Split from: 1Mhz USART0 on ATtiny841 not working
7 posts / 0 new
* Split from the 4 year old thread https://www.avrfreaks.net/comment...
I am using attiny841 controller for my application. I am facing some strange problem in Uart communication in two controllers. i have same set of hardware and i am using same piece of firmware for both the controllers. Here is my uart initialization function.
void Uart initialization(unsigned int baudrate)
UBRR0H = (unsigned char) (baudrate>>8);
UBRR0L = (unsigned char) (baudrate);
UCSR0B |= (1<<RXCIE0);
UCSR0B |= ((1<<RXEN0) | (1<<TXEN0)); //enable receiver and transmitter pin
UCSR0C |= ((1<<UCSZ01) | (1<<UCSZ00)); // setting to 8bit mode
UCSR0B &=~ (1<<UCSZ02);
UCSR0C &=~((1<<UPM00) | (1<<UPM01));
UCSR0C |= (1<<USBS0);
UCSR0A |= (1<< U2X0);
For one controller, I am able to communicate correctly with  Uart initialization(7); where as for other, it is working with  Uart initialization(8); which means i need to set different baud rate register for 2 different controllers. If i set both to Uart initialization(7); or Uart initialization(8); then i get junk characters in the other.
Please suggest some solution to the issue.
prakash
How to properly post source code: https://www.avrfreaks.net/comment...
Sounds like you need to do the basic test to find exactly what speeds your two chips are actually running at.
Clearly, if they are running at significantly different speeds, then you are bound to need different setting to achieve the same baud rate!
EDIT
Note that this was already suggested in the 4-year-old thread you originally hijacked: https://www.avrfreaks.net/comment...
 I am using 8 MHz internal clock frequency for both attiny841 controller and two controllers are running at same clock speed. Even though it runs at same clock speed ,it is working at different baud rate. I need to make that controllers working at same baud rate.
prakash
did you not read #3 ?
I don't think the Uart initialization function has anything to do with the problem.  Show us all of the Uart code and we might be able to help you.
Total votes: 2
How many threads have been posted here asking about using the internal RC and serial comm problems......
Too many!
The simple answer is add a xtal and two caps and set the fuses to use same and your serial comms will work as expected, because Async comms require an accurate and stable clock source to be reliable and consistant!
Click Link: Get Free Stock: Retire early!
