at all. The problem wasn't at compiling time, but when the uC send data to me.
