Very special compile error.... software bug
13 posts / 0 new
I go to a university where many students use Atmel Studio 7.0 and i have heard of many people having this problem. It is not too serious of a problem but I am curious how to fix it. I have only ever made a C executable project so i'm unaware if this occurs in other types but here it is:
Every time i make a change in my project files and compile or build, I get the same exact error "recipe for target 'project'.elf has failed". Then i have to compile or build once more, and it compiles / builds without fail. I can even make  change in a comment or delete one character that doesn't affect the output, and the error comes back until i build for the second time. I have a feeling that it's because i'm running atmel studio on a mac via Parallels, but I was wondering if anyone has any ideas of why this is. It seems apparent that this is a bug but maybe there is a fix
This has absolutely nothing to do with the compiler. It's a problem with your builr environment, e.g. a flaw in your Makefile (input of GNU make).
sounds like something was not "cleaned-up" properly the first time.
Have you shown this to your teachers?
It will be far easier for them to help you when they can sit at your computer and see exactly what you are doing, and exactly what you have on your computer, and exactly what is happening.
It is vastly more difficult to debug remotely - especially for complete strangers. You will need to supply a whole lot more detail...
"recipe failed" simply means there was a build error. If I write:
int main(void) {
    // no closing brace
then I might expect to see the same. This is not a valid C program and will cause an error.
The point about AS7 (and the Visual Studio on which it is based in general) is that it can be very poor at showing the reason for build errors. Often the infamous "Error List" will report something like this "recipe failed" thing (which as SprinterSB says comes from make, not from the compiler) but only when you switch to the "Output" tab and read through the complete output of the compiler will you see the real reason for the failure.
So when you have seen "recipe failed" what has the complete build output tab actually said?
I'm guessing that an external make file is involved.
"SCSI is NOT magic. There are *fundamental technical
reasons* why it is necessary to sacrifice a young
goat to your SCSI chain now and then." -- John Woods
I don't think you guys understand. It has nothing to do with what my code contains. I've made many many projects and every time I compile, i have to do it twice.
Also @awneil I dont understand what you mean that you dont think something was not "cleaned-up" properly the first time. And what do you mean debugging for complete strangers?
​The bottom line is that i have provided all of the detail possible. The problem guaranteed has nothing to do with what i'm doing wrong / right, this is a BUG
No you haven't.  Is this for an AVR, Xmega, SAM? Which device?  Are you using ASF, or GCC?
As suggested show us the build output.
AS Cliff has explained, Visual Studio does not give a very good explanation with the "recipe failed".  THe Build Output window does give an accurate reason for what the problem is.
EDIT:
Recent thread with the same error:
https://www.avrfreaks.net/forum/t...
In that thread the cause for the error was a simple boo boo.  Just as we suspect here. smiley
No, you haven't.
Specifically, you haven't provided the full build output - as requested in #4.
Also, #5 suggested that an external makefile may be involved.
You haven't confirmed whether that is or is not the case
When you build a project, the first thing it does is to delete the stuff from previous builds that's no longer required.
That's what I mean by "cleaning-up"
You don't actually know anyone here, do you?
And we don't know you - so we are all "complete strangers"
We know nothing about you; we know nothing about your project; we know nothing about the computer (or computers?) you are using; we know nothing about how you have your computer(s) configured; we know nothing about what else may or may not be installed on your computer(s); we cannot see what you are actually doing when you get this message; we cannot see what is actually happening on your computer at the time; we cannot see what is appearing in the 'Output' window; etc; etc; etc
All of this makes it very much more difficult for us - as complete strangers, far away - to debug your problem.
But none of this applies to your teachers: they do know you; they do know about your project; they do know the computer (or computers?) you are using; they can see how you have your computer(s) configured; they can see what else may or may not be installed on your computer(s); they can see what you are actually doing when you get this message; they can see what is actually happening on your computer at the time; they can see what is appearing in the 'Output' window; etc; etc; etc
So, really, your teachers are best placed to help you with this.
Almost certainly it does.
 this is a BUG
http://www.catb.org/~esr/faqs/smart-questions.html#idm46060474146768
ltimber wrote:
this is a BUG
yes, almost certainly a BUG in the code you have written. But until you post the build output so we can see what the compiler is complaining about no one here can help you locate what you have done wrong.
EDIT: just this week there was this:
That illustrates how deficient the AS7 Error List actually is. In that case it completely failed to report the actual error even though the build output that the OP posted made it clear exactly what was wrong.
and/or in the makefile you have written - if, indeed, it is an external makefile.
See #5.
I get that when I have something stupid like a missing } in a code file. I read it as "you screwed THAT up, dummy."
Give us an example program that produces the error.
"We trained hard... but it seemed that every time we were beginning to form up into a team, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing. And a wonderful method it can be of creating the illusion of progress while producing confusion, inefficiency and demoralization." Petronius Arbiter, approx. 2000 years ago.
An important question has been raised, here, and the OP has been dancing around it, a bit.
Since this seems to be a relatively common occurrence at that site (university lab) and NOT common elsewhere, there is likely to be some common factor unique to this site. One of the factors common to universities are massive on-line storage systems. Another possibility is that the instructor(s) have set up a makefile for use in the class and that makefile is faulty.
But, as awneil noted in message #8, nobody here can diagnose any of that WITHOUT A COPY OF THE BUILD OUTPUT. Not the error list, but the actual build output (as noted in message #9). You need not be defensive about all this. Instructors DO screw up (been there, done that). There may be something about PATH definitions for this class lab. Any number of things are possible. There ARE folks here who are much more knowledgable about such things than the Average Bear.
So, help us help you. A complete build output would go a long ways!
I would suggest everyone stop posting until the OP comes back and replies...if the OP ever does. No sense in repeating the obvious over and over.
East Coast Jim
