If I had installed Studio as an admin, would I have avoided this?
I don't want to go through this on my primary computer.
I am not sure whether you found it but for clarification. Right click on Project and go to Properties.
I found it, but everytime I change a project to "use the latest version", AS7 crashes. At least when I reopen it, the project does have the change...
Funny UI issues after upgrades are almost always due to the caches in %LOCALAPPDATA%/AtmelStudio/7.0
I wish the studio installer just cleared them. (Because VS2015 isn't smart enough to regenerate them)
Done
Thank you!
Tried to update 7.0.594 to 7.0.1645, update failed. Then I removed 7.0.594 to install from scratch. The drivers install, but then "Atmel Development Environment" fails to install according to the installation log. Not too sure where in installation log to look for the problem. Any ideas?
Many Thanks
J.Clark
If you can share your log we can help you look.
Thanks for getting back to me. I attached the log. It seems that all goes well until:
MSI (s) (38:6C) [13:24:20:113]: Hello, I'm your 32bit
Impersonated custom action server.
Action start 13:24:19: ExtractContent.
SFXCA: Failed to create new CA process via RUNDLL32. Error code: 2
Then a list of Property (S) that refer to locations that did not exist when the installation started??
I attached the log. Many thanks.
Hello All,
after updating to 7.0.1645 on Windows 7 x64 the IDE is trying to update the EDBG firmware for a couple of SAM D21 and L21 boards (i.e. from revision 3.19 or 3.1f to 3.25). The progress bar is full instantaneously I get the message EDBG MSD firmware successfully upgraded. But it's not, and I cannot flash my software anymore!
I have tried also with atfw directly, but with no success, atfw crashes!
Do you have any idea what I can do to continue work?
Best regards,
Draghi
Take the kit out of MSD mode.
View-Available Tools, right click the edbg, kit mode settings, select DGI and make sure Persist is checked.
Hi, meolsen,
I have same problem to update the EDBG firmware from revision 3.22 to 3.25. After following your instructions, changed edbg to DGI mode with persist checked(before is AUTO mode) the update is still not sucessful from Atmelstudio or from command line. And I can no longer view the edbg in Atmelstudio even though the vitual port is visible. Could you give me some more details?
Edit: I solved the problem by try and error. Set to DGI but persist not checked->command line to update->some error message and can not go on->replug the device and update in studio(setting is back to "AUTO" and persist checked)->update sucess.
I was trying to install "as-installer-7.0.1645-full.exe" on win10, but this message was displayed. Does anyone have the same symptoms?
That worked for me! Tnx meolsen
Hello All,
Best regards,
Draghi
Could you try the following update http://studio.download.atmel.com/7.0.1652/as-installer-7.0.1652-web.exe and see whether it fixes the issue?
Charles
Any chance we can get Atmel Studio 7 to not overwrite the Arduino Bootloader when using the Atmel JTAGICE3 to program an Arduino via ISP? Or, have an easy way (menu option?) to restore Arduino Bootloaders? Is there a quick way to restore it via the JTAGICE3? I programmed my Mega2560 via it's ISP (not the onboard ATmega16u2's ISP) but now when I try to program it via the USB/ATmega16u2 using the Arduino IDE I get "stk500v2_ReceiveMessage(): timeout" messages. I don't understand what's going on. I thought the Atmega16u2 programs the ATmega2560 via the Atmega2560's ISP also. Guess I was wrong.
That just gives me the following error message:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/Christos/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/Christos/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done. Thank you.
Error while burning bootloader.
My fuses and bits look like this:
BODLEVEL = 2V7 OCDEN = [ ] JTAGEN = [ ] SPIEN = [X] WDTON = [ ] EESAVE = [X] BOOTSZ = 4096W_1F000 BOOTRST = [X] CKDIV8 = [ ] CKOUT = [ ] SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_65MS EXTENDED = 0xFD (valid) HIGH = 0xD0 (valid) LOW = 0xFF (valid) LB = NO_LOCK BLB0 = NO_LOCK BLB1 = LPM_SPM_DISABLE LOCKBIT = 0xCF (valid)
I wish it was that simple... i'd not be here then.
Can you show us the command you used when running Avrdude?
And just to make it clear, you have a JTAGICE3 connected to target?
You need to also change the programmer on the line above.
Now it's set to use an avrisp2...
Yes, to connected via JTAGICE3.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cjtag3isp -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : jtag3isp
avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2110, 0x2140
1) Go To Run in Windows
2) Type %appdata%\Atmel\AtmelStudio\7.0
3) Delete the above folder
4)Type %localappdata%\Atmel\AtmelStudio\7.0
5) Delete the above folder
6) Start Studio and open the project.
Note: This will remove the existing settings for Atmel Studio like Windows Layout, Recent projects etc.
Charles
TopI am not sure whether you found it but for clarification. Right click on Project and go to Properties.
TopAll part support is contained in the part packs (device packs). Header files, linker scripts, assembly include files, ... Not everybody is happy for this disconnect from the toolchain, but for us it gives the advantage of being able to distribute new part support and fix bugs without having to release a new toolchain. All our packs is available at http://packs.download.atmel.com/
TopSomething strange happened to my computer shortly thereafter. Some programs froze up and others worked okay. Studio worked okay. The start button didn't do anything. Ctrl-alt-del worked but nothing on its menu did. Trying to sign out or restart or shutdown was futile. All that happened was a blank screen with those white balls chasing each other around a circle. I had to pull the plug. Well actually pressing and holding the power button.
This situation is very unusual. I don't know if Studio did it, but deleting stuff in appdata is rather unusual also.
Since re-booting, everything seems to be normal.
TopMaybe not so normal. Now my HyperTerminal doesn't work. It can't read the session file. It gives a pathlist in AppData. It shows "Accessories" in the pathlist. But I have "Windows Accessories" instead. Maybe that folder name change in the error message is irrelevant because HyperTerminal hasn't changed since XP.
TopWell that wasn't so bad. I just had to create a new port.
TopReally? I already said that in #47, but apparently step by step recipes are needed. Well, I'll keep that in mind for the future...
Top
