I am trying to get to read individual bits of a byte array. I am basically iterating through the byte array and want to tell whether each individual bit is 0 or 1.
My problem is, I am unable to differentiate between a 0 and 1 bit. The code is always reading each bit as a 1.
This is my code:
const unsigned char bitmap[] = { 0x00,0xFF,0xFF,0x00,0x00,0x00, 0x00,0x00,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF }; void drawBitmap(Framebuffer *fb) { uint8_t x = 1; for (int i = 0; i < sizeof(bitmap); ++i) { for (int p = 0; p < 8; ++p) { if ((bitmap[i] >> p) & 1) { // If bit fb->drawPixel(x, 1); // **RIGHT HERE** --> I AM ALWAYS GETTING THIS AS TRUE } x++; } } }
Note that there are some bytes that should be all zeroes (0x00). I am assuming by default these are bytes (8 bits), right? Any ideas why am I unable to differentiate between a 1 and a 0?
Note: Here's the whole code... I am trying to use this library: https://github.com/tibounise/SSD... with an atmega328P... This just doesn't make any sensse. Whenever I use "fb->drawPixel(x, 1);" on it's own it works fine, but on that particular function I always get a "1" (a pixel).
#define F_CPU 14745600 #include <stdint.h> #include <stdio.h> #include <math.h> #include <avr/io.h> #include <avr/interrupt.h> #include <avr/pgmspace.h> #include <inttypes.h> #include <util/delay.h> //#include "SSD1306.h" #include "Framebuffer.h" const unsigned char bitmap[] = { 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF }; void drawBitmap(Framebuffer *fb) { uint8_t x = 1; int z = 0; for (int i = 0; i < sizeof(bitmap); ++i) { for (int p = 0; p < 8; ++p) { if ((bitmap[i] >> p) & 1) { // If bit fb->drawPixel(x,1); } x++; } } } int main(void) { //const uint8_t *bitmap; //bitmap = &bitmap1; Framebuffer fb; Framebuffer *FB; //Pointer to the class FB = &fb; //fb.drawPixel(5, 5); drawBitmap(FB); fb.show(); //delay_ms(1000); return 0; }
Any ideas?
Thanks in advance.
