I'm afraid of static discharges during development cycle could damage my LCD and/or AVR. In any case I'll assemble my project on PCB and test for any glitches. Also I think that choke on the transformer low-voltage output could help against current spikes (I suggest that voltage spikes are already rejected with my capacitors) but I not sure what the value for choke is pretty good. Also I wonder if there any math behind choosing values for filtering chokes (I know some for caps but not for inductors)
Anyway thank you all for your advises and suggestions. I'll test my device in real environment and report about the result
Viktor Drobot
A.N. Belozersky Research Institute Of Physico-Chemical Biology MSU
A transformer has inter-winding capacitance. Nasties from the mains side couple through this capacitance and travel through your circuit until they find ground. Putting a choke in series with the ac secondary wont do much - especially with the non sinusoidal current through the rectifier.
When in the dark remember-the future looks brighter than ever. I look forward to being able to predict the future!
TopThat would have to take the striped apron award of the week!
Mmmmm! Molded mud resistors. Where’s the tag strip and the 12AX7’s?
TopA Google for "striped apron award" had only nine results... one of them is this thread.
I get the gist, but what does it mean, really?
"Good judgement comes from experience. Experience comes from bad judgement."
"Fast. Cheap. Good. Pick two."
TopThere! Don't you see them?
They are right next to the Fahnestock clips!
Wow! Cool project!
TopA buthcer's job.
TopGot it! ;-)
TopIt's been a long time since I used any of those, at least 2 years.
TopThose carbon resistors take me back to the days of the RadioShack pbox projects.
TopI'm afraid of static discharges during development cycle could damage my LCD and/or AVR. In any case I'll assemble my project on PCB and test for any glitches. Also I think that choke on the transformer low-voltage output could help against current spikes (I suggest that voltage spikes are already rejected with my capacitors) but I not sure what the value for choke is pretty good. Also I wonder if there any math behind choosing values for filtering chokes (I know some for caps but not for inductors)
Viktor Drobot
TopA transformer has inter-winding capacitance. Nasties from the mains side couple through this capacitance and travel through your circuit until they find ground. Putting a choke in series with the ac secondary wont do much - especially with the non sinusoidal current through the rectifier.
TopSo they are necessary mainly for switching PSUs, aren't they?
Viktor Drobot
TopSwitching psus are a different application. They usually have a common mode choke on the input side to mainly stop them radiating.
TopPages
