Want to sell: WiFi-enabled in-circuit AVR ISP/PDI programmer
30 posts / 0 new
Hi folks,
I've mostly been a lurker here for a while and have been using all flavours of AVR for a good few years (way before Arduino was a thing) and made do with el-cheapo programmers, but I'd always wanted something a little more flexible.
So last year I decided to build an ISP/PDI programmer of my own design, called "wAVR". I think it's pretty neat, and now I'd like to make it available commercially.
Numerous significant features, when combined, set it apart from other AVR programmers:
  • Programs devices over your WiFi network using the open-source programmer "avrdude".
  • Programs devices over USB using "avrdude" or Atmel Studio though this is not the preferred mode of operation.
  • Supports target voltages between 1.65 volts and 5.5 volts.
  • Communicates with your target using RS232 on a UART or bit-banged I/O pin, making "printf" style debug very simple. wAVR will make the UART data available over WiFi using the telnet command on your host. Both RxD and TxD are supported at all the common baud rates.
  • wAVR's OLED display keeps you informed of both its status and various target parameters. It can also be configured to show the RS232 data received from the target.
  • The USB interface provides two CDC-compatible RS232 interfaces. One of those can be used for programming - supporting the same protocols as the WiFi interface. The other provides access to the same target UART interface mentioned above. This might be useful if, for whatever reason, WiFi is unavailable.
  • The USB interface can also be configured to emulate just enough of Atmel's STK600 programmer for Atmel Studio to be used to program your devices without the need to add avrdude as an external command. Though again, this is not the preferred mode of operation.
  • wAVR can provide your target with a configurable recovery clock signal should you need it to reset the fuses on Tiny or Mega devices.
  • All I/O signals between wAVR and your target are protected against electrostatic discharge, over-voltage and reverse voltage.
  • In most cases wAVR can be powered by your target. Only when your target voltage is below around 3.1 volts will wAVR need a separate power connection. wAVR will show a message on the OLED display if its power-supply voltage is too low for reliable operation.
  • Full galvanic isolation from your host PC and/or test/measurement tools when powered by the target.
  • Firmware updates for wAVR itself can be applied over WiFi. Note that wAVR doesn't phone home to implement this. It has a WiFi-capable boot loader which talks to a simple downloader program on the host.
The user guide is available online here: http://www.maverick-embedded.co.uk/downloads/wAVR-Manual.pdf
The price is UKP 85 plus postage (the board + packaging is very light so postage will be minimal). Contact me here by PM if you want to buy one. Numbers are limited at the moment but once I get a feel for demand I'll have a larger batch produced, or not as the case may be!
I'm also considering making one available for free to a lucky forum member. If I get enough replies (say 20 or more) to this post by mid-day GMT next Friday (Jan 26) then I'll draw the winner from the list of replies.
Comments/questions welcomed.
Steve
Maverick Embedded Technologies Ltd. Home of Maven and wAVR.
Maven: WiFi ARM Cortex-M Debugger/Programmer
wAVR: WiFi AVR ISP/PDI/uPDI Programmer
https://www.maverick-embedded.co...
I would be interested in this device as I have a beta project at a customer site that I would like to update the test firmware but the choices are limited to either a Studio install, or sending a stand alone programmer to the site via UPS/FedEx.  I would be even more interested - as would others if you posted a picture of it here.
Please include me in your contest drawing.
EDIT:
Picture:
There's a couple of pictures in the user guide, and also here: http://www.maverick-embedded.co.uk/wp-content/uploads/2018/01/IMG_2773-768x447.jpg
The board's dimensions are 80mm x 50mm.
Steve
Nice looking unit!
jgmdesign wrote:
Nice looking unit!
Thanks!
I hadn't considered your use-case. So you'd leave one connected to your device on the customer's premises in order to upload your firmware remotely? I guess with a suitable VPN and access to the customer's WiFi that would work pretty well. It might be a little slow due to packet RTT over the 'net but hopefully not so slow that avrdude times out.
Steve
Add me to your drawing!
TNX
Yes, this is a beta test and there have been a few changes that have been made.  Usually I send a dongle to do the update which is a pain in the butt.
Don't need a VPN as I have the customers public IP and we can do a firewall port forward to your gizmo.  Much faster than VPN.
Will see what happens IF I win your drawing.
Cheers,
JIm
I'll toss my hat into the ring...
OK, I'm in also. Thanks for the offer.
One day left to get your name in the hat!
I'll drop the target to 10 names to make it more likely the draw will go ahead.
Steve
OK, count me in.
I'm in...
David
Happy Trails,
Mike
JaxCoder.com
Nice project.
I'm really intrigued by the realization of seven identical level-converters whatever the direction.
Yep, they're all identical with independent direction control. Let's just say I have a few additional applications in mind. smiley
Steve
Wow, great product, count me in please.. Thank you for the offer.
Larry
Thanks!
So that makes 9 names in the hat. One more and the draw is good to go at 12 mid-day UTC tomorrow.
Steve
I am in. 1 in 10 is pretty OK odds. Better than 1 in 10 to the gazillion.
Please add me to the drawing.
I am also interested if the programmer will work with CVAVR, it supports STK600 as a programmer. There is a free evaluation version that could be used for test.
It all starts with a mental vision.
I hate to lessen everyone else's odds, but please also count me in .
It looks like a great device!
Count me in too.
think I might have a use for it in the near future. All depends on certian projects going ahead or not.
Entry list closed, with 13 names in the hat (in order of replies to this thread):
jgmdesign
ki0bk
joeymorin
valusoft
John_A_Brown
frog_jr
mike32217
Vladivolt
larryvc
ka7ehk
KitCarlson
DocJC
meslomp
I'll assign numbers 0-12 to each name, in the order above, and pick the winner based on today's closing price of the FTSE 100 index using the formula (FTSE100 * 100) % 13. Good luck chaps.
Steve
I have a question, my board is an Xmega64d4 based board using 3.3v. My power supply on the board is unable to supply the required current. It sounds like I can power the wAVR via usb, does this mean that the PDI and serial interface will use 5v logic levels or 3.3v logic levels detected by the VCC pin on the program header?
- Thanks
Michael Sangster
No. The target side of the level converters are always powered by the target so are safe to use for any TVcc between 1.65v and 5.5v. See the datasheet for TI's SN74LVC1T45. The target supplies the VCCB side of the transceivers.
Steve
FTSE100 closed at 7665.54 so the winner is: (7665.54 * 100) % 13 == 9 == ka7ehk.
Many thanks for all who took part. For anyone still interested, you can find wAVR on Tindie: https://www.tindie.com/products/11366/
Steve
Many thanks for all who took part. For anyone still interested...
Congratulations Jim. smiley
Steve, are there plans to implement UPDI for the new ATtinys?
From what I understand of UPDI the hardware should be up to the task as-is, so it's already on the ToDo list. As usual it boils down to setting aside some time to implement it.
Steve
Congratulations Jim and thanks Steve for your generosity.
Really appreciated. Thank you very much, Steve!
I've just released a firmware update which adds support for uPDI - the programming protocol used by the latest AtTiny devices. Existing users can grab it here: https://www.maverick-embedded.co...
To use uPDI support, you'll need to build avrdude from top-of-tree sources together with the patches here: https://savannah.nongnu.org/patc...
Steve
