DHT11 isn't responding.
10 posts / 0 new
Hello everyone! I try to find a mistake already 3 days, re-read the code and the datasheet, but all for nothing. Please, help me find the error. As for the LCD library, I'm sure, because I use it in other projects.
DHT11.c:
#include "DHT11.h"
void DHT11_Init (void)
	_delay_ms(1500);
void DHT11_ResetPort (void)
	DHT11_DDR |= 1 << DHT11_PIN;	//	Output
	DHT11_PORT |= 1 << DHT11_PIN;	//	High
	_delay_ms(77);
uint8_t DHT11_ReceiveData (uint8_t* data)
	DHT11_ResetPort();
	DHT11_PORT &= ~(1 << DHT11_PIN);
	_delay_ms(18);
	DHT11_DDR &= ~(1 << DHT11_PIN);
	_delay_us(40);
	if ((DHT11_PINS & (1 << DHT11_PIN)))	return DHT11_ERROR;
	_delay_us(80);
	if (!(DHT11_PINS & (1 << DHT11_PIN)))	return DHT11_ERROR;
	while (DHT11_PINS & (1 << DHT11_PIN));
// 	_delay_us(80);
	for (uint8_t i = 0; i < 5; i++)
		data[i] = 0;
		for (int8_t j = 7; j >= 0; j--)
			cli();
			while (!(DHT11_PINS & (1 << DHT11_PIN)));
			_delay_us(33);
			if (DHT11_PINS & (1 << DHT11_PIN))  data[i] |= 1 << j;
			sei();
	if (data[0] + data[1] + data[2] + data[3] == data[5])	return (DHT11_SUCCESS);
	return (DHT11_ERROR);
main.c:
#include "main.h"
void IO_Init (void)
void setup (void)
	IO_Init();
	LCD_Init();
	DHT11_Init();
	sei();
int main (void)
	setup();
	uint8_t meteoData[4];
	while (1)
		LCD_SetPosition(1,1);
		if (DHT11_ReceiveData(meteoData))
			LCD_PutByte((meteoData[2] / 10) + ASCII_NULL);
			LCD_PutByte((meteoData[2] % 10) + ASCII_NULL);
		else	LCD_SendString((int8_t* ) "Error");
		_delay_ms(1000);
Ruslan
Don't just assume - make a test to actually prove this!
It's more helpful to embed you schematic so that we can actually see it in the post - like this:
Instructions to do this are here: https://www.avrfreaks.net/comment...
So that looks like a Proteus simulation - is it?
If it is, then use the simulator to step through the code & see what's happening.
The schematic shows as ATMega328P; it has on-board debug - so, again, use it to step through the code & see what's happening.
There's always the possibility that the DHT11 is faulty or damaged - have you checked?
Do you have access to a logic analyser or oscilloscope?
Ok, I prove, that the LCD is work.
#include "main.h"
void IO_Init (void)
void setup (void)
	IO_Init();
	LCD_Init();
	DHT11_Init();
	sei();
int main (void)
	setup();
	//uint8_t meteoData[4];
	int8_t a = 51;
	LCD_PutByte(a / 10 + ASCII_NULL);
	LCD_PutByte(a % 10 + ASCII_NULL);
	while (1)
// 		LCD_SetPosition(1,1);
// 		if (DHT11_ReceiveData(meteoData))
// 			LCD_PutByte((meteoData[2] / 10) + ASCII_NULL);
// 			LCD_PutByte((meteoData[2] % 10) + ASCII_NULL);
// 		else	LCD_SendString((int8_t* ) "Error");
// 		_delay_ms(1000);
Ruslan
Shouldn't the test in DHT11_ReceiveData be:
if (data[0] + data[1] + data[2] + data[3] == data[4])	return (DHT11_SUCCESS);
David (aka frog_jr)
In one of the first page search hits for "Arduino DHT11 library" I find this: (https://github.com/nicolsc/ardui...)
enum ReadStatus {
    OK,
    ERROR_CHECKSUM,
    ERROR_TIMEOUT,
Why not implement these separate error codes so you can get better visibility of where your code fails ?
I fixed, thank you, but it is still doesn't work.
Ruslan
A general tip for you.
Rather than commenting-out stuff like this:
D-503 wrote:
	while (1)
// 		_delay_ms(1000);
It's a lot easier to use a #if - like this:
	while (1)
#if 0
 		_delay_ms(1000);
#endif
Or even
	while (1)
#ifdef DISABLE_DHT11
 		_delay_ms(1000);
#endif
Which makes it easier to disable code in multiple places; eg
void setup (void)
	IO_Init();
	LCD_Init();
	DHT11_Init();
#endif
	sei();
int main (void)
	setup();
	int8_t a = 51;
	while (1)
 		_delay_ms(1000);
#endif
That really tells us nothing...
The DHT11_ReceiveData function must not be returning a TRUE value since you are seeing "Error".
We do not know how DHT11_SUCCESS and DHT11_ERROR are defined, and it would be helpful if you used the debugger to step through the code to see the values of data[0], data[1], data[2], data[3] & data[4] when you are making the determination to return SUCCESS or ERROR.
David (aka frog_jr)
and see #5 - have your code distinguish different types of error ...
Solved one and half month ago. I played with the timings and it all worked. Only the sensor gives the strange values for humidity. And it isn't very precise in principle.
Ruslan
