floating point values on modbus.
2 posts / 0 new
For my project I am using modbus in slave mode. And to replay mater I want to transmit floating point no like 123.456 or 9958.32. So what is correct way to transmit float values on modbus.
I having function to break float value in char. but I don't know weather it is correct or not for MODBUS.
unsigned char outbox[5];
void breakDown(void)
  int index=78.295;
  float member=1;
  unsigned long d = *(unsigned long *)&member;
  outbox[0] = d & 0x00FF;
  outbox[1] = (d & 0xFF00) >> 8;
  outbox[2] = (d & 0xFF0000) >> 16;
  outbox[3] = (d & 0xFF000000) >> 24;
  transmit(outbox[0]);
  transmit(outbox[1]);
  transmit(outbox[2]);
  transmit(outbox[3]);
Clearly, this is not a tutorial. So why post here?
Firstly, your masks will probably need a type associated with them. Eg: 0xff0000UL
You’ve got four possibilities of byte order. One works. Read the modbus spec to find this out.
