Atmel-ICE not found in Studio 7 but works fine in Studio 6.2?
6 posts / 0 new
As the title says, I had Atmel Studio 6.2 installed for a long time working well with the Atmel-ICE but can not see it at all under Studio 7
This one - http://www.atmel.com/tools/atatm...
My machine is Windows 10 Pro 64-bit Version 1511 Build 10586.545
In Studio 6 Device Programming window I can select the tool and program my board no problem.
I installed Studio 7.0.1417 on the same machine but it does not see the tool at all. I'm not running both versions at the same time.
The Atmel-ICE has firmware version 1.24
In Device Manager I have
- Atmel-ICE Data Gateway 42.0.1.0 (2/02/2017)
- Jungo / atmelwindrvr 12.0.0.0 (9/10/2015)
I guess the Jungo driver is out of date? or not?
12.0.0 the installed one.
C:\Program Files (x86)\Atmel\Studio\Drivers\Jungo\usb64\atmelwindrvr.sys
Not sure what to try next.
Just a quick follow up..  I did try these instructions to manually add the device.
http://www.atmel.com/webdoc/atme...
I removed the old jungo driver and manualy added the path.
It shows three drivers, so I installed all three of them.
- atmelwindrvr : 12.0.0.0 9/10/2015
- WinDriver : 11.5.0.0 26/01/2014
- WinDriver1200 : 12.0.0.0 12/08/2015
I disabled all three to start with and Atmel Studio 6 still works? I'll reboot and see.
...That didn't work....
So I deleted all the Jungo and Atmel drivers from Device Manager.
Rebooted.
Then downloaded and ran Atmel USB Installer
https://gallery.atmel.com/Produc...
Rebooted.
Now I just have Atmel-ICE Data Gateway 1.0.0.0 5/01/2013 and Jungo WinDriver 11.5.0.0 26/01/2014
Still works fine in Atmel 6.2 but not in 7
I did a repair install of Studio 7 with the same online installer I downloaded previously. as-installer-7.0.1417-web.exe
This caused me to check my sanity because when I double checked the latest version of this on the Atmel site the file is called.
as-installer-7.0.1188-web.exe
While it failed with an error 'ARM32 User Account already exists' or something like that, It did fix my problem.
Double checked Studio 7 version after repair and it's still build 1417
Anyway ran Studio 7 Device Programming, can now select the tool and it asked to upgrade Firmware in the device 1.24 -> 1.26. I do that.
Now the Atmel-ICE works in both Studio 6.2 and 7.. Just the way I wanted it.
So this is kind of solved even though I don't really know what happened.
No longer used in Atmel Studio 7.0.1416 and subsequent :
http://atmel-studio.s3-website-us-west-2.amazonaws.com/7.0.1417/as-installer-7.0.1417-readme.pdf
(page 3)
The following changes are done in Atmel Studio 7.0.1416:
• Changed driver to WinUSB for AVR Dragon™, AVRISP mkII, JTAGICE mkII, JTAGICE3, AVR ONE!, STK®600, and QT600
Note:
If you install this version of Atmel Studio in parallel with an older Studio versions or IAR Embedded Workbench® and are using AVR Dragon™, AVRISP mkII, JTAGICE mkII, AVR ONE!, STK®600, or QT600 read
How to downgrade to use older Jungo drivers.
via http://www.microchip.com/development-tools/atmel-studio-7
IIRC, Atmel-ICE has been through WinUSB for quite sometime.
Then will not need Jungo at all.
Oops ... will need Jungo.
Microsoft
MSDN
WinUSB (Winusb.sys)
https://msdn.microsoft.com/en-us/library/vs/alm/ff540196(v=vs.85).aspx
Edits : via, Oops
Cheers - I had similar issue. Studio 7 wouldn't recognise the ICE. Ran the installer to repair Studio 7 and all ok now
