sbis PIND, 2
19 posts / 0 new
Hi Guys, I have been looking around for a simple translation from
this:
sbis   PIND, 2
or
sbic   PIND, 2
to C code.
I can't seem to find it.
Can anyone help?
Thanks in advance.
if ((PIND & (1<<PD2)) == 0)
You can figure out the other one.
Well, a particular C compiler may or may not ever generate a particular machine instruction.
What have you done so far?  What does
newbie123 wrote:
sbis PIND, 2
mean?
...so bit 2 of PINC, right?
How about
if (PINC & (1<<PINC2))
The first one will skip the next instruction if PIND bit 2 is set the next will skip if the bit is clear.
something like
if (PIND & (1<<2))    // Test if bit set
        your function
Too many cooks.......
And all implemented the sbic (since you are executing the code within braces on bit set)...smiley
David (aka frog_jr)
Look again!
Sorry Kartman, missed the == 0...blush
David (aka frog_jr)
Probably Mr. Johan would go with:
if (!(PIND & (1<<PD2)))
or how 'bout:  if !(PIND & (1<<PD2))
looking for the equalities (==0 or ==1 ) is probably more natural to think about initially...of course, then the error becomes using  = instead of ==
You sure about that?
It's all Greek...I mean C to me...
good call!
arrrg...sadly, C requires those extra parens
Surely it's just...
if (PIND.2) {
like this...
0000 0011     if (PORTD.2) {
000064 9992      SBIC 0x12,2
0000 0012         a = 1;
000065 e011      LDI  R17,LOW(1)
0000 0013     }
Just so OP isn't confused, you only get to use PIND.2 if you own Codevision. While a very nice feature (previously seen in other micros like 8051 compilers) it breaks the rules of C as anything beyond '.' in that syntax should name a struct member and they follow the usual C naming convention that requires symbol names to start with a non-digit. The best you can achieve in standard C is a syntax like:
if (Pind.b2) ...
...and the other variations.  Remember what I mentioned:
Your toolchain may or may not generate SBIC with the ==0 or the !(...) or even the .b2 variations.  [even applies to the "usual" (PINx&(1<<n)) variant]
OP's query sounds a bit ingenuous at first reading, but indeed if you haven't been around AVR for a goodly stretch there is some magic in all but the .n syntax in the compilers recognizing the (1<<n) bit mask and turning it into the bit number needed for SBIS/SBIC.
Just to confirm that for ".b2" syntax avr-gcc will generate the " tight" opcodes. (I've got a .h generator that kind of relies on this)
Again, OP asked for a C fragment, right?  And I stand behind my ongoing "it depends on the toolchain and the version and the phase of the moon and the recognizable/transformable construct" and similar.
But OP has disappeared and hasn't come back to expand on the context of why this might be important.  Or even useful, or pertinent.
Well, I had to try a couple experiments.  A recent CV version, and GCC from Studio 6.2.  I might well need to relent about "not all variants might generate SBIS/SBIC" as these modern versions picked up on the variations I threw at them.
But -- check out the GCC results for (PIND & 4) ...
                 	.CSEG
                 _main:
                 ;.FSTART _main
                 ;0000 0004 unsigned char scratch;
                 ;0000 0005
                 ;0000 0006     scratch = 0;
                 ;	scratch -> R17
00003f e010      	LDI  R17,LOW(0)
                 ;0000 0007
                 ;0000 0008    if (PIND & 4)    scratch++;
000040 994a      	SBIC 0x9,2
000041 5f1f      	SUBI R17,-1
                 ;0000 0009    if (PIND & (1<<2)) scratch++;
000042 994a      	SBIC 0x9,2
000043 5f1f      	SUBI R17,-1
                 ;0000 000A    if (PIND.2) scratch++;
000044 994a      	SBIC 0x9,2
000045 5f1f      	SUBI R17,-1
                 ;0000 000B
                 ;0000 000C    if ((PIND & (1<<2)) != 0) scratch++;
000046 994a      	SBIC 0x9,2
000047 5f1f      	SUBI R17,-1
                 ;0000 000D    if (!(PIND & (1<<2))) scratch++;
000048 9b4a      	SBIS 0x9,2
000049 5f1f      	SUBI R17,-1
                 ;0000 000E
                 ;0000 000F    PORTB = scratch;
00004a b915      	OUT  0x5,R17
                 ;0000 0010
                 ;0000 0011  while (1);
0000009e <main>:
	scratch = 0;
  9e:	89 b1       	in	r24, 0x09	; 9
  a0:	82 fb       	bst	r24, 2
  a2:	88 27       	eor	r24, r24
  a4:	80 f9       	bld	r24, 0
  a6:	4a 99       	sbic	0x09, 2	; 9
  a8:	8f 5f       	subi	r24, 0xFF	; 255
//	if (PIND.2) scratch++;
  aa:	4a 99       	sbic	0x09, 2	; 9
  ac:	8f 5f       	subi	r24, 0xFF	; 255
  ae:	4a 9b       	sbis	0x09, 2	; 9
  b0:	8f 5f       	subi	r24, 0xFF	; 255
	PORTB = scratch;
  b2:	85 b9       	out	0x05, r24	; 5
  b4:	ff cf       	rjmp	.-2      	; 0xb4 <main+0x16>
