What is the story with the PEN pin on the ATMEGA64A
10 posts / 0 new
I've read through the datasheet and I'm not really getting it.  Can you operate the ATMEGA64A using ISP with the RESET like others?  What is the point of the PEN?
Interesting. The Spec Sheet says:
  1. PEN is a programming enable pin for the SPI Serial Programming mode, and is internally pulled high. By holding this pin low during a Power-on Reset, the device will enter the SPI Serial Programming mode. PEN has no function during normal operation.
This IS a JTAG chip. The serial programming connection diagram (Figure 31.7) does not show anything about the PEN pin. Very strange! The SPI serial programming algorithm (section 31.9.1) says:
  1. Power-up sequence:
    Apply power between VCC and GND while RESET and SCK are set to “0”. In some systems, the programmer can not guarantee that SCK is held low during power-up. In this case, RESET must be given a positive pulse of at least two CPU clock cycles duration after SCK has been set to “0”.
    As an alternative to using the RESET signal, PEN can be held low during Power-on Reset while SCK is set to “0”. In this case, only the PEN value at Power-on Reset is important. If the programmer cannot guarantee that SCK is held low during power-up, the PEN method cannot be used. The device must be powered down in order to commence normal operation when using this method.
So, PEN is not required in all cases!
Simple answer: Just ignore it and don't use it. I hope you don't really want to start anything new with the M64, you can use the new compatible chips and gain that pin as a GPIO.
Search the forums - this thing has been a mystery for years. I remember a lot of posts from "microcarl" about it.
I think (as John says) the consensus in the end was "ignore it"
PEN was (is?) a carryover from the ATmega103.  There is little on /PEN in the Mega103 datasheet; a couple of notes similar to the text in the Mega64 datasheet.
Indeed, we fussed a bit with /PEN in our first Mega64-family app years ago.  end result:  Just ignore it and let it float.
I was looking for a 64 pin AVR that can do 5V and has a pair of UARTs.  I think there were some others 128A or 2561.
I might have a couple of unmounted m128/m256 lying about...
Tom Pappano
Tulsa, Oklahoma
And in that thread I mentioned the NEWER pin compatible chip to the M64 which is pretty old.
edit ATmega1281/2561.
edit #2 the price is ridiculously high for those 2 chips compared even to a Mega128A.sad
Thanks John - it is a for a for fun project but I still don't want to think the AVR I'm using is going to go out.  It still says in production on the microchip site but who knows for how long.
Just get an Arduino clone with a '2560 mounted, probably for less than a single bare '64A?
$13, with free shipping, wall charger, and USB cable:  https://www.ebay.com/sch/i.html?...
