Difference in compile, Larger .hex file
7 posts / 0 new
hey, I'm absolute new with Atmel studio (mine is 6)
in the middle of my way in learning AVR, i found this tutorial specially written for Attiny13.
but when i compiled the code, the hex file was 2.16 KB which reaches maximum 1KB  Flash size of Attiny13.
what is wrong? should i stay rely on mentioned Tutorial or not?
is there any setting or configurable to reducing the size?
Here is the Code provided from that Tutorial:
 * Copyright (c) 2016, Łukasz Marcin Podkalicki <lpodkalicki@gmail.com>
 * ATtiny13/011
 * Control LEDs with IR remote control. Example of monblocking
 * IR signal reader (38kHz, TSOPxxx) and NEC protocol decoder.
 * MCU Settings:
 *  FUSE_L=0x7A
 *  FUSE_H=0xFF
 *  F_CPU=9600000
#include <util/delay.h>
#include <avr/interrupt.h>
#define    LED1_PIN               PB0
#define    LED2_PIN               PB2
#define    LED3_PIN               PB3
#define    LED4_PIN               PB4
#define    IR_IN_PIN              PB1
#define    IR_IN_PORT             PORTB
#define    IR_OCR0A               (122)
#define    LOW                    (0)
#define    HIGH                   (1)
#define    IR_SUCCESS             (0)
#define    IR_ERROR               (1)
#define    IR_EVENT_IDLE          (0)
#define    IR_EVENT_INIT          (1)
#define    IR_EVENT_FINI          (2)
#define    IR_EVENT_PROC          (3)
#define    IR_PROTO_EVENT_INIT    (0)
#define    IR_PROTO_EVENT_DATA    (1)
#define    IR_PROTO_EVENT_FINI    (2)
#define    IR_PROTO_EVENT_HOOK    (3)
volatile uint16_t IR_timeout = 0;
volatile uint16_t IR_counter = 0;
volatile uint32_t IR_rawdata = 0;
uint8_t IR_event = 0;
uint8_t IR_proto_event = 0;
uint8_t IR_index = 0;
uint32_t IR_data = 0;
static void
IR_init()
    DDRB &= ~_BV(IR_IN_PIN); // set IR IN pin as INPUT
    PORTB &= ~_BV(IR_IN_PIN); // set LOW level to IR IN pin
    TCCR0A |= _BV(WGM01); // set timer counter mode to CTC
    TCCR0B |= _BV(CS00); // set prescaler to 1
    TIMSK0 |= _BV(OCIE0A); // enable Timer COMPA interrupt
    OCR0A = IR_OCR0A; // set OCR0n to get ~38.222kHz timer frequency
    GIMSK |= _BV(INT0); // enable INT0 interrupt handler
    MCUCR &= ~_BV(ISC01); // trigger INTO interrupt on raising
    MCUCR |= _BV(ISC00); // and falling edge
    sei(); // enable global interrupts
static int8_t
IR_NEC_process(uint16_t counter, uint8_t value)
    int8_t retval = IR_ERROR;
    switch(IR_proto_event) {
    case IR_PROTO_EVENT_INIT:
        /* expecting a space */
        if (value == HIGH) {
            if (counter > 330 && counter < 360) {
                /* a 4.5ms space for regular transmition of NEC Code;
                 counter => 0.0045/(1.0/38222.0) * 2 = 344 (+/- 15) */
                IR_proto_event = IR_PROTO_EVENT_DATA;
                IR_data = IR_index = 0;
                retval = IR_SUCCESS;
            } else if (counter > 155 && counter < 185) {
                /* a 2.25ms space for NEC Code repeat;
                 counter => 0.00225/(1.0/38222.0) * 2 = 172 (+/- 15) */
                IR_proto_event = IR_PROTO_EVENT_FINI;
        break;
    case IR_PROTO_EVENT_DATA:
        /* Reading 4 octets (32bits) of data:
         1) the 8-bit address for the receiving device
         2) the 8-bit logical inverse of the address
         3) the 8-bit command
         4) the 8-bit logical inverse of the command
        Logical '0' – a 562.5µs pulse burst followed by a 562.5µs
         (<90 IR counter cycles) space, with a total transmit time of 1.125ms
        Logical '1' – a 562.5µs pulse burst followed by a 1.6875ms
         (>=90 IR counter cycles) space, with a total transmit time of 2.25ms */
        if (IR_index < 32) {
                IR_data |= ((uint32_t)((counter < 90) ? 0 : 1) << IR_index++);
                        if (IR_index == 32) {
                    IR_proto_event = IR_PROTO_EVENT_HOOK;
        break;
    case IR_PROTO_EVENT_HOOK:
        /* expecting a final 562.5µs pulse burst to
         signify the end of message transmission */
        if (value == LOW) {
        break;
    case IR_PROTO_EVENT_FINI:
        /* copying data to volatile variable; raw data is ready */
        IR_rawdata = IR_data;
        break;
    default:
        break;
    return retval;
static void
IR_process()
    uint8_t value;
    uint16_t counter;
    /* load IR counter value to local variable, then reset counter */
    counter = IR_counter;
    IR_counter = 0;
    /* read IR_IN_PIN digital value
     (NOTE: logical inverse value = value ^ 1 due to sensor used) */
    value = (PINB & (1 << IR_IN_PIN)) > 0 ? LOW : HIGH;
    switch(IR_event) {
    case IR_EVENT_IDLE:
        /* awaiting for an initial signal */
            IR_event = IR_EVENT_INIT;
        break;
    case IR_EVENT_INIT:
        /* consume leading pulse burst */
        if (value == LOW) {
            if (counter > 655 && counter < 815) {
                /* a 9ms leading pulse burst, NEC Infrared Transmission Protocol detected,
                counter = 0.009/(1.0/38222.) * 2 = 343.998 * 2 = 686 (+/- 30) */
                IR_event = IR_EVENT_PROC;
                IR_proto_event = IR_PROTO_EVENT_INIT;
                IR_timeout = 7400;
            } else {
                IR_event = IR_EVENT_FINI;
        } else {
        break;
    case IR_EVENT_PROC:
        /* read and decode NEC Protocol data */
        if (IR_NEC_process(counter, value))
        break;
    case IR_EVENT_FINI:
        /* clear timeout and set idle mode */
        IR_event = IR_EVENT_IDLE;
        IR_timeout = 0;
        break;
    default:
        break;
static int8_t
IR_read(uint8_t *address, uint8_t *command)
    if (!IR_rawdata)
        return IR_ERROR;
    *address = IR_rawdata;
    *command = IR_rawdata >> 16;
    IR_rawdata = 0;
    return IR_SUCCESS;
ISR(INT0_vect)
    IR_process();
ISR(TIM0_COMPA_vect)
    /* When transmitting or receiving remote control codes using
     the NEC IR transmission protocol, the communications performs
     optimally when the carrier frequency (used for modulation/demodulation)
     is set to 38.222kHz. */
    if (IR_counter++ > 10000)
    if (IR_timeout && --IR_timeout == 0)
int
main(void)
    uint8_t addr, cmd;
    /* setup */
    DDRB |= _BV(LED1_PIN)|_BV(LED2_PIN)|_BV(LED3_PIN)|_BV(LED4_PIN);
    IR_init();
    /* loop */
    while (1) {
        if (IR_read(&addr, &cmd) == IR_SUCCESS) {
            if (addr != 0x01)
                continue;
            switch(cmd) {
            case 0x01:
                /* turn all LEDs off */
                PORTB &= ~(_BV(LED1_PIN)|_BV(LED2_PIN)|_BV(LED3_PIN)|_BV(LED4_PIN));
                break;
            case 0x00:
                PORTB ^= _BV(LED1_PIN); // toggle LED1
                break;
            case 0x07:
                PORTB ^= _BV(LED2_PIN); // toggle LED2
                break;
            case 0x06:
                PORTB ^= _BV(LED3_PIN); // toggle LED3
                break;
            case 0x04:
                PORTB ^= _BV(LED4_PIN); // toggle LED4
                break;
            default:
                break;
tnx:)
I'm new, please help me.
payam_sbr wrote:
...but when i compiled the code, the hex file was 2.16 KB which reaches maximum 1KB  Flash size of Attiny13.
what is wrong?
Nothing is wrong. A .hex file is an ACSII representation of the data to be programmed into a chip. It will be AT LEAST twice as large as the binary equivalent as each program byte is represented by two ASCII characters, ie two bytes, in the .hex file.
As an example, the code I am working on at the moment occupies 20906 bytes out of my 32k of code memory and yet my .hex file is 58816 bytes in size.
A .hex file will be at least 2.6875 times larger than the code size.
When you compile the program in Atmel Studio, you should see the actual program and data usage in the output.
For example:
	Task "RunOutputFileVerifyTask"
		Program Memory Usage 	:	812 bytes   79.3 % Full
		Data Memory Usage 	:	15 bytes   23.4 % Full
(Of course the Data Usage does not include stack usage...)
Edit: added "in Atmel Studio"
David (aka frog_jr)
Good news!
thank you, but one more critical question stay for me,
is there any way to validate code size for chips? whether inside Atmel Studio or via an external tool
shall i trust divided value by 2 every time?
frog_jr wrote:
When you compile the program, you should see the actual program and data usage in the output.
For example:
ops, thanks a lot, i post previous reply before seeing your Reply.
I normally reckon on x2.6 to about x3 for Hex size but it would be very unwsie to measure size using the size of the HEX. Either run avr-size on it or avr-objcopy it from Hex to Bin and then measure the BIN size.
