ATmega328p ADC to PWM
84 posts / 0 new
I use an ATmega328p Xplained mini board with a potentiometer at the ADC5 input. PWM off is PB1 (OC1A).
source snippet;
#define F_CPU    16000000UL
#include <avr/interrupt.h>
double dutyCycle;
    DDRB = (1 << PORTB1);
    TCCR1A |= (1 << COM1A1) | (1 << COM1A0) | (1 << WGM11); // fast PWM mode 14 en geinverteerd, set OC1A/OC1B on compare match
       TCCR1B |= (1<<WGM13) | (1 << WGM12) | (1 << CS11); // delen door 8
       ICR1 = 50; // Frequentie
    setupADC();
    sei();
void setupADC()
    ADMUX = (1 << REFS0) | (1 << MUX0) | (1 << MUX2);
    ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS0) | (1 << ADPS1);// | (1 << ADPS2); // 128 prescaler
    DIDR0 = (1 << ADC5D);
    startConversion();
void startConversion()
    ADCSRA |= (1 << ADSC); // ADSC is start conversie
ISR(TIMER1_OVF_vect)
    OCR1A = dutyCycle;
ISR(ADC_vect)
    dutyCycle = ADC;
    startConversion();
With this source I'll get a constant signal as you can see in the picture, the position of the potentiometer does not matter.
Does anyone know how I can adjust the source so that I can use the potentiometer to control the duty cula of e.g. ~ 3% to 98%?
Be_logic wrote:
double dutyCycle;
On quick glance, I see two problems, dutyCycle does not need to be double and it should be volatile...
I would change the definition to:
volatile uint16_t dutyCycle;
Edit: also you will need to scale dutyCycle to the period of the timer.
David
You've also set the ADC clock to 1 MHz, which is too fast for 10-bit results.  You'll get about 8-bit results (top 8 bits good, bottom 2 bits noise).  This is fine since you're only using about 5.7 bits with your top value of 50 (timer resolution of 51).
That resolution will give you a PWM frequency of about 314 kHz (assuming the m328p is in fact running at 16 MHz).  Is that what you're looking for?
dutyCycle ... should be volatile...
Yup.
Yup.
Not a 'problem' per se, but definitely sub-optimal ;-)
Can you show me what to adjust in the source because it is not entirely clear to me.
I would like to be able to arrange the duty cycle of ~ 3-98%.
Nobody is going to do your homework for you ;-)
You've been given clear feedback on three points:
  1. dutyCycle must be declared volatile
  2. you must scale dutyCycle before writing it to the OCR1A
  3. dutyCycle need not be declared as double
Which of these is not entirely clear to you?
You've also been asked if a PWM frequency of 314 kHz is what you wanted.  Is it?
Hi, I declared dutyCycle as volatile in the source and the clock frequency for the Xplained Mini board at 8 MHz, but could give me hints to scale dutyCycle before writing it to the OCR1A?
I do not need a certain frequency for my project, but I want to be able to arrange the duty cycle between ~ 3 and 98%.
Can you help me with that?
#define F_CPU    8000000UL
    setupADC();
    sei();
void setupADC()
    startConversion();
    OCR1A = dutyCycle;
ISR(ADC_vect)
    dutyCycle = ADC;
    startConversion();
This has already been mentioned but the ADC reading is going to be 0..1023 so you cannot just:
    OCR1A = dutyCycle;
because the range of active values for OCR1A is not just 0..1023 so you need to scale one to the other.
Let's say that OCR1A takes the entire 0..65535 range then you would need to scale up the ADC value 65536/1024 is 64 so in that case you would need:
    OCR1A = dutyCycle * 64;
but if the OCR1A range is different (if you used a mode where TOP was not 65536) then you would need to work out how to scale one to the other.
Of course you could change the counting of the timer so it only counts form 0..1023 for its complete range but if you do that then you change the PWM frequency.
Arduino has a really nice "MAP" function that is useful for scaling one range to another:
ex. map( 0, 1023, 3, 98);    // maps adc range 0-1023 to pwm range 3-98
Source code for this function is easy to find using google.
Keys to wealth:
Lets go Brandon!
Hi Jim, shure thats a nice function but I'm using Atmel Studio 7.
I used OCR1A = dutyCycle * 64; in the source but I still have a constant duty cycle of ~98% so I can't adjust it with the potmeter.
Could I use OCR1AL en OCR1AH for using 16 bits?
this
So, Arduino code is GCC, what's the problem?
long map(long x, long in_min, long in_max, long out_min, long out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
edit: added function c code
Keys to wealth:
Lets go Brandon!
LOL -- while we can see that OP doesn't have a good grasp of the situation, from time-to-time over the years I've chosen fixed-TOP 8-/9-/10-bit PWM in production apps.  It eliminates picking a TOP register and in some cases makes for a trivial yet useful transfer function.
Your pulse width is determined by the Input Compare 1 register, not the TimerCounter 1 register.   The pulse width is never modulated: it is always 50/256 percent because ICR1 is set to 50 and never changed.
Err no...
He appears to be using mode 14. So ICR1 sets TOP - that is the PWM frequency, not the duty cycle. In mode14 OCR1A sets the duty cycle of the pulse on OC1A and OCR1B sets the duty cycle of the pulse on OC1B. So to vary the frequency (and also the couting range of the timer) he should vary ICR1 and to modulate the pulses he should change OCR1A / OCR1B.
You do however highlight the fact that he sets:
So setting OCR1A values 0..1023 is not going to work as the majority of the range is beyond the end of the timer's counting range. So he actually needs to map 0..1023 from the ADC to 0..49 that the counter uses. That would seem to involve a division by 20.48. Wonder why he chose to set ICR1 to just 50 ?? Sure it's a very high PWM frequency but why? Anyway he needs:
   OCR1A = dutyCycle / 20.48;
as things stand at present. But life would be much simpler with:
    ICR1 = 1024; // Give timer same counting range as ADC readings for 1:1 mapping
in that case
   OCR1A = dutyCycle;
really could be used.
clawson wrote:
Err no...
Err, yes...timer1's input capture register is used as TOP.  Isn't that what was said?
Oh, I see now  -- "compare" versus "capture"?  I guess I kind of read over that, as I grasped Simonetta's intent.
I guess that depends on what we mean by "pulse width". Does that mean the width of the "active bit" (ie the "modulated" bit - the actual "pulse") or does it mean the overall width (ie the complete period of one cycle). I read it as the former.
Thanks in advance for your help because I have modified the source according to Simonetta but I now get a constant PWM signal with only other values, see the attached jpg.
I still can not change the PWM signal with the potentiometer.
Showing your actual code (as revised) will help us help you...
David
Here is the revised code;
    setupADC();
    sei();
void setupADC()
    startConversion();
    OCR1A = dutyCycle;
ISR(ADC_vect)
    dutyCycle = ADC;
    startConversion();
As these things go, the code looks OK at a first glance...
1)  Learn how to use the Code tages <> on the formatting toolbar to preserve formatting
2)  ...the below should be 1023 not 1024 but won't affect operation much
3)  From your attached .JPG we see a PWM frequency of about 2kHz.  Does that make sense with your setup?  Which pin of the AVR are you actually probing with Channel 2 of your logic analyzer?
4)  Show the connections to your potentiometer.  Which AVR pin is the wiper connected to?  When you probe right at that pin, what Voltage do you see?  Does it change when you turn the pot?
5)  You are getting a runt PWM duty cycle, so I'm guessing ADC counts of zero.  So now we need to ask about AVcc and AGnd connections, and the level on those pins.
5a)  Now we need to ask about connections and the level on the AREF pin.
Discussion on the above:  Are you sure your AVR is running at 8MHz?  The PWM period suggests 16MHz to me, which is the Arduino frequency, right?
6)  In TIMSK1 you need to enable the overflow interrupt...
Still waiting:
But that's not good enough.  Is a 1 Hz signal alright?  What about a 31.25 kHz signal?  Or an 80 kHz signal?  How about 0.0001 Hz?
"I want to get from New York City to Los Angeles.  It doesn't matter how long it takes."
Ok, if you walk 8 hours a day, 5 days a week, starting now, you'll get there in time for International Youth Day in August.   Is that OK?
You must decide what range of frequencies will be suitable for your needs.
And you are still clocking the ADC too fast (as joeymorin pointed out in post #3). It needs to run between 50 and 200kHz for 10-bit resolution.
If F_CPU is actually 8MHz then you need set ADPSn to divide by 64 (8MHz/64 = 125kHz).
If F_CPU is 16MHz, then ADPSn should divide by 128.
David
I have added TIMSK1 = TOIE1.
I use a ATMEL ATmega328p Xplained Mini board wich is just like an UNO, also the connections.
@3) frequency is not important and my logic analyzer is connected to PB1 (OC1A)
@4) the wiper of the potentiometer is connected to PC5 (AD05) and has a variation 0.65 V to 2V
@5) Aref=5Vdc
@5a) according to an instructor on "Microchip Makes" (youtube) the ATmega328p on the Xplained board runs on 8MHz
So a frequency of 0 Hz is OK?
C'mon.  Pick a range of suitable frequencies.  Or ask your professor to pick one for you.  Everything else depends on that range.
Ok, lets say frequency between 30 and 150 kHz? Is that alright?
So, did it work?
Show that code.  did you mean TIMSK1 = (1<<TOIE1);"
30 Hz?  Or 30 kHz?
e.g. ~ 3% to 98%
With what degree of precision?  That is, how fine a step size do you need?  Is 5% per step sufficient?:
  • 3%
  • 8%
  • 13%
  • 88%
  • 93%
  • 98%
Or do you need 1%?  Better than 1%?
3% and 98% seem fairly arbitrary and specific.  Is this to control a specific device?  Where do these numbers come from?
Of course I placed TIMSK1 = (1<<TOIE1); in the source but I still have a fixed signal.
I mean the frequency range from 30kHz to 150kHz and I wil use it using a sensor (variable resistor) and after PWM, by means of a filter I will have a variable DC voltage.
I would like the smallest possible precision with the given values and possibilities with this WGM-mode.
Hopefully you understand my English.......
Bert
With your code in #19 above, you've set ICR1 to 1024.  This sets a resolution of 1025, not 1024.  The register is 0 based, so for 1024 steps you want to set it to 1023.
In any event, with that many steps, and with a prescaler of 8 as you've done, the PWM frequency will be:
FPWM = FCPU / PRESCALER / STEPS
     = 8000000 / 8 / 1024
     = 976.5625 Hz
That falls outside your range of 30 kHz to 150 kHz.  You'll have to do something else.
Statements which include 'as ___ as possible' are not especially helpful to an engineer.  You must state the constraints of your problem in a way which can be quantified.
I would submit that you don't need nearly as small a step size as you think you do.  There's a limit to how accurately your finger can adjust a rotary pot, a linear pot, or even a 20-turn trim pot.  As a guess, I would discard your 'smallest possible' and simply try the full 8-bits provided by an 8-bit timer, i.e. 256 steps.  If that turns out not to be enough, then you'll have to re-specify the requirements.
Let's try an 8-bit timer doing Fast PWM with a full 256 steps, and a prescaler of 1.
     = 8000000 / 1 / 256
     = 31,250 Hz
That falls within your stated range of 30 kHz to 150 kHz.
With Fast PWM, you'll have the following duty cycles available:
  •   1/256
  •   2/256
  •   3/256
  •   4/256
  •   5/256
  •   6/256
  •   7/256
  •   8/256
  •   9/256
  • 248/256
  • 249/256
  • 250/256
  • 251/256
  • 252/256
  • 253/256
  • 254/256
  • 255/256
  • 256/256
As percentages:
  • OCRnx  PERCENT
  •   0:   0.39%
  •   1:   0.78%
  •   2:   1.17%
  •   3:   1.56%
  •   4:   1.95%
  •   5:   2.34%
  •   6:   2.73%
  •   7:   3.13%
  •   8:   3.52%
  • 247:  96.88%
  • 248:  97.27%
  • 249:  97.66%
  • 250:  98.05%
  • 251:  98.44%
  • 252:  98.83%
  • 253:  99.22%
  • 254:  99.61%
  • 255: 100.00%
Now you need to map your ADC results, which come in a range of 0 to 1023, onto the range that the timer's PWM channel will expect, which will be a range of 0 to 255.  @ki0bk has suggested a way to map it to the percentage range you've specified (3% to 98%), but you could simply divide by 4 to map it to 0% through 100%, and then limit the top and bottom.  If you want limit to 'about 3%', then you could simply clamp the OCRnx value to a minimum of 6 (2.73%) and a maximum of 250 (98.05%).
When running at 3.3V, yes.  At 5V it runs at 16 MHz.
What have you done to confirm that your board is running at 8 MHz and not 16 MHz?
With your stated requirement, it may not matter.  You can choose an ADC prescaler of /128.   This will give you an acceptable ADC clock for both 8 MHz (62.5 kHz) and 16 MHz (125 kHz).  It will also give you a PWM frequency within your stated range.  At 8 MHz, the PWM frequency would be 31.25 kHz, and at 16 MHz it would be 62.5 kHz.
Joey, thank you for this detailed explanation of what I did not find in the datasheet. Below I give some information and have some questions.
- I already had the value of ICR1 changed to 1023 and TIMSK1 = (1 << TOIE1) in the source.
- I don't need a very small step size and variable resistor is a simple one (60 Ohm til 280 Ohm)
- So, should I use the 8 bit Timer0 or 2 or can I use Timer1 anyway?
- In the final design I want to use the 8 MHz internal oscillator.
  in several films of Microchip Makes on youtube F_CPU 8000000UL is used  for the Xplained mini board.
- Should I use OCR1A=6 and OCRB=250 with Timer1? But OCR1A is already used in the (Timer1_OVF_vect) what about this?
with the current source I have a duty cycle between 59.5 and 86.9%
    ICR1 = 1023; // Give timer same counting range as ADC readings for 1:1 mapping
    //OCR1A = 6;
    //OCR1B = 250;
    TIMSK1 = (1 << TOIE1);
    setupADC();
    sei();
void setupADC()
    ADMUX = (1 << REFS0) | (1 << REFS0) | (1 << MUX0) | (1 << MUX2);
    ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);  //  /128
    startConversion();
    OCR1A = dutyCycle;
ISR(ADC_vect)
    dutyCycle = ADC; // met delen door 4 duty cycle van 90-97% zonder /4  59.5-86.9%
    startConversion();
I hope you can help me further
Can you post a schematic of how you have the variable resistor connected with respect to GND, AVCC, and the ADC input?
A schematic provides information that a verbal description just doesn't convey effectively.
David
I have the drawing as an attachment
I'm confused, for what value of the 60-280 variable resistor do you set the 1K variable resistor such that you have 2V at A?
David
I'd like to see the generated code, such as the .LSS file.  And perhaps the build log and the ISP log -- is the right file getting to your target chip?
Indeed there is something happening that is "interesting".  As you are set up for inverted PWM and are seeing near 100% duty on the output, that would imply ADC conversion results always at 1023 counts.  That implies a very low reference.  Check the levels again, right on the AVR pins, for AGND and AVCC and AREF and PC5.
Then I'd make a sanity check program, and just make the PWM work.  [there is still a frequency mystery between the discussion and the posted traces]  E.g. in the main loop
while (1)
_delay_ms (123);
OCR1A++;
OCR1A &= 1023;
Although, you can be forgiven for not doing so, since a site upgrade earlier today broke the code editor.
int main(void) {
  ICR1 = 1023;
  //OCR1A = 6;
  //OCR1B = 250;
  setupADC();
  sei();
  while(1) {}
void setupADC() {
  startConversion();
void startConversion() {
ISR(TIMER1_OVF_vect) {
  OCR1A = dutyCycle;
ISR(ADC_vect) {
  dutyCycle = ADC;
  startConversion();
Although it does no harm, you've specified (1 << REFS0) twice.  Once is enough ;-)
I think you've misunderstood.  With mode 14 on TIMER1, ICR1 sets the >>resolution<< of the timer, while OCR1A and OCR1B are used to set the duty cycle of the two outputs OC1A and OC1B, respectively.  They do not set minimums and maximums.
You've made PB1/OC1A and output, so you should use OCR1A, which you are.
I think you can do away with the TIMER1 overflow interrupt altogether (and refrain from enabling it with TOIE1), and assign the new value for OCR1A directly in the ADC.
Your schematic doesn't make much sense.  Why two variable resistors?  Why not just a potentiometer?:
assign the new value for OCR1A directly in the ADC --> how should I make this in the source?
The sensor is a kind of potentiometer as is used in petrol tanks of cars, hence the strange resistance values (~ 65-280 Ohm, lineair type).
Of course, a potentiometer connected on one side to GND would be easier.
By the way do you have ideas how I could spoof the ADC for compensation of the 65 Ohm threshold?
The 1k 10 turn adjustment potentiometer serves as a pre-setting to set 2Vdc as bias, with another "potentiometer" this value should be 1Vdc
I tried posting the source with <> but it didn't work with copy-paste.
Whoops that was supposed to say ADC_vect ISR.  What I mean is that you can assign the new value for OCR1A in the ADC ISR.  You don't need the timer ISR to do that.
I'm not certain I understand.  Are you saying that the 1K pot needs to be adjusted such that when the sensor is 280 ohms (is that 'full'?), then the voltage of the resultant divider should be 2V, and when it is 65 ohms (is that empty), it should be 1V?  If not, then please say exactly what you mean.  Tell the range of voltages you want to see when the sensor swings from 65 ohms to 280 ohms.
This is what I mean by being specific when you state your requirements.  Here we are at post #40 and we are hardly any closer to answering your question than when this thread began.  Statement of the problem and the subsequent statement of the requirements for solving it are arguably the most important steps in any engineering endeavour.  I would argue that they are the most important steps in >>any<< human endeavour, technical or not.
Assuming I'm right and you want 1V-2V swing from the sensor, then there is a bit of arithmetic to do.  First we should try to determine the resistance needed on the 1K pot to achieve that range.
If:
  • the 1K pot we call R2
  • the 'full' voltage we call Vf
  • the 'empty' voltage we call Ve
  • the 'full' resistance of the sensor we call Rf
  • the 'empty' resistance of the sensor we call Re
... then we have two equations:
Vf = (Vcc * Rf) / (Rf + R2)
Ve = (Vcc * Re) / (Re + R2)
Filling in known values, we get:
2 = (5 * 280) / (280 + R2)
1 = (5 * 65) / (65 + R2)
Solving the first:
             2 = 1400 / (280 + R2)
2 * (280 + R2) = 1400
     560 + 2R2 = 1400
           2R2 = 840
            R2 = 420
Now we do the same for the second:
      1 = 325 / (65 + R2)
65 + R2 = 325
     R2 = 260
So we see that it is not possible to set the 1K to a single value which will result in the voltage swing you require.  Either I have misunderstood what you've said, or your circuit is not adequate to the task.  You need another resistor 'below' the sensor:
         VCC
         | /   R3
         |/|   1K
ADC5------+
         | /  Sensor
         |/|  65-280
         | /   R1
         |/|   1K
         GND
Now we have two new equations:
Vf = (Vcc * (R1 + Rf)) / (R1 + Rf + R3)
Ve = (Vcc * (R1 + Re)) / (R1 + Re + R3)
Filling in known values:
2 = (5 * (R1 + 280)) / (R1 + 280 + R3)
1 = (5 * (R1 + 65)) / (R1 + 65 + R3)
Solving the first for R3 w.r.t. R1:
2 * (R1 + 280 + R3) = 5 * (R1 + 280)
    2R1 + 560 + 2R3 = 5R1 + 1400
          2R1 + 2R3 = 5R1 + 840
                2R3 = 3R1 + 840
                 R3 = (3R1 + 840) / 2
Solving the second for R3 w.r.t. R1:
R1 + 65 + R3 = 5R1 + 325
          R3 = 4R1 + 260
Now we combine the two to solve for R1:
4R1 + 260 = (3R1 + 840) / 2
8R1 + 520 = 3R1 + 840
      5R1 = 320
       R1 = 64
Now we plug our solved value for R1 back into one of the equations (it doesn't matter which) to solve for R3:
          R3 = 4R1 + 260
             = (4 * 64) + 260
             = 256 + 260
             = 516
We can verify our results by plugging those values in to each initial equation:
   = (5 * (64 + 280)) / (64 + 280 + 516)
   = (5 * 344) / 860
   = 1720 / 860
   = 2
   = (5 * (64 + 65)) / (64 + 65 + 516)
   = (5 * 129) / 645
   = 654 / 645
   = 1
So that seems to work.  In order to get the 1V-2V swing on ADC5, you'll want a 516 ohm resistor above the sensor, and a 64 ohm resistor below the sensor.  A good value for the top trimpot is 1K as you already have.  A good value for the bottom trim pot would be 100 ohms.
If this makes sense to you, you can move on to the code.  If I've misunderstood your requirements for the voltage range presented to ADC5 by your sensor voltage divider, then please set me straight.  You might also want to explain the rationale behind those requirements.  For instance (if I'm right) why do you require a 1V-2V range?  Is this a requirement given to you by your teacher with no explanation?  Or was an explanation provided to you?
I think I've done enough of your homework for you for today ;-)
Sure that was a lot of work because I also started with Ohm's law equations to compensate the 65 ohm treshold.
This evening I have less time but tomorrowevening I will make the resistance circuit and then test with the code. thanks!
Bert
You haven't answered my questions:
Once you nail down the range of voltages you want to see on ADC5, then we can determine what range of values you'll see from the ADC, and then create a transfer function which converts that range of values to the 3%-98% PWM values you want.
One thing to consider is the current through the voltage divider.  If we go with the 516R and 64R settings for the two trimpots, then the current will be from:
I = Vcc / (R1 + Rf + R3)
  = 5 / (64 + 280 + 516)
  = 5 / 860
  = 5.8 mA
... up to:
I = Vcc / (R1 + R3 + R3)
  = 5 / (64 + 65 + 516)
  = 5 / 645
  = 7.8 mA
That should be fine for the trim pots. The 1K and 100R 10-turn pots I found on DigiKey are rated for 300 mW, and with the above arrangement they each will dissipate much less than that.
However, you will need to know what your sensor is rated for.  That includes voltage, current, and power.  Chances are you'll be OK, but engineering is about >>proving<< it.
I have connected a normal potentiometer and with the current source I have a duty cycle of 1.075% to 99%. so it seems to me the source is ok.
Would I be able to adjust the ADC conversion value in ADCL etc. after conversion for the other adjustable sensor (resistance of 65-280 Ohm)?
Because for the sensor the voltage on the AD input should be between 0.1 and 2Vdc.
As mentioned several times now, you simply need to scale the resulting range of ADC values to the required range of PWM values.  But you have several questions to answer first.  See my previous posts.
- How do I scale the resulting range of ADC values to the required range of PWM values?
- The voltage on the AD input should be between 0.1 and 2Vdc
- This range should give a 3-98% PWM range.
So return to the work I did in #40 and redo the math for 0.1-2 instead of the 1-2 which I did.  To what value will the 1K trimmer need to be set?  Will you need another trimmer 'below' the sensor?
Once you know the voltages to expect on the ADC input, you will also know the range of values to expect from the ADC.  Simply multiply by the resolution of the ADC (1024), and divide by AVcc (5).
[Sigh]... Does Google not work where you are?
https://www.google.ca/search?q=how+to+scale+a+number
Here's a hint:
https://www.avrfreaks.net/comment/2412566#comment-2412566
As Jim has hinted, you can find the source code for that pretty easily with Google:
https://www.google.ca/search?q=arduino+map+source+code
Second hit.
ADC max value = 409.6 and ADC min value = 122.88    because ADC=(Vin*1024)/Vref
The minimum DutyCycle (DC) reached now is ~2% but the maximum DC is now ~67.5%
What could I do making the max DC 99.9%? remapping?
Could  you give me some help/hints how to remapping in Atmel Studio?
Bert
Not sure how a register that only returns integers between 0 and 1023 can actually return n.6 or n.88 but anyway...
The fact is that your active range is 409.6 - 122.88 = 286.72. So if you end up with a value in the range 122.88 to 409.6 first subtract 122.88 from it. Now you have a value 0 .. 286.72. Assuming you want this to represent 0..100% then clearly you need to divide by 2.8672.
So say the value from your formula is 237.4 then 273.4 - 122.88 is 150.52 and 150.52 / 2.8672 is 52.497 so a reading of 273.4 is 52.497% and so n.
This is just simple algebra - don't try to "over think" this. It's simply an instanc of y=mx + c (a straight line).
How did you get 122.88 from a required range of 0.1V to 2.0V?
The higher number is right (although Cliff has pointed out you can't represent fraction numbers in an integer), but the lower number represents 0.6V, not 0.1V.
Thanks, I will test it right away!
OK, the lower value for 0.1V is 20.48 and ofcource I understand that it can't be represented.
I have used the calculation in the source but does not provide any improvement for the maximum duty cycle.
Ok, the value for 0.1V is 20.48 and ofcourse I understand that the figures behind the dot can't be represented.
I used the calculations in the source but it didn't provide a larger dutycycle towards 99%
Cliff has explained it perfectly well.  And both Jim and I have even pointed out where you can find the source code which will completely solve your problem.  Jim even actually posted it here!  Why are you still working on this?
IF you expect the ADC to return a value no lower than 20, and
IF you expect the ADC to return a value no higher than 410, and
IF you want a minimum OCR1A value of 6 (2.73%), and
IF you want a maximum OCR1A value of 250 (98.05%), and
WERE you to use the Arduino map() function, then it would look like this:
OCR1A = map(ADC, 20, 410, 6, 250);
Since you're not using the Arduino environment, you can simply implement the same function in your own code.  Have you even >>looked<< at the source?
You will need to handle cases where the ADC value is outside the range you expect so that your device doesn't explode.  What happens if the sensor fails?  What happens if there is a short somewhere?
I did make a recalculation and used it in the source but it gave no improvement for the maximum dutycycle e.g. 99.9%
I will not open a random .docx file.  Post the text of it here instead.
I searched a lot for the Arduino map() source but could not find it.
Could you please tell me where finding it?
I will post it in txt format.
You have got to be kidding me.
It's in >>this<< thread!
Scroll to the top of the page and find post #11.
He first mentioned it in #8.
Also find it where I pointed you to a google search result it in post # 47, and mentioned it again in #54.
You are clearly not paying attention, or making much of an effort.
I'm out.  Good luck with your project.
???  Does everyone else know what that means?  Do you mean that you want a duty cycle greater than 99.9% ?  What duty cycle >>do<< you want?  For which input value?  What duty cycle are you getting now?
Yesterday I made reply"s but can't see this here so I send it again.
The ADC value for 0.1V is 20.48, see the recalculations and ofcource I can use the figures after the dot.
At which part in the source I must place ORC1A = map(ADC, 20, 410, 6, 250);
Because I managed using the map function in Atmel Studio 7.
Dutycycle must be variable between 1 and 99.9%, now it's ~67.5 max
There must be some kind of a language barrier (or stubbornness, or laziness) at work here.  I don't care which.  I am tiring of it all, and just want it to end!  So here's a crack at it:
#define ADC_MIN 21
#define ADC_MAX 409
#define PWM_MIN 6
#define PWM_MAX 250
static uint32_t map(const uint32_t x,
                    const uint32_t in_min, const uint32_t in_max,
                    const uint32_t out_min, const uint32_t out_max) {
int main(void) {
  uint16_t adc;
  // Disable input buffer on ADC5.
  // AVcc, ADC5.
  ADMUX = (1 << REFS0) | (5 << MUX0);
  // div128, free running, start.
  ADCSRA = (1 << ADEN) | (1 << ADSC) | (1 << ADATE) | (7 << ADPS0);
  // OC1A output for PWM.
  // Mode 5 (8-bit Fast PWM), /1, non-inverted output on OC1A.
  TCCR1A = (2 << COM1A0) | (1 << WGM10);
  TCCR1B = (1 << WGM12) | (1 << CS10);
  // Forever.
  while(1) {
    adc = ADC;
    // Constrain.
    if (adc < ADC_MIN) {
      adc = ADC_MIN;
    else if (adc > ADC_MAX) {
      adc = ADC_MAX;
    // Scale to PWM output.
    OCR1A = map(adc, ADC_MIN, ADC_MAX, PWM_MIN, PWM_MAX);
Ask if you don't understand something.
After a time I started AD to PWM conversion for an application again and I want to ask a question about the above source if that is allowed.
I want the lowest PWM value 0 to be set at the lowest adc value and I thought that was possible by means of scaling with the map() function.
Doesn't it work because I use Atmel Studio 7?
Best regards.
Bert
#define ADC_MIN 0 and #define PWM 0. I don't understand the relevance of Atmel Studio 7 - how does this affect the code apart from compiling it??
Be_logic wrote:
Doesn't it work because...
Define "doesn't work".  Start over and show schematic/connections.  Tell voltages >>right on the AVR pins<<.  Show a complete test program.  Tell language, toolchain, and build settings including optimization level.  Tell how you are testing.  Tell what you expect to happen; tell what >>is<< happening.
There is a reason for knowing each piece of information requested, to answer your query.
What answer is map() giving you?  For what input?
All that said, perhaps depending on your timer setup you are getting the "single pulse" PWM at 0.  You can't get full-on and full-off at the same time with Fast PWM on an AVR8.  If you want full-off then use inverted PWM at the expense of not being able to get full-on.
Source see #63
Be_logic wrote:
Source see #63
Surely that answers few if any of my queries.  Did you tell how you are invoking the function etc?
theusch wrote:
Define "doesn't work". Start over and show schematic/connections. Tell voltages >>right on the AVR pins<<. Show a complete test program. Tell language, toolchain, and build settings including optimization level. Tell how you are testing. Tell what you expect to happen; tell what >>is<< happening. There is a reason for knowing each piece of information requested, to answer your query. What answer is map() giving you? For what input?
Then I went on to outline a possible cause.  Which is the >>same<< as in your other thread response!
Be_logic,
You do understand what's happening when Joey does this?...
#define ADC_MIN 21
#define ADC_MAX 409
#define PWM_MIN 6
#define PWM_MAX 250
so in other words it's just:
OCR1A = map(adc, 21, 409, 6, 250);
So that's saying "here is an ADC reading in the "adc" variable, it will be somewhere between 21 and 409, now map the value to the range 6 to 250". So this can only ever set OCR1A to values between 6 and 250. It will set it to 6 when "adc" is 21 and set it to 250 when "adc" is 409. It will linearly scale all readings between 21..409 to be PWM values between 6 and 250.
If these limits for ADC readings or for PWM range do not match your actual implementation then change:
#define ADC_MIN 21
#define ADC_MAX 409
#define PWM_MIN 6
#define PWM_MAX 250
If you want an ADC reading of 0 to map to a PWM setting of 0 then perhaps:
#define ADC_MIN 0
#define ADC_MAX 409
#define PWM_MIN 0
#define PWM_MAX 250
All this is a long version of what Kartman said in #65
More generally you need to determine:
What is the reading of ADC at the minimum point  - set this as ADC_MIN
What is the reading of ADC at the maximum point - set this as ADC_MAX
What is the minimum PWM/OCR value you want at the "bottom end" - set this as PWM_MIN
What is the maximum PWM/OCR value you want at the "top end" - set this as PWM_MAX
Job done.
In a situation like this, it helps to do three things:
 1) Clearly define what you wish to do:
     Read potentiometer and change (linearily) a PWM's duty cycle output according to the pot value.
2)  Write a simple, easy, clear Arduino program to do it:
    uint16_t  myADCvalue;
    unsigned long   myInterval=100;
    uint8_t   myScaledADC;
    void setup() {
       myADCvalue= analogRead(0);   // ADC MUX 0
       analogWrite(myPWMchannel, myADCvalue/4);
   void loop() {   // update PWM duty cycle every half-second
      if (millis() > myInterval) {
          myInterval = millis() + 500;
3)   decide if you're going on to the next stage of the project, or, are going to spend hours trying to understand how it works in AVR Studio.
clawson wrote:
Job done.
Ummmm...not necessarily:https://www.avrfreaks.net/commen...
[you answered in that thread as well]
Seven years ago.
It's not clear to me that @Be_logic even understands the issue in that thread, namely that non-inverted fast pwm can't do 0% duty cycle.
In either case (for @Be_logic or that thread's OP) I'd suggest phase correct PWM.  It can go to 0% and 100% duty.
Apparently, the message got through after many repeated attempts.
the frustrating part is that he dug up the old pertinent thread, which had the same symptoms and outlined the cause and solution.  Yet the discussion was ignored, and something to the effect of "what could be the problem and how can it be cured" was posted.  Similarly in this thread.
I used/checked the information #70, #73 so now it's in phase correct mode.
    TCCR1A = (1 << COM1A1) | (1 << COM1A0) | (1 << WGM10);  //WGM10 = mode 1 phase correct mode 8 bit
    // Set OC1A/OC1B on Compare Match when up-counting. Clear
    // OC1A/OC1B on Compare Match when down-counting.
    TCCR1B = (1 << CS10); // No pre scaling
    // Forever
        adc = ADC;
        // constrain
        if (adc < ADC_MIN)
            adc = 0;
            adc = ADC_MAX;
With this setting, phase correct, the frequency is indeed half as you can read in the datasheet.
But still the PWM is 14.5% at the lowest potmeter value and 45% at the highest value.
Bert
So show your new definitions of ADC_MIN, ADC_MAX, PWM_MIN and PWM_MAX.
Also note that this looks wrong:
        // constrain
        if (adc < ADC_MIN)
            adc = 0;
            adc = ADC_MAX;
0 is not in the range ADC_MIN to ADC_MAX (unless you changed the values?) so you cannot set this as the lower bound or the map() function will not work. You should have:
        // constrain
        if (adc < ADC_MIN)
            adc = ADC_MIN;
            adc = ADC_MAX;
It seems to me that you are just throwing code at your C editor without actually thinking about what you are doing. Software authoring should be a case of careful design followed by easy implementation. You seem to be skipping the design steps. If this is because you don't understand something then ask questions don't just guess at things randomly.
EDIT: oh this is ludicrous - I just read back through the thread as I can't believe it's taken 75 posts to get here and I found in #63 that Joey already gave you the correct code and you have actually CHANGED IT?!?! If you don't know what you are doing then don't just throw random ideas at the thing.
I already told you in #70 how to map to PWM_MIN=0 and that is by adjusting the four #define's - which bit of that sentence is it that you can't wrap your brain around??
I had already modified the #define's and I missed the error adc = 0 and I also modified it.
Nevertheless, I keep the same% PWM values as before. However, I have found that the frequency is halved at phase correct PWM.
    // Forever
        adc = ADC;
        // constrain
        if (adc < ADC_MIN)
            adc = ADC_MIN;
            adc = ADC_MAX;
This is like pulling teeth. No one here is psychic (AFAIK) so we can't possibly know what you have changed the MIN/MAX values to if you don't show us?!?!
sorry, here it is
#define ADC_MIN 0
#define ADC_MAX 438
#define PWM_MIN 0
#define PWM_MAX 115
And have you confirmed that if you simply set OCR1A to 0 or 115 it changes the duty "full scale"? Have you also confirmed that your ADC really does provide readings of 0 and 438 at either end of the Pot travel?
How can I test the ADC if the ADC reads the values between 0 and 438? However, with my Salea Logic analyzer I can conclude that the pot with the lowest resistance value gives a PWM value of 14.5% and with the highest resistance value it is 45.1%. I hoped that with the map () function I would be able to reduce the 14.5% to almost 0%. The pot has a lowest resistance of 60 Ohm, so not 0.
Just as an aside, likely not related to your issue... One subtle change needed in the code I posted in #63:
    // Constrain.
    if (adc <= ADC_MIN) {
      adc = ADC_MIN;
      adc = ADC_MAX;
This will avoid a warning when ADC_MIN is defined as 0.
Unless you're using -Werror (which, you should, by the way), the code in #63 will still build.  If you >>are<< using -Werror, >>and<< you failed to notice a failed build, it might explain why you're not seeing the results you're expecting i.e. the new code isn't actually making it onto the target.
Good catch.
Real-world control signals are rarely perfect.  As the AVR's 10-bit ADC has 1000 and a few more counts, I'll generally say e.g. anything below 11 is zero, and anything about 1009 is 100%.  Then map the intervening 1000 counts to 0.0% to 100.0%.
OP can test that assumption by feeding a hard 0 into the map call.  Usually I'll have such a sanity-check during dev anyway, to test output functionality.  Drive to e.g. 50%; wait a few seconds to read the result; drive to other values in succession delaying between.  Note that you don't start with 0% and 100% or you cannot tell whether stuck low/high.
As mentioned, we don;t really know the actual current code and test conditions.
Thank you for your response and today I have another time to get AD to PWM working, at least I hope so.
As a result of your tip, I manually set to 0 and 115 in the () function PWM_MIN and PWM_MAX, respectively.
But that doesn't matter.
I doubt that the folder function is updated with new values.
It should not be that difficult to get the minimum PWM value between 0 and ~ 3%?
Hopefully you want and can help me with that.
