uart transmission to Atmel Studio using the Power Debugger interface ?
7 posts / 0 new
Hi I'm using a SAM L21 Xplained Pro,
1) Is it possible to do uart[aka SERCOM] transmission from the Controller to Atmel Studio using the Power Debugger interface ?
2) Where can I find the schematics for the Power Debugger?
 Some thoughts inspired by hands-on experience on design and production of an SMU...
 As a HW guy you know, for sure, that measuring current in uA range becomes non-trivial. Usually you can't just put a shunt, it may require an OA and you need a very accurate standalone ADC. Then, this ADC must be very fast if you want to be able to synchronise your recorded current to CPU running at eg 16 MHz. So, I believe that $100 for a dual-channel UI meter integrated with a GUI IDE is not that much.
 Then, you don't measure energy consumption of DUT running in debug mode. Neither you need current curve to be aligned to every single CPU cycle, etc etc. Having been doing power optimisation for smartphones and watches for several years, I'd be glad to share my experience, but would like to keep the posts short. So, if you have questions, please feel free to ask. I can even get you in touch with real people who made an SMU that can synchronise recorded current to debug messages.
Qoitech AB, The Home of Otii Arc, an SMU for every developer
Check out Otii solution at www.qoitech.com
I wouldn't assume that everyone (or even many?) here are going to know what "SMU" stands for - or what it is ...
Hi Microzod,
cool handle!
You are not allone in thinking this is a usefull piece of equipment.
Analysis of clock by clock power consumption is a well known technique for reverse engineering and testing cryptography stuff.
There are also open source and open hardware designes in that direction.
I recall one which was specifically designed for that purpose, but can't remember it's name.
I think it was a kickstarter a few years back, but you should be able to find more info with a bit of searching.
Red Pitaya comes to mind, but that is not specifically designed for this goal, but there might be some software for it in that direction.
According to Yabusame this "expensive" thing you mention cost USD100 ?
This does not sound expensive to me for a very specialized piece of equipment with a resonably fast ADC & software.
https://www.kickstarter.com/projects/coflynn/chipwhisperer-lite-a-new-era-of-hardware-security
by
NewAE Technology
AES-256 Is Not Enough.™
https://newae.com/
https://github.com/newaetech/chipwhisperer
ChipWhisperer - the complete open-source toolchain for side-channel power analysis and glitching attacks http://chipwhisperer.com
 SMU, source and measure unit. Like http://uk.farnell.com/keysight-technologies/b2901a/precision-source-measure-unit/dp/2491328?ost=B2901A&scope=partnumberlookahead&exaMfpn=true&searchref=searchlookahead&ddkey=http%3Aen-GB%2FElement14_United_Kingdom%2Fw%2Fsearch
or https://www.digikey.com/products/en/test-and-measurement/equipment-specialty/618?k=&pkeyword=&v=1916&FV=ffe0026a&mnonly=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
combines functionality of power supply and IU meter.
