bq21040 Li-poly battery charger, Solar Cells and USB connector
6 posts / 0 new
Hi All
I am planning to use the bq21040 as it has a wide voltage input from 4.5V to 28V.
Ideally, Vin will always be 5V, but there could be a possibility that Vin be solar cells rated between 12v to 24V.
The PCB have a USB connector connected to the bq21040.
Are there any confederation to keep in mind when Solar panel is connected to the micro USB connector using a custom cable and outputting 12V-24V?
The bq21040 will be configured to output 500mA to 800mA.
Please note , the USB will not be connected to any device such as a PC, when connected to a solar panel.
Regards
DJ
That's a TI (Texas Instruments) product - nothing to do with Atmel or Microchip.
(in fact, Microchip do some charger chips - so it's actually a competitor product!)
For documentation & support with TI products, you need to go to the TI website!
http://www.ti.com/product/BQ21040 - note 'Technical documents' and 'Support and training' ...
We know what happened to the Confederates. Just ask General Lee.
You would want to ensure the input voltage is limited to less than 28 volts by using something like a zener based circuit that disconnects the input in case of overvoltage.
The problem with using a standard connector in non-standard ways is what happens if someone thinks its just a USB connector and plugs it into something that can not take 24v!!!
I would suggest providing a separate solar panel input connector of a unique type rather then trying to re-use the USB connector!
+24!
ki0bk wrote:
... if (sic?) someone thinks its just a USB connector
Murphy's law clearly states that there is no "if" about it ...
surprise
