atmega 32 with hc-05
28 posts / 0 new
i don't understand why my avr does not receive anything although my code runs on proteus good , i send characters from mobile app to hc-05 and then check these characters and do action base on them but avr doesn't respond at all , here is the code
#define F_CPU 16000000
#include <util/delay.h>
void forward()
    PORTA=0b00000101;
void backward()
    PORTA=0b00001010;
void right()
    PORTA=0b00001001;
void left()
    PORTA=0b00000110;
void stop()
    PORTA=0;
    DDRA = 0b00001111;
    uint16_t UBRRValue = 103;
    UBRRL = (uint8_t)UBRRValue;
    UBRRH = (uint8_t)(UBRRValue>>8);
    UCSRB = (1<<RXEN)|(1<<TXEN);
    UCSRC|= (3<<UCSZ0);
    while (1)
    while(!(UCSRA&(1<<RXC)));
    switch(UDR)
            case 'W':forward(); break;
        case 'S': backward(); break;
        case 'D':right(); break;
        case'A': left();  break;
        default : stop(); break;
return 0;
should i do something to hc-05 or add some code?
* Posted in the wrong forum. *
So how do you know that your AVR does not receive anything?
How is your Proteus connected to the HC-05 ?
Again, how do you know that the characters actually reach the AVR?
How do you know that the AVR "doesn't respond at all" ?
Debugging Serial Comms:
first when avr receives the character i send, dc motor should rotate by using h bridge but there is nothing happens
second in proteus i use virtual terminal to send characters and the avr responds correctly
third i don't know whether the characters reach avr or not but as i said the dc motor doesn't rotate
So don't you think that's the first thing you need to check?!
If nothing reaches the AVR, then the AVR will obviously do nothing - won't it?!
Similarly if what reaches the AVR is junk.
So how do you know that what you're sending is actually the same as what the HC-05 sends?
What happens if you use a terminal to send characters to the real AVR?
Only if the character is 'W' or 'S' or 'D' or 'A'
From Post#1:
How do you know that the uC is running at 16MHz?
Did you change the fuses in the uC?
If so, to what values?
To verify that the uC is running at 16MHz, write a test program
that blinks a led once per second and then time the blinks.
(This is common practice for every new project.)
So how to check that avr receive something , how can i do that?
And also how can i use terminal to send characters to real avr?
I use 16mhz crystal capacitor but i didn't change anything in the fuses , should i do that ? And if so what should i do?
Did you not look at the links in #2 - under, "Debugging Serial Comms" ?
Oh i didn't see that , i will look at them and see , thanks!!
I Don't understand how can i implement this chart using tera term and i use hc 05 not esp , is this gonna work?
Go on! It's just a really simple block diagram.
Did you read the description on that page?
At the top, you have your AVR connected to your HC-05 (was "ESP" in the original):
|    TX+--------------------------------------->+RX     |
|AVR   |                                        |  HC-05|
|    RX+<---------------------------------------+TX     |
You want to be able to monitor what is being sent by the AVR from its TX to the HC-05's RX;
You also want to be able to monitor what is being sent by the HC-05 from its TX to the AVR's RX.
So you add connections to monitor those lines:
|    TX+-------+------------------------------->+RX     |
|AVR   |       |                                |   ESP |
|    RX+<--------------------------+------------+TX     |
               V                   V
            Monitor             Monitor
            AVR TX              HC-05 TX
           to HC-05              to AVR
Those lines are UART signals at logic levels - 3V or 5V (or whatever - depending on what voltage your system is running at).
To connect them to a PC, you need UART-to-USB converters - to plug into the PC's USB ports:
|AVR   |       |                                |   ESP |
               V                   V
          |    RX   TX    |   |    RX   TX    |
          | USB-to-Serial |   | USB-to-Serial |
          |       1       |   |       2       |
               USB|                   |USB
                  V                   V
          |   TeraTerm            TeraTerm    |
          |   Instance            Instance    |
          |       1                   2       |
          |                 PC                |
The UART-to-USB converters each appear as a COM port on the PC - so you can connect a terminal app to each.
Thus one terminal will show you what is being sent by the AVR from its TX to the HC-05's RX;
The other terminal will show you what is being sent by the HC-05 from its TX to the AVR's RX.
The use of USB-to-UART converters has been discussed at length recently; eg,
https://www.avrfreaks.net/forum/connecting-atmega-notebook
https://www.avrfreaks.net/forum/mcu-usb-and-c-gui
Do you mean by(hc 05 sends to avr) that what i send from mobile app to hc 05 and then it sends it to avr?
Also i don't have uart to usb converter , is there another way to debug serial communication ?
Can i do that using usbasp ?
And also when i know that nothing reaches avr , what will i do then?
Fill in your member profile with your location, there may be a freak near by that can loan you a USB/TTL serial adapter, although they are very cheap, you should have one or more.
Keys to wealth:
Lets go Brandon!
By "16mhz crystal capacitor" I'm guessing crystal and capacitors.
Yes, if you want to use a crystal with the avr, you need to change the fuses.
From the ATmega32 datasheet (document 2503Q–AVR–02/11):
The device is shipped with CKSEL = “0001” and SUT = “10”.
The default clock source setting is therefore the 1MHz Internal RC Oscillator
with longest startup time.
You can change the fuses using your ISP programmer.
You can determine the proper fuse values using the online
Engbedded Atmel AVR Fuse Calculator (LINK).
Be careful in changing the fuses since it is possible to
"Brick" the uC if you use the wrong values.
("Brick": a condition where the uC doesn't work and won't
  respond to the ISP programmer.)
Edit:
While you're changing the fuses and since you are using an ISP programmer,
disable the  JTAG Interface which is enabled on new chips (default condition).
Below is an example of fuse settings for ATmega32 with 16MHz crystal:
Not really.
The AVR neither knows nor cares where the data actually originates - all it sees is bytes arrving at its UART input.
You need to see exactly what those bytes are.
Then you will need to get some.
The linked threads show where you can obtain them very cheaply.
Not without investing significantly more money in more advanced test gear.
This really is the cheapest, most basic approach to it!
And also when (sic) i know that nothing reaches avr , what will i do then?
You mean, "if" ?
If that is the case, then you will have to find out why nothing is reaching the AVR.
It does seem that you are tackling a project which is rather beyond your capabilities here.
Perhaps you should take a few steps back to the basics:
So now i will get usb/ttl and connect it with the line that goes from hc 05 tx to avr rx and open tera trim and send to hc 05 from my app so what next?
Do not get just one!
Get at least two.
In general, you need to be able to see both what is being sent and what is being received.
Actually, before you do anything with the AVR, you need to just look at the HC-05 - is it actually sending what you expect?
Note that the name is TeraTerm.
EDIT
When you get your USB-to-TTL (aka USB-to-UART) converters, be sure that they are for the appropriate voltage - 3V or 5V
Preferably, get ones that work with both.
Debugging is a key skill in any form of development - hardware, software, whatever.
You really need to learn how to think about a problem, analyse what's going on, and come up with solutions.
The key questions to ask when debugging are:
  1. What should be happening?
  2. What actually is happening?
  3. How can I explain the difference?
Once you have explained the difference between what should be happening and what actually is happening - you know what to fix to get the desired behaviour!
Note that a common reason why what should be happening is different from what actually is happening is that there is a mistake in the code, on in the hardware design; or some other false assumption about the system.
So always check your assumptions!
Also check your expectations: If your expectation of what should happen is incorrect - then it won't happen!
See also: https://www.avrfreaks.net/commen...
Some general articles on debugging:
http://www.8052mcu.com/faqs/120313
http://www.ganssle.com/articles/...
https://www.bbc.co.uk/bitesize/guides/zgmpr82/revision/6
#HowToDebug
EDIT
Added expectations.
EDIT 2
Changed 8052.com link to 8052mcu.com - see http://www.8052mcu.com/forum/rea... for details
EDIT 3
A key consideration of your design from the outset should be, "how will I test & debug this?"
See this thread for a load of suggestions on "Design For Debug":
#DesignForDebug #DesignForTest
EDIT 4
For specific help on how to use the debug facilities in  Atmel  Microchip Studio, see the videos linked on the product page:
https://www.microchip.com/en-us/development-tools-tools-and-software/microchip-studio-for-avr-and-sam-devices
See also:
Debugging 1: Break Points, Stepping, and Call Stack
Debugging 2: Conditional- and Action-Breakpoints
Debugging 3: I/O View Memory View and Watch
Thanks man , i really appreciate your help and i'll try all what you told me to do , thanks again!
While you're waiting for the converters to arrive, you could think about the possible differences between running in a simulator, and running in real hardware ...
I use usbasp not isp programmer , is there somoething will change?
Your question is vague and does not make much sense, can you explain what you mean?
Also note that a USBASP is an ISP programmer.
Indeed.
I can't see that the question has anything to do with any part of the discussion in this thread.
If it's a separate question, then start a separate thread.
No i just want to check that my fuses is well adjusted , maybe this is the problem , you understand me?
Well, in a pinch you can use a scope, though often not as convenient...send something like 0x55 which has alternating 0101010101 pattern, or something else easy to spot.  Some better/newer scopes have decoding built in, a great help.  A logic analyzer works even better, since it is more suited for such work.  The scope is the best to really see noise, glitches, etc & to perhaps determine what prevents the terminal from working.  When things are running smoothly, the terminal is best to see what is going back & forth & the responses.
A few years ago, I programmed up a two chan serial monitor that combined & caps-coded the streams into one output to make it somewhat easier to track sends & replies:  HELLOyesMOT?stoVOLTS?pped12.6vVALrVEpmstONall
You asked:
Perfectly, but how would we know what post you are referencing with the question you posed?  Magic?  A crystal ball?  Get in the habit of quoting a little bit of the post that you are responding to, it will help us understand you even better! smiley
So now we can assume that you were asking Chuck99 that question, yes?  His posts are the only posts that referred to fuses.
You will need to use avrdude, or avrdudess, to read the fuse values from the chip.  Then compare them to the values shown for your chip at the Engbedded Atmel AVR Fuse Calculator (LINK).
If the fuse values you read from the chip are different than the fuse values shown at the Enbedded fuse calculator,  you can enter the chip fuse values into the calculator to see what features the chip fuse values have set.
EDIT: Or you can use a scope as avrcandies wrote above.
As larryvc stated, the USBASP is an ISP programmer.
What software are you using with the USBASP to program the ATmega32?
amr_pk in Post#7 wrote:
I use 16mhz crystal capacitor but i didn't change anything in the fuses ...
If the ATmega32 is new, then it is running at 1MHz not 16MHz.
If this is the case then the uC is running at 600 Baud not 9600 Baud.
In Post#5 I mentioned blinking a LED to test the uC clock frequency.
If you have a LED (and resistor), please do that - it is simple, fast,
and will tell you if the uC fuses need to be changed.
Here is a program to blink a LED.
int main(void) {
   // blink LED once per second
   while (1) {
      // insert code here to switch LED on
       _delay_ms (150);
      // insert code here to switch LED off
       _delay_ms (850);
