Find all doesn't, in a START generated project
3 posts / 0 new
In a START generated project I would like to find all references to a item.  For example "SERCOM_USART_CTRLB_PMODE_Pos".  I can find several uses, but not the define.  In ASF3 generated projects I could find all references.
I know that I can go to the pack and find the reference, but that seems to be a little awkward.
Is there any way to configure Atmel Studio to include the pack directory in the searchs?
Go to VAssistX -> Visual Assist Options->C/C++ Directories Select Custom and add directories
https://docs.wholetomato.com/def...
This solution is not good for device specific includes, it is system wide, thus if you use a different device, you must change the entries.  Still need a solution that includes the device includes by device.
