Creating Security Zone - AT32UC3A3128s - FlashVault Feature
7 posts / 0 new
I am new to Micro controller programming.
I am working on a task in which we wanted to move our firmware into Security Zone.  I read about FlashVault feature in AVR in datasheet. It mentions that, Security Zone can be created and it is available in Revision 3 only.
But I am not able to find what is the revision of my microcontroller. Can someone help.
Part number I am using is  AT32UC3A3128s. I am not able to upload datasheet here..as it is 15 MB. Attaching other docs.
Amit
FlashVaultTM is a part of Secure State which is indicated in the most significant bit of the status register.
AVR32UC Technical Reference Manual
http://ww1.microchip.com/downloads/en/DeviceDoc/doc32002.pdf (1MB)
(page 8)
2.4 The Status Register
UC3A3/4 datasheet
http://ww1.microchip.com/downloads/en/DeviceDoc/doc32072.pdf (15MB)
(page 26)
4.4.2 Status Register Configuration
UC3C datasheet
http://ww1.microchip.com/downloads/en/DeviceDoc/doc32117.pdf (19MB)
(page 30)
Yeah. But it is available only in Revision 3 of Microcontroller. And my problem is I am not able to find what is the revision of my microcontroller AT32UC3A3128s. How do i do that ?
UC3A3/4 datasheet
(page 34)
4.6 Module Configuration
All AT32UC3A3 parts implement the CPU and Architecture Revision 2.
per
(page 6)
The “Processor and Architecture”-chapter of the device datasheet identifies the CPU revision used.
Edit: Link target
So why are you starting with AVR32?
See: https://www.avrfreaks.net/comment...
right on cue.
Thanks.! I missed it. Yes, this Microcontroller is Revision 2.
