SAMR21 - BitCloud I2C Problems
4 posts / 0 new
Normally I used the ATmega256rfr2 Chip, recently I bought the SAMR21 Xplained Pro to test out the chip.
I could nearly user every function I normally need, like generate network, ADC, UART and so on.
But the I2C seems to crash, when using the predefined BitCloud functions.
Did anyone else have this problem and has a solution?
As soon as I am trying to read or write something with the I2C Descriptor the board crashes and has to be reset.
Any suggestions or remarks?
I2C will tell you when something goes wrong if you use the return status of the functions and test for unexpected return values.
Click Link: Get Free Stock: Retire early!
Hey Jim,
thanks for the answer!
Yes I know and I am using them. As you can see below I always check the return value of the I2C function, I do the same with the Read and Write functions.
			if(-1 == HAL_OpenI2cPacket(&i2cdescriptor)) {
				appWriteDataToUsart((uint8_t*)"I2C_OPEN_FAIL\n\r", sizeof("I2C_OPEN_FAIL\n\r")-1);
				appstate = APP_INIT_LM73_STATE;
				SYS_PostTask(APL_TASK_ID);
			} else
				appWriteDataToUsart((uint8_t*)"I2C_OPEN\n\r", sizeof("I2C_OPEN\n\r")-1);
But as soon as I am trying to use the Read function of the I2C-Descriptor it literally crashes.
Does nobody have the same problems as me?
What do you mean by that?
  • It restarts from the reset vector?
  • It hangs?
  • You get a Hard Fault?
  • Other?
Note that this "ASF" forum is stupidly buried in the AVR section; so not immediately visible from the Cortex-specific forums - where the Cortex people are.
<rolls-eyes>
Hence you may be better in the specific Cortex-M forum - especially if you're getting into debugging Hard Faults...
Also, BitCloud topics are probaly more appropriate in the IoT section ...
A moderator would be able to move it.
