Detecting I2C LCD address automatically
4 posts / 0 new
Based on part number of PCF8574 , there are two default addresses possible for PCF8574 based serial module such as 0x7E or 0x4E. So I thought of detecting the address automatically. But the code I wrote below is not working. In both type of LCD serial modules, i2CTest() returns 0. However addresses 0x7E and 0x4E are correct and both the modules work if I set PCF8574_ADDR to respective address. I used Peter Fleury' I2C library and added small wrapper function i2CTest() to check the device address. I did not add complete code here and if needed I can add after some changes.
uint8_t PCF8574_ADDR = 0x7E;
void initializeLCD(void)
    	//After reset, data sheet suggests some delay.
	_delay_mS(2);
	In case of PCF8574, there could be two possible addresses by default.
	We are considering 0x7E as default address.
	In case we get NACK, we will use other address.
    if(!i2CTest(PCF8574_ADDR))
        PCF8574_ADDR=0x4E;
	i2c_start(PCF8574_ADDR + I2C_WRITE);
	// rest of the initialization code goes here.
uint8_t i2CTest(uint8_t address)
    uint8_t status=0;
    if(!i2c_start(address))
        i2c_readNak();
        status=1;
    i2c_stop();
    return(status);
* Changed "Serial" in the thread title to "I2C". Moderator *
Rather then doing a readNAK(), I would just do a start() stop() and save / test the status of the start, expecting the correct address to ACK.
Click Link: Get Free Stock: Retire early!
In this thread:
David mentions a utility that might do what you are looking to do.  Will also give you the pin connections between the PCF and the LCD.
Another Jim
Why is there a "Highway to Hell" and only a "Stairway to Heaven"? A prediction of the expected traffic load?  - Lee "theusch"
First: Can you change the title?
"Serial" is not a good alias for " I2C ".
Second:
In a pc there are a bunch of internal I2C busses ( & busses forked from I2C).
In linux there is a package called "i2c-tools" to send and read data from I2C busses from the command line.
There is also a function which tries to sniff all I2C addresses and generates a list of the hardware it thinks it found on the bus.
You might want to look into that code.
Paul van der Hoeven.
http://www.hoevendesign.com
