C++ Include Files?
7 posts / 0 new
I have just started using AVR Studio (Ver 6) for C++ programs.
I am having a problem with include files. The files show in the project window but compiler says they don't exist.
What must you do to use include (.h) files with this C++ compiler?
Bob Macklin
Seattle, Wa
Why have you started with v6 ??
v6 was superseded by v7 several years ago!
You use the 'Include Path' to tell the compiler (or, to be pedantic, the preprocessor) where to find include files.
Bob Macklin
Seattle, Wa
Welcome to AVRFreaks Bob.
Atmel Studio, not AVR Studio, is at version 7 now, you should uninstall AS6 and install AS7 instead.
How have you tried to include the .h files?
I am still running WinXP. When I tried version 7 it would not run on XP.
I have my include files (.h) in the same directory as the main program.
Where do I set the path to the include files?
I have been a C++ programmer since 1989. Since 1998 I mostly used Microsoft VC++
I have been programming the Atmel chips in assembly language since about 2005. I previously use version 4 and 5 for assembly.
I recently upgraded to version 6.
Atmel Studio is built on Visual Studio - you should recognise it!
In the Project Proerties > AVR/GNU C++ Compiler > Directories
GOT IT!
Thanks for the help!
Bob Macklin
Seattle, Wa
If the header files are in the same directory as main() they should just be found if you #include "name.h"
