How to avoid this ESP8266 / LCD / AVR UART glitch easily?
23 posts / 0 new
I have a PCB with an ESP8266 + graphic LCD and an ATtiny816.
The init phase on the main file looks like so:
	CLOCKSet20MHZ();
	UARTInit();
	SPIInit();
	sei();
	LCDInit();
	LCDScrollInit();
	#ifdef DEBUG
		LCDFillColor(BLACK);
		LCDSetCursor(0, 0);
		LCDSetTextSize(1);
		LCDSetTextColor(BLACK, WHITE);
		LCDGWriteString("Start DEBUG\n");
	#endif
	ESPInit();
ESP8266 is communicating via UART, LCD via SPI.
Notice how the DEBUG macro is checked and if enabled "Start DEBUG" is written to the LCD.
The next thing that happens is the ESP8266 is being initiated with a list of commands, what they are is not important right now but the send function used to transfer the data + init are:
void UARTInit(void)
	cli();
	PORTB.OUTSET = PIN2_bm; // TxD pin high
	PORTB.DIRSET = PIN2_bm; // TxD pin as output
	USART0.BAUDL = 0xB6;
	USART0.BAUDH = 0x02;
	USART0.CTRLC |= USART_CHSIZE_8BIT_gc;
	USART0.CTRLB |= USART_RXEN_bm | USART_TXEN_bm;
	USART0.CTRLA |= USART_RXCIE_bm; // RxD interrupt enabled
	UARTRXFlag = false;
void UARTSendString_P (const char *data)
	#ifdef DEBUG
		LCDSetTextColor(GREEN, BLACK);
	#endif
	for (char c = pgm_read_byte(data) ; c != 0x00 ; c = pgm_read_byte(++data))
		UARTSendChar(c);
		#ifdef DEBUG
			LCDGWriteChar(c);
		#endif
Please note that the commands that are sent using UARTSendString_P should be displayed in green over black.
Incoming UART is also sent to LCD using the following code:
ISR(USART0_RXC_vect)
	static uint8_t UARTRXBufferIndex = 0;
	UARTRXBuffer[UARTRXBufferIndex] = USART0.RXDATAL;
	#ifdef DEBUG
		LCDSetTextColor(BLUE, BLACK);
		LCDGWriteChar(UARTRXBuffer[UARTRXBufferIndex]);
	#endif
	if (UARTRXBuffer[UARTRXBufferIndex] == '\n')
		//UARTRXFlag = true;
	else if (UARTRXBufferIndex < UART_RX_BUFFER_SIZE)
		UARTRXBufferIndex++;
As you can see the incoming data will be printed in blue letters on the LCD.
Here is the problem:
  1. When I load the board by powering up the power supply I can see that the text that is written to the 1st line has some spaces in it and the colors of the letters are changing, indicating that the UART RX interrupt was fired a few times.
  2. When the AVR resets by writing new code, the letters appear on the LCD as should (no spaces and no color changes - all green for the 1st line).
  3. Disabling UART RX caused the text to be displayed without the spaces so I suspect the UART RX firing a few times when powering up.
What could be the cause of this different behavior on power-ups? I have added a long delay before the ESP8266 init sequence (1 sec) which had no effect on the above behavior.
The bootloader of the ESP8266 sends some messages on power-up.
Stefan Ernst
You haven't shown the LCD functions - are they suitable for calling from an ISR ... ?
What do you mean by suitable?
Here are the LCD functions - communicating over SPI
void LCDSetTextColor(uint16_t text, uint16_t bg)
    LCDTextData.textColor = text;
    LCDTextData.textBGColor = bg;
void LCDGWriteChar(char c)
	if (c == '\n')
		LCDTextData.cursorY += LCDTextData.textSize * 8;
		LCDTextData.cursorX = 0;
	else if (c != '\r') // If normal char
		LCDGDrawChar(LCDTextData.cursorX, LCDTextData.cursorY, c, LCDTextData.textColor, LCDTextData.textBGColor, LCDTextData.textSize);
		LCDTextData.cursorX += LCDTextData.textSize * 6;
		// If end of line, skip to next line
		if (LCDTextData.cursorX >= LCD_W)
	// If reached last line, scroll 1 line
	if (LCDTextData.cursorY > LCD_H)
		LCDScrollLine();
		LCDTextData.cursorY = LCD_H;
In general, stuff that takes a long time should not be called from ISR ...
EDIT
Not the kind of thing that's generally good in an ISR!
surprise
Adding a 1 sec delay before the ESP8266 init function should fixed it, I think. That allows enough time for the ESP to send a few chars before I start init. As far as I can tell _delay_ms() is not clearing global interrupts. However this does not help and I can see the same artifacts.
You can see the top white block that says start DEBUG is showing OK, the problem is with the line under it that should say "ATE0" all in green text.
Right now it says "A T. E 0." with the T in green all the other fonts in blue. The spaces and dots are not something I'm sending or expecting from the ESP8266.
The color changes over because the UART interrupt fires since some data in coming in.
An ugly solution could possibly be to enable the RX interrupt only after sending the 1st command?
surprise
Fair enough, I can add some flags and insert that into the while(1) loop in main... Trying it out now.
No. The UART is already initialized, so you do receive that messages no matter of that delay. If you want to resolve the problem with a delay, then you need it in front of the UART initialization.
Stefan Ernst
sternst wrote:
If you want to resolve the problem with a delay...
That does not resolve the problem - it simply masks the symptoms.
OK so here is the problem... how can I move the code out of the ISR?
The init of the ESP8266 and the LCD takes place at the beginning of the code, before it reaches to the while(1) loop inside main. This means that I can not simply set a flag because no one will be there to check it just yet.
I can do something else though, I can send the data to the LCD from within the UART RX ISR, but only after a full commands was received - which means to check for '/n'.
The standard approach (not specific to AVR)  is to use a so-called Ring Buffer (aka "Circular Buffer" or "FIFO").
This has been covered many times both here and elsewhere.
EDIT
eg, https://www.avrfreaks.net/comment...
You seem to be using the uart (and the TFT routines) both from within "normal" code and from ISR's ???
That looks like pretty sloppy progamming and is almost beggin for timing dependant bugs.
My advise to you is to make a nice and clean split in your code between different functions.
A certain part of the code shoud be responsible for handling TFT routines, and no other code should be able to interfere with it.
Same for the uart.
C++ and Classes are ideal for this.
Different parts of the code should exchange data in a predictable way. Some messaging system or ring buffers.
In my code ISR's are usually pretty dumb and small.
For the uart I first prepare some buffer with data and set a counter, (in regular code).
The ISR then just sends a byte,( without even knowing what that byte means) and decrements the byte counter.
Once the (volatile) byte counter reaches zero the interrupt disables itself.
If the rest of the code detects that the byte counter has reached zero, then it know's the data is send and the buffer can be reused / filled with new data.
It's a very simple but robust semaphore like behaviour.
I think it's a good idea for you to make a cup of tea (coffee) sit back with a pen an paper (No PC) and sketch some idea's for the global behaviour of your program.
After an hour or so take the best of your ideas and put it in a pseudo code framework.
Then again look at it from a distance and decide if you want to go this way.
If so, then fill in the details.
Paulvdh wrote:
If the rest of the code detects that the byte counter has reached zero, then it knows the data is send and the buffer can be reused
Using a Ring buffer means you don't have to wait for the buffer to be empty
EDIT
This Ring buffer implementation often gets recommended here:
http://www.fourwalledcubicle.com/files/LUFA/Doc/170418/html/group___group___ring_buff.html
EDIT 2
Download link: http://www.fourwalledcubicle.com/AVRCodeSamples.php
Ring buffers also called circular buffers are also a good way to exchange data between different parts of a program.
If you need performance from your small AVR you may want to avoid copying data from one buffer to another too many times.
Passing a pointer around is "cheaper" but can easily lead to more difficult to maintain code.
The main thing here is that any message passing code used (and also the rest of the code) is based on simple, easy to maintain and well thought out algorithms.
So you suggest implementing 2 buffers? One for UART RX and another for TX?
This means the buffers should be large enough to hold the entire init sequence for the ESP8266 and the replies from the module prior to being able to send them to the LCD.
Is there an alternative that might get away with a much smaller memory usage? This means sending the text to the LCD right after UART send is complete (last char or command) and displaying incoming data on the LCD right after it was reprieved.
I can't set a Boolean flag for this as a variable can be tested only when I get into the while(1) loop in the code.
Not necessarily.
Rx is the important one - as you have on control of when charters arrive.
Tx is entirely under your control - so you can manage it however fits your application.
No, not at all.
The whole point of Ring buffering is that it allows your code to get on with stuff while receiving/transmitting.
You don't just fill the buffers completely, then send all at once.
The buffer forms a queue - so it just needs to big enough to match the peak rate of character arrival to the average rate of processing.
Flow control [1]
Again, you've missed the point - it allows you to keep doing stuff while the send/receive is ongoing.
EDIT
Another option could be to reduce the baud rate ?
EDIT 2
Specifically, in this kind of application, Harware Flow Control, or Software Flow Control
OK, I think I'm not clear about the part regarding the buffer size.
Let's say I have a function called ESP8266_Init() and it send multiple commands over UART to the ESP8266 module. That function is being called right after UART was initialized so it send 8 strings more or less. After each one is sent there is an incoming transfer from the ESP8266 with some reply.
Now here is the main issue - I imagine that in order to figure out if the buffer contains new data there is an expression to evaluate in the while(1) loop in main. For example if "head" pointer was changed from previous value (assuming I have a head + tail pointers). If there is new data it is sent to the LCD, if not the program continues normal execution.
The 1st time the condition can be evaluated is after ESP8266_Init() was already executed and sent a bunch of data and also a bunch of data was received.
How can I fire the init commands at a time where the buffer is being evaluated not inside an ISR but rather in the while(1) loop?
Hope that makes sense.
But you should never send multiple AT commands without waiting for - and paying attention to - the response to each!
surprise
Did you look at the links I posted earlier? It has a RingBuffer_IsEmpty() function: http://www.fourwalledcubicle.com...
OK... I see the code will have to be more complicated than I originally thought. :)
The init part must be blocking though?
Without looking too deply into your code, it's bad habit to write blocking code.
Some time ago I wrote a network stack for an RS485 based network.
You could declare a packet (with it's own buffer), fill the packet (data addres etc) and send it on it's way.
It also had a callback funcion.
If there was a response from a remote node it could call a callback function.
The callback function could format a new packet, set the callback pointer to a new function and send the new packet on it's way.
Once the second response arrived the 2nd callback function was executed, and it could do whatever was needed with the new packet.
(The packet class has built in address checking, resends timeouts, CRC, and they are all handled for each packet before the callback was called, so the callback funcion only had to do something with the actual data).  "Simple" callback functons did nothing more than copy a sting into the packet, change the callback pointer and send the new packet on it's way. 3 lines of code.
It was quite a hassle to write and debug the code, but after I got it going It all works pretty neatly.
The implementation of the callbacks automatically enforces a natural flow into your data stream without writing extra loops of if() statements. Functions just get called when they need to be called.
I don't see why that should necessarily be the case ?
So do you use a timer interrupt to check on the buffer state?
Total votes: 2
Yes and no.
It is pseudo - blocking, in that you can not just send several init commands all at once.
You have to wait for an appropriate response following each command you send.
But it need not be truly blocking in the sense that the micro can't do anything else but sit in a wait loop awaiting the response.
Depending upon how you code it the micro could be doing other things while awaiting the response.
When it gets a response, verifies that the init is preceding correctly, then it sends the next init instruction.
Note, that if the init is taking place at the start of the program, and there isn't anything else to do between sending the init instruction sequence, then the program might well just sit there awaiting the next response.
