Byte array and bitwise operator for LCD
31 posts / 0 new
I am trying to get to read individual bits of a byte array. I am basically iterating through the byte array and want to tell whether each individual bit is 0 or 1.
My problem is, I am unable to differentiate between a 0 and 1 bit. The code is always reading each bit as a 1.
This is my code:
    const unsigned char bitmap[] = {
    0x00,0xFF,0xFF,0x00,0x00,0x00,
    0x00,0x00,0xFF,0xFF,0xFF,0xFF,
    0xFF,0xFF,0xFF,0xFF
    void drawBitmap(Framebuffer *fb) {
    uint8_t x = 1;
    for (int i = 0; i < sizeof(bitmap); ++i) {
    for (int p = 0; p < 8; ++p) {
    if ((bitmap[i] >> p) & 1) { // If bit
    fb->drawPixel(x, 1); // **RIGHT HERE** --> I AM ALWAYS GETTING THIS AS TRUE
    x++;
Note that there are some bytes that should be all zeroes (0x00). I am assuming by default these are bytes (8 bits), right? Any ideas why am I unable to differentiate between a 1 and a 0?
Note: Here's the whole code... I am trying to use this library: https://github.com/tibounise/SSD... with an atmega328P... This just doesn't make any sensse. Whenever I use "fb->drawPixel(x, 1);" on it's own it works fine, but on that particular function I always get a "1" (a pixel).
    #define F_CPU 14745600
    #include <stdint.h>
    #include <stdio.h>
    #include <math.h>
    #include <avr/interrupt.h>
    #include <avr/pgmspace.h>
    #include <inttypes.h>
    #include <util/delay.h>
    //#include "SSD1306.h"
    #include "Framebuffer.h"
    0x00,0x00,0x00,0x00,0x00,0x00,
    0xFF,0xFF,0xFF,0xFF
    uint8_t x = 1;
    int z = 0;
    fb->drawPixel(x,1);
    x++;
    int main(void) {
    //const uint8_t *bitmap;
    //bitmap = &bitmap1;
    Framebuffer fb;
    Framebuffer *FB;
    //Pointer to the class
    FB = &fb;
    //fb.drawPixel(5, 5);
    drawBitmap(FB);
    fb.show();
    //delay_ms(1000);
    return 0;
Any ideas?
Thanks in advance.
Your >> are a very expensive way to do this anyway. Perhaps consider a 1,2,4,8,16,32,64,128 mask array?
Care to give any example? ... Still I don't know why this is happening... But as long as there is a way to get the same result in another way, I would take it.
I am gobsmacked by how people like to make their lives difficult.
A human can't follow flush code.    At least this human can't.
    0x00, 0xFF, 0xFF, 0x00, 0x00, 0x00,
    0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF,
    uint8_t x = 1;
            x++;
Your code looks as if it should work.    Obviously it could be written about 10x more efficiently.   As suggested by clawson.
Most drawPixel() functions would draw at x, y e.g. with drawPixel(x, y, color)
Formatting code in the AS7 editor requires an arduous two keypresses.   Formatting code in the Arduino IDE requires a single ctrl-T
    uint8_t x = 1;
            x++;
But that's the thing... It's not working. I know it should work but it's not. The line
is not differentiating the 1's from the 0's. It's always a "1".
How did you establish?
Code seems true
Majid
I have no idea what you are trying to do.   But this is what your function does :
drawBitmap()
00000000
11111111
11111111
00000000
00000000
00000000
00000000
00000000
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
From this Arduino sketch:    Obviously you want 128 bits in one line.   Humans find blocks of 8 easier to read.
//void drawBitmap(Framebuffer *fb) {
void setup(void) {
    Serial.begin(9600);
    Serial.println("drawBitmap()");
    uint8_t x = 1;
                //                fb->drawPixel(x, 1); // **RIGHT HERE** --> I AM ALWAYS GETTING THIS AS TRUE
                Serial.print("1");
            else Serial.print("0");
            x++;
        Serial.println("");
void loop(void)
David/
lcruz007 wrote:
It's always a "1"
Since the code looks right, another possibility is that bitmap[] actually contains only FFs instead of the data that is supposed to be there. What build environment do you use? Some self-made Makefile perhaps?
Stefan Ernst
Try this code:
for( uint8_t Mask = 1; Mask; Mask <<= 1) {
    if (byte & Mask) {
        // Do something usefull.
Yes I am using my own makefile and I compile it with WinAVR (a bit outdated but it works like a charm)... What do you mean about the bitmap function?
Then I suspect that you do not export the .data section into the HEX file.
Stefan Ernst
What data section? What do you mean?
Here's the makefile I have to compile the libraries:
GS=-g -Os -Wall -mmcu=atmega328p
all: delay.o lcd.o uart.o I2C.o SSD1306.o Framebuffer.o
delay.o: delay.c
	avr-gcc ${GCCFLAGS} -o delay.o -c delay.c
lcd.o: lcd.c
	avr-gcc ${GCCFLAGS} -o lcd.o -c lcd.c
uart.o: uart.c
	avr-gcc ${GCCFLAGS} -o uart.o -c uart.c
I2C.o: I2C.cpp
	avr-gcc ${GCCFLAGS} -o I2C.o -c I2C.cpp
SSD1306.o: SSD1306.cpp
	avr-gcc ${GCCFLAGS} -o SSD1306.o -c SSD1306.cpp
Framebuffer.o: Framebuffer.cpp
	avr-gcc ${GCCFLAGS} -o Framebuffer.o -c Framebuffer.cpp
And the makefile I use to burn the code you saw on my other posts (the one not working) into the chip:
GCCFLAGS=-g -Os -Wall -mmcu=atmega328p
LINKFLAGS=-Wl,-u,vfprintf -lprintf_flt -Wl,-u,vfscanf -lscanf_flt
AVRDUDEFLAGS=-F -p atmega328p -c usbtiny
LINKOBJECTS=../libs/delay.o ../libs/lcd.o ../libs/uart.o ../libs/I2C.o ../libs/SSD1306.o ../libs/Framebuffer.o
all:	storage-upload
storage.hex:	storage.cpp
	make -C ../libs
	avr-gcc ${GCCFLAGS} ${LINKFLAGS} -o storage.o storage.cpp -lm ${LINKOBJECTS}
	avr-objcopy -j .text -O ihex storage.o storage.hex
storage.ass:	storage.hex
	avr-objdump -S -d storage.o > storage.ass
storage-upload:	storage.hex
	avrdude ${AVRDUDEFLAGS} -U flash:w:storage.hex:a
Life is a mystery.
God gave you the Arduino.
Atmel gave you AS4 and AS7.
You choose to create a bad Makefile.
In the days of AS4 there was a utility called Mfile that would create the Makefile for you.
Edit.   You can run the Arduino on Windoze, Linux, Mac, ...
You can probably run it on a a RaspberrryPi or Android phone.
Life is a mystery.
Hey David,
How is it a bad Makefile? It would be really helpful if you would point out the problem.
P.S I don't want to use Arudino's bootloader. Which is why I am using an ISP programmer
I am not suggesting that you use any particular operating system.    But it is always wise to snoop on a working system.    Then compare it with your own.
I happen to use Arduino hardware almost all of the time.   It is so convenient to have a single USB cable and standard headers to receive prototyping boards.
Yes,  I use the bootloader whenever possible.    Much more convenient than hooking up a USBASP.    But if I do choose to use USBASP or STK500 I would never use avrdude -F
This is a typical objcopy command from an AS7 project:
	@echo Building target: $@
	@echo Invoking: AVR/GNU Linker : 5.4.0
	$(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="I2C_t817.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mmcu=attiny817 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATtiny_DFP\1.2.118\gcc\dev\attiny817"
	@echo Finished building target: $@
	"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures  "I2C_t817.elf" "I2C_t817.hex"
	"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "I2C_t817.elf" "I2C_t817.eep" || exit 0
	"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "I2C_t817.elf" > "I2C_t817.lss"
	"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "I2C_t817.elf" "I2C_t817.srec"
	"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.exe" "I2C_t817.elf"
You could study a working Makefile from any IDE or working project.   Make sure that your homegrown Makefile follows a similar pattern.
It seems quite clear that your bitmap function works just fine.    Efficiency does not matter.
I suggest that you examine the LSS file to see the compiler has produced.   However objdump works on the ELF file.    The HEX file might have omitted some records due to wrong objcopy switches.
Ok I see... I am now suspecting there is a problem with AVR-DUDE or WINAVR, as I am also trying other operations with arrays and none of them work. For some reason it's not working with arrays.... Why would that be...?
The only thing left to try is.... well, I will try to compile this code with Atmel Studio and see if things improve.
No, it is definitely a problem of your Makefile, in particular this line:
As I already said, the root of your problems is that you do not export .data into the HEX file.
Stefan Ernst
So probably millions of people and millions of apps use the mentioned tools.  Yet none of them until you have uncovered a problem with arrays?  Sounds unlikely.
Create the smallest complete test program that demonstrates your symptoms, and post it in its entirety including build sequence, ISP sequence, what you expect, what you see, etc.
Ok so here is a small test program:
Keep in mind that I am using this library https://github.com/tibounise/SSD... and I am basically driving a LCD OLED display, 128x64. What I am trying to accomplish is turn specific pixels ON.
	fb->drawPixel(10, 1);
	fb->drawPixel(11, 1);
	fb->drawPixel(12, 1);
	fb->drawPixel(90, 1);
	fb->drawPixel(91, 1);
	fb->drawPixel(92, 1);
int main(void) {
	Framebuffer fb;
	Framebuffer *FB;
	FB = &fb;
	drawBitmap(FB);
	fb.show();
	return 0;
The above code works like a charm! Works as expected These are the results:
Now if I do this....
	uint8_t x = 1;
				fb->drawPixel(x,1);
			x++;
int main(void) {
	Framebuffer fb;
	Framebuffer *FB;
	FB = &fb;
	drawBitmap(FB);
	fb.show();
	return 0;
The above code does NOT work at all!! This is what I get:
So it's like the MCU is basically reading just a "1" for every item in the array. This part "if ((bitmap[i] >> p) & 1) {" is always TRUE according to the results... What I expect to see is some pixels OFF at the start, and then some of them will be ON. (depending on the array I initialize).
Both codes compile correctly though:
I see no reason why this is happening... I have even tried some other operations with arrays (just to try to get the correct results) and it's the same always. It's like "if ((bitmap[i] >> p) & 1)" meant "if there is an element in the array make it TRUE regardless of the value"... It's weird, I have no idea what could be wrong with it.
You sure about that? I have used the same makefile for years and I have never had a problem before... The only difference this time is that I am using a library for SSD1306 LCDs, and that it's written in a cpp file instead of a .C. But it should work the same I suppose, I have even tried avr-g++ instead and I get the same results... What do you recommend I do to fix this? I just posted more information of my results, maybe that helps?
I can't  believe you've used that makefile "For years" and have never been previously bitten by the lack of -j .data in the obcopy?? Most sensible makefiles these days seem to prefer -Rs anyway as that will include any "private" data/code sections you add automatically.
Why don't you update to a 2018 toolchain?
I see.... Yes I'd definitely do that. I am using the pocket AVR ISP programmer from Sparkfun. I guess that if a new toolchain is available and it supports my programmer I am happy... What would you recommend?
To establish if the issue is related to arrays try to use a fixed variable as test
something like this:
uint8_t temp = 0x0F;
uint8_t x = 1;
        if ((temp >> p) & 1) {
           fb->drawPixel(x,1);
        x++;
This shuold draw dashed line
Majid
uint8_t x = 1;
           fb->drawPixel(x,1);
        x++;
I have no problem with the temp variable, I just tried! When setting it to 0X00 all pixels are off, when I set it to something like 0XFF then I some pixels on. So the issue is definitely related to arrays! I have no clue why this is the case!! it doesn't make any sense... Why do I have problems only with arrays?? Does that has to do with my makefiles...? Why only arrays though...? This is so weird...
Ok so you were right!! The makefile was the problem all this time. Just like you said, the data part... I changed it to this:
avr-objcopy -j .text -j .data -O ihex storage.o storage.hex
Is it not recommended at all to do that? Well it's working for me now...
It's weird I hadn't had this problem in the past... And I have used the same makefile for a lot of my other projects before... Hmm.. Well it's good to know what the problem was.
Maybe it is because of "const"
Try
İnstead of
Majid
Not to hijack the thread, but where are your XTAL caps & all the bypass caps for your regulator and each of the various components (the modules prob have their own)?  Lack of those can cause working code to develop odd happenings.
Just to pint out that it was Stefan not me who identified missing .data
Not all code has a .data section.  It is used to store the initial values of any local static or global variables which are initialised to non-zero values.  If you don't have any of those, you won't miss .data.  Perhaps coincidentally none of your projects had any?  Or, if they did, they were tolerant of being initialised to 0xFF.
clawson wrote:
Just to pint out...
Had a good day eh? ;-)
I have just come back from the pub too.
