sim808 firmware for gsm location
3 posts / 0 new
Hello I have sim808 module with firmware version 1418B01SIM808M32
I need the latest firmware for sim808 to use the command AT+CLBS=1,1
I tried to find firmware download at the simcomm site
http://simcomm2m.com/En/
and I even tried to contact them but no answer
any idea how to get this firmware ?
It's a SIMCOM product - so SIMCOM is the only place you're going to get it.
Have you tried your local distributor ?
yes sir I'm aware of that and I tried to contact them but no answer
some people tell me that chinese companies are always on vacation on february (SIMCOM is chinese)
and no I didn't try local distributor cause I don't think Egypt has local distributor for SIMCOM .
