Temperature Display
7 posts / 0 new
I am a software developer looking to learn more about developing embedded systems. I know software development pretty well but lack EE knowledge. I may need some advice on how to go through this small project.
First I would like a simple micro controller.
I was thinking about ordering this one
https://www.mouser.com/ProductDe...
I am not sure what I would need to order to install compiled code onto this micro controller or where to get the IDE or debugging tools?
Then I think I can figure out how to power it and order the sensor and interface with the micro controller and display it on a few 7 segment displays.
Shane
Maybe you should start by reading this (3rd sticky from the top) wink  https://www.avrfreaks.net/forum/p...
I'll move the thread.
No stock and Obsolete.
Many of us would suggest an Arduino... a few dollars delivered free from China. It includes the crystal, voltage regulator, printed circuit board, interface to your PC's usb and the Arduino world includes an IDE, zillions of proven code interfacing every sensor you could imagine.
But if you really have your heart set on an obsolete chip... be my guest. cheeky
Ross McKenzie, Melbourne Australia
As already noted, Arduino must be the obvious answer here:
https://www.arduino.cc/en/Guide/Introduction
If you really want to be a bit "closer to the metal", then get an Atmel Microchip XPlained board with the built-in debugger/programmer:
Xplained Pro: http://www.microchip.com/develop...
eg,
ATmega324PB Xplained Pro
Xplained Mini: http://www.microchip.com/develop...
ATmega328P Xplained Mini
Xplained Nano: http://www.microchip.com/develop...
ATtiny416 Xplained Nano
https://www.avrfreaks.net/comment...
These will be recognised by Atmel Studio, and it will give you a whole set of ready-to-go examples specifically for the connected board.
#ArduinoXPlained
EDIT
Typo
EDIT 2
To clarify, XPlained Pro, Mini, and Nano are the ones the built-in debugger/programmer - other (earlier) versions don't have it.
December 2020 Update:
There are now Microchip Curiosity Nano boards to add to the list of ones with built-in debugger/programmer:
EDIT 3
See this thread: https://www.avrfreaks.net/forum/xplained-mini-mega328pb for some examples of using  ATmega328PB & ATmega328P XPlained Mini boards ...
Also this thread: https://www.avrfreaks.net/forum/low-cost-debugger-xplained-kits for using the on-board debugger with an external target.
EDIT 4
So this is what you're getting:
                           PCB
                          :     Debug Adapter        Microcontroller    :
|      |       USB        :    |             |      |               |   :
|  PC  +<=====================>+USB      UART+<====>+UART           |   :
+------+                  :    |        Debug+<====>+Debug          |   :
Might be helpful to expand on that - what kind of "software"? what kind of environment(s) are you familiar with? what languages, etc ...
For some basic electronics tips, see: https://electronicsclub.info/
Companies like Sparkfun and Adafruit have loads of good tutorials, and produce lots of easy-to-use modules with sensors and stuff ...
Welcome to the Forum.
As noted above, an Arduino type, (there is a family of choices), would be a great starting point.
This will let you focus on interfacing the display and sensors, and you won't have to worry about the power connections, by-pass caps, Reset\ circuit, programming headers, power supply, etc.
Next:  As a general rule, start big.
That means don't start a project off with a small AVR Tiny type chip.
When you run out of pins or memory, your stuck.
Since an Arduino Uno with a Mega328P is only a couple of bucks, you can't possibly do better cost wise.
Getting a 7-segment LED display up and running is a great project, but not trivial is you are just starting out.
You might wish to consider getting a 2x16 Character LCD display also, as it is significantly easier to work with, and will get you up and running faster.
Then save the 7-Seg display as an additional project.
If you are just starting out you might also consider one of the Sensor Kits from Banggood Electronics.
They currently have a 45 sensor kit for $20 USD, (~ 50% off).
This will give you lots of sensors to tinker with at a give-away price.
+10
Cramming code into a severely-constrained chip is an art in itself:  this should be regarded as an advanced topic - not a starting point.
As   a "software developer", you should be aware of the saying, "premature optimisation is a root of all kinds of evil" ...
