I have an Arduino Uno with the standard 16MHz clock. I also have an SD Card Shield from Seeedstudio. The schematic for it is here:
https://raw.githubusercontent.co...
I have a 4GB SanDisk SD Card, formatted as FAT32, which I know on the existing ATMEGA328P and SD-Card shield, if I flash it with the Arduino boot loader, use the Arduino IDE and use their SD library example, it works.
I am now trying to do the same thing in Atmel Studio 7 (and then later in AVR-GCC) with FatFS, however, I am not having any luck. After doing what I think clawson instructed me to do, I can get it to compile, but it will not write to the SD-Card.
I am using the latest FatFS diskio.c, diskio.h, ff.c, ff.h, ffconf.h, integer.h, mmc_avr.h, mmc_avr_spi.c in my project.
I have altered the ffconf.h so to not use long file names, not use f_mkfs (not formatting in this demo), set my FF_CODE_PAGE to US, and disabled FF_FS_EXFAT. The rest I left as defaults.
/*---------------------------------------------------------------------------/ / FatFs - Configuration file /---------------------------------------------------------------------------*/ #define FFCONF_DEF 89352 /* Revision ID */ /*---------------------------------------------------------------------------/ / Function Configurations /---------------------------------------------------------------------------*/ #define FF_FS_READONLY 0 /* This option switches read-only configuration. (0:Read/Write or 1:Read-only) / Read-only configuration removes writing API functions, f_write(), f_sync(), / f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree() / and optional writing functions as well. */ #define FF_FS_MINIMIZE 0 /* This option defines minimization level to remove some basic API functions. / / 0: Basic functions are fully enabled. / 1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename() / are removed. / 2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1. / 3: f_lseek() function is removed in addition to 2. */ #define FF_USE_STRFUNC 0 /* This option switches string functions, f_gets(), f_putc(), f_puts() and f_printf(). / / 0: Disable string functions. / 1: Enable without LF-CRLF conversion. / 2: Enable with LF-CRLF conversion. */ #define FF_USE_FIND 0 /* This option switches filtered directory read functions, f_findfirst() and / f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */ #define FF_USE_MKFS 0 /* This option switches f_mkfs() function. (0:Disable or 1:Enable) */ #define FF_USE_FASTSEEK 0 /* This option switches fast seek function. (0:Disable or 1:Enable) */ #define FF_USE_EXPAND 0 /* This option switches f_expand function. (0:Disable or 1:Enable) */ #define FF_USE_CHMOD 1 /* This option switches attribute manipulation functions, f_chmod() and f_utime(). / (0:Disable or 1:Enable) Also FF_FS_READONLY needs to be 0 to enable this option. */ #define FF_USE_LABEL 0 /* This option switches volume label functions, f_getlabel() and f_setlabel(). / (0:Disable or 1:Enable) */ #define FF_USE_FORWARD 0 /* This option switches f_forward() function. (0:Disable or 1:Enable) */ /*---------------------------------------------------------------------------/ / Locale and Namespace Configurations /---------------------------------------------------------------------------*/ #define FF_CODE_PAGE 437 /* This option specifies the OEM code page to be used on the target system. / Incorrect code page setting can cause a file open failure. / / 437 - U.S. / 720 - Arabic / 737 - Greek / 771 - KBL / 775 - Baltic / 850 - Latin 1 / 852 - Latin 2 / 855 - Cyrillic / 857 - Turkish / 860 - Portuguese / 861 - Icelandic / 862 - Hebrew / 863 - Canadian French / 864 - Arabic / 865 - Nordic / 866 - Russian / 869 - Greek 2 / 932 - Japanese (DBCS) / 936 - Simplified Chinese (DBCS) / 949 - Korean (DBCS) / 950 - Traditional Chinese (DBCS) / 0 - Include all code pages above and configured by f_setcp() */ #define FF_USE_LFN 0 #define FF_MAX_LFN 255 /* The FF_USE_LFN switches the support for LFN (long file name). / / 0: Disable LFN. FF_MAX_LFN has no effect. / 1: Enable LFN with static working buffer on the BSS. Always NOT thread-safe. / 2: Enable LFN with dynamic working buffer on the STACK. / 3: Enable LFN with dynamic working buffer on the HEAP. / / To enable the LFN, ffunicode.c needs to be added to the project. The LFN function / requiers certain internal working buffer occupies (FF_MAX_LFN + 1) * 2 bytes and / additional (FF_MAX_LFN + 44) / 15 * 32 bytes when exFAT is enabled. / The FF_MAX_LFN defines size of the working buffer in UTF-16 code unit and it can / be in range of 12 to 255. It is recommended to be set 255 to fully support LFN / specification. / When use stack for the working buffer, take care on stack overflow. When use heap / memory for the working buffer, memory management functions, ff_memalloc() and / ff_memfree() in ffsystem.c, need to be added to the project. */ #define FF_LFN_UNICODE 0 /* This option switches the character encoding on the API when LFN is enabled. / / 0: ANSI/OEM in current CP (TCHAR = char) / 1: Unicode in UTF-16 (TCHAR = WCHAR) / 2: Unicode in UTF-8 (TCHAR = char) / / Also behavior of string I/O functions will be affected by this option. / When LFN is not enabled, this option has no effect. */ #define FF_LFN_BUF 255 #define FF_SFN_BUF 12 /* This set of options defines size of file name members in the FILINFO structure / which is used to read out directory items. These values should be suffcient for / the file names to read. The maximum possible length of the read file name depends / on character encoding. When LFN is not enabled, these options have no effect. */ #define FF_STRF_ENCODE 3 /* When FF_LFN_UNICODE >= 1 with LFN enabled, string I/O functions, f_gets(), / f_putc(), f_puts and f_printf() convert the character encoding in it. / This option selects assumption of character encoding ON THE FILE to be / read/written via those functions. / / 0: ANSI/OEM in current CP / 1: Unicode in UTF-16LE / 2: Unicode in UTF-16BE / 3: Unicode in UTF-8 */ #define FF_FS_RPATH 2 /* This option configures support for relative path. / / 0: Disable relative path and remove related functions. / 1: Enable relative path. f_chdir() and f_chdrive() are available. / 2: f_getcwd() function is available in addition to 1. */ /*---------------------------------------------------------------------------/ / Drive/Volume Configurations /---------------------------------------------------------------------------*/ #define FF_VOLUMES 2 /* Number of volumes (logical drives) to be used. (1-10) */ #define FF_STR_VOLUME_ID 0 #define FF_VOLUME_STRS "RAM","NAND","CF","SD","SD2","USB","USB2","USB3" /* FF_STR_VOLUME_ID switches string support for volume ID. / When FF_STR_VOLUME_ID is set to 1, also pre-defined strings can be used as drive / number in the path name. FF_VOLUME_STRS defines the drive ID strings for each / logical drives. Number of items must be equal to FF_VOLUMES. Valid characters for / the drive ID strings are: A-Z and 0-9. */ #define FF_MULTI_PARTITION 0 /* This option switches support for multiple volumes on the physical drive. / By default (0), each logical drive number is bound to the same physical drive / number and only an FAT volume found on the physical drive will be mounted. / When this function is enabled (1), each logical drive number can be bound to / arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk() / funciton will be available. */ #define FF_MIN_SS 512 #define FF_MAX_SS 512 /* This set of options configures the range of sector size to be supported. (512, / 1024, 2048 or 4096) Always set both 512 for most systems, generic memory card and / harddisk. But a larger value may be required for on-board flash memory and some / type of optical media. When FF_MAX_SS is larger than FF_MIN_SS, FatFs is configured / for variable sector size mode and disk_ioctl() function needs to implement / GET_SECTOR_SIZE command. */ #define FF_USE_TRIM 0 /* This option switches support for ATA-TRIM. (0:Disable or 1:Enable) / To enable Trim function, also CTRL_TRIM command should be implemented to the / disk_ioctl() function. */ #define FF_FS_NOFSINFO 0 /* If you need to know correct free space on the FAT32 volume, set bit 0 of this / option, and f_getfree() function at first time after volume mount will force / a full FAT scan. Bit 1 controls the use of last allocated cluster number. / / bit0=0: Use free cluster count in the FSINFO if available. / bit0=1: Do not trust free cluster count in the FSINFO. / bit1=0: Use last allocated cluster number in the FSINFO if available. / bit1=1: Do not trust last allocated cluster number in the FSINFO. */ /*---------------------------------------------------------------------------/ / System Configurations /---------------------------------------------------------------------------*/ #define FF_FS_TINY 1 /* This option switches tiny buffer configuration. (0:Normal or 1:Tiny) / At the tiny configuration, size of file object (FIL) is shrinked FF_MAX_SS bytes. / Instead of private sector buffer eliminated from the file object, common sector / buffer in the filesystem object (FATFS) is used for the file data transfer. */ #define FF_FS_EXFAT 0 /* This option switches support for exFAT filesystem. (0:Disable or 1:Enable) / When enable exFAT, also LFN needs to be enabled. / Note that enabling exFAT discards ANSI C (C89) compatibility. */ #define FF_FS_NORTC 0 #define FF_NORTC_MON 1 #define FF_NORTC_MDAY 1 #define FF_NORTC_YEAR 2017 /* The option FF_FS_NORTC switches timestamp functiton. If the system does not have / any RTC function or valid timestamp is not needed, set FF_FS_NORTC = 1 to disable / the timestamp function. All objects modified by FatFs will have a fixed timestamp / defined by FF_NORTC_MON, FF_NORTC_MDAY and FF_NORTC_YEAR in local time. / To enable timestamp function (FF_FS_NORTC = 0), get_fattime() function need to be / added to the project to read current time form real-time clock. FF_NORTC_MON, / FF_NORTC_MDAY and FF_NORTC_YEAR have no effect. / These options have no effect at read-only configuration (FF_FS_READONLY = 1). */ #define FF_FS_LOCK 0 /* The option FF_FS_LOCK switches file lock function to control duplicated file open / and illegal operation to open objects. This option must be 0 when FF_FS_READONLY / is 1. / / 0: Disable file lock function. To avoid volume corruption, application program / should avoid illegal open, remove and rename to the open objects. / >0: Enable file lock function. The value defines how many files/sub-directories / can be opened simultaneously under file lock control. Note that the file / lock control is independent of re-entrancy. */ #define FF_FS_REENTRANT 0 #define FF_FS_TIMEOUT 1000 #define FF_SYNC_t HANDLE /* The option FF_FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs / module itself. Note that regardless of this option, file access to different / volume is always re-entrant and volume control functions, f_mount(), f_mkfs() / and f_fdisk() function, are always not re-entrant. Only file/directory access / to the same volume is under control of this function. / / 0: Disable re-entrancy. FF_FS_TIMEOUT and FF_SYNC_t have no effect. / 1: Enable re-entrancy. Also user provided synchronization handlers, / ff_req_grant(), ff_rel_grant(), ff_del_syncobj() and ff_cre_syncobj() / function, must be added to the project. Samples are available in / option/syscall.c. / / The FF_FS_TIMEOUT defines timeout period in unit of time tick. / The FF_SYNC_t defines O/S dependent sync object type. e.g. HANDLE, ID, OS_EVENT*, / SemaphoreHandle_t and etc. A header file for O/S definitions needs to be / included somewhere in the scope of ff.h. */ /* #include <windows.h> // O/S definitions */ /*--- End of configuration options ---*/
I have altered the mmc_avr_spi.c to have hte Peripherals reflect the Arduino and SD Shield. The shield lacks CD and WP, so I hard coded them to 1 and 0 respectively. Under the power on function, I set the data directions and SPCR/SPSR bits. Under the power off function, I only disabled the SPCR bits. As it lacks any power on controller, I removed that from the example provided in the FatFS. As of the rest of the functions, I left as defaults.
/*-----------------------------------------------------------------------*/ /* MMCv3/SDv1/SDv2 Controls via AVR SPI module */ /*-----------------------------------------------------------------------*/ /* / Copyright (C) 2016, ChaN, all right reserved. / / * This software is a free software and there is NO WARRANTY. / * No restriction on use. You can use, modify and redistribute it for / any purpose as you like UNDER YOUR RESPONSIBILITY. / * Redistributions of source code must retain the above copyright notice. / /-------------------------------------------------------------------------*/ #include <avr/io.h> #include "diskio.h" #include "mmc_avr.h" // ATMEGA328P, 16MHz XTal // No WP. Card Detect is on CS. // PD4: SD_CS; // PB3: SD_DI; // PB4: SD_DO; // PB5: SD_CLK. /* Peripheral controls (Platform dependent) */ #define CS_LOW() PORTD &= ~(1 << 4) /* Set MMC_CS = low */ #define CS_HIGH() PORTD |= (1 << 4) /* Set MMC_CS = high */ #define MMC_CD 1 /* Test if card detected. yes:true, no:false, default:true */ #define MMC_WP 0 /* Test if write protected. yes:true, no:false, default:false */ #define FCLK_SLOW() SPCR = 0x52 /* Set SPI clock for initialization (100-400kHz), (F_CPU / 64) or (16MHz / 64) or (250kHz) */ #define FCLK_FAST() SPCR = 0x50 /* Set SPI clock for read/write (20MHz max), (F_CPU / 2) or (16MHz / 2) or (8MHz) */ /*-------------------------------------------------------------------------- Module Private Functions ---------------------------------------------------------------------------*/ /* Definitions for MMC/SDC command */ #define CMD0 (0) /* GO_IDLE_STATE */ #define CMD1 (1) /* SEND_OP_COND (MMC) */ #define ACMD41 (0x80+41) /* SEND_OP_COND (SDC) */ #define CMD8 (8) /* SEND_IF_COND */ #define CMD9 (9) /* SEND_CSD */ #define CMD10 (10) /* SEND_CID */ #define CMD12 (12) /* STOP_TRANSMISSION */ #define ACMD13 (0x80+13) /* SD_STATUS (SDC) */ #define CMD16 (16) /* SET_BLOCKLEN */ #define CMD17 (17) /* READ_SINGLE_BLOCK */ #define CMD18 (18) /* READ_MULTIPLE_BLOCK */ #define CMD23 (23) /* SET_BLOCK_COUNT (MMC) */ #define ACMD23 (0x80+23) /* SET_WR_BLK_ERASE_COUNT (SDC) */ #define CMD24 (24) /* WRITE_BLOCK */ #define CMD25 (25) /* WRITE_MULTIPLE_BLOCK */ #define CMD32 (32) /* ERASE_ER_BLK_START */ #define CMD33 (33) /* ERASE_ER_BLK_END */ #define CMD38 (38) /* ERASE */ #define CMD48 (48) /* READ_EXTR_SINGLE */ #define CMD49 (49) /* WRITE_EXTR_SINGLE */ #define CMD55 (55) /* APP_CMD */ #define CMD58 (58) /* READ_OCR */ static volatile DSTATUS Stat = STA_NOINIT; /* Disk status */ static volatile BYTE Timer1, Timer2; /* 100Hz decrement timer */ static BYTE CardType; /* Card type flags (b0:MMC, b1:SDv1, b2:SDv2, b3:Block addressing) */ /*-----------------------------------------------------------------------*/ /* Power Control (Platform dependent) */ /*-----------------------------------------------------------------------*/ /* When the target system does not support socket power control, there */ /* is nothing to do in these functions and chk_power always returns 1. */ static void power_on (void) { // Configure MOSI/SCK/CS as output pins and MISO to input DDRB |= (1 << 3); // Set PB3, MOSI to output DDRB &= ~ (1 << 4); // Set PB4, MISO to input DDRB |= (1 << 5); // Set PB5, SCK to output DDRB |= (1 << 4); // Set PD4, CS to output SPCR = 0x52; /* Enable SPI function in mode 0 */ SPSR = 0x01; /* SPI 2x mode */ } static void power_off (void) { SPCR = 0; /* Disable SPI function */ } /*-----------------------------------------------------------------------*/ /* Transmit/Receive data from/to MMC via SPI (Platform dependent) */ /*-----------------------------------------------------------------------*/ /* Exchange a byte */ static BYTE xchg_spi ( /* Returns received data */ BYTE dat /* Data to be sent */ ) { SPDR = dat; loop_until_bit_is_set(SPSR, SPIF); return SPDR; } /* Receive a data block fast */ static void rcvr_spi_multi ( BYTE *p, /* Data read buffer */ UINT cnt /* Size of data block */ ) { do { SPDR = 0xFF; loop_until_bit_is_set(SPSR, SPIF); *p++ = SPDR; SPDR = 0xFF; loop_until_bit_is_set(SPSR, SPIF); *p++ = SPDR; } while (cnt -= 2); } /* Send a data block fast */ static void xmit_spi_multi ( const BYTE *p, /* Data block to be sent */ UINT cnt /* Size of data block */ ) { do { SPDR = *p++; loop_until_bit_is_set(SPSR, SPIF); SPDR = *p++; loop_until_bit_is_set(SPSR, SPIF); } while (cnt -= 2); } /*-----------------------------------------------------------------------*/ /* Wait for card ready */ /*-----------------------------------------------------------------------*/ static int wait_ready ( /* 1:Ready, 0:Timeout */ UINT wt /* Timeout [ms] */ ) { BYTE d; Timer2 = wt / 10; do d = xchg_spi(0xFF); /* This loop takes a time. Insert rot_rdq() here for multitask envilonment. */ while (d != 0xFF && Timer2); return (d == 0xFF) ? 1 : 0; } /*-----------------------------------------------------------------------*/ /* Deselect the card and release SPI bus */ /*-----------------------------------------------------------------------*/ static void deselect (void) { CS_HIGH(); /* Set CS# high */ xchg_spi(0xFF); /* Dummy clock (force DO hi-z for multiple slave SPI) */ } /*-----------------------------------------------------------------------*/ /* Select the card and wait for ready */ /*-----------------------------------------------------------------------*/ static int select (void) /* 1:Successful, 0:Timeout */ { CS_LOW(); /* Set CS# low */ xchg_spi(0xFF); /* Dummy clock (force DO enabled) */ if (wait_ready(500)) return 1; /* Leading busy check: Wait for card ready */ deselect(); /* Timeout */ return 0; } /*-----------------------------------------------------------------------*/ /* Receive a data packet from MMC */ /*-----------------------------------------------------------------------*/ static int rcvr_datablock ( BYTE *buff, /* Data buffer to store received data */ UINT btr /* Byte count (must be multiple of 4) */ ) { BYTE token; Timer1 = 20; do { /* Wait for data packet in timeout of 200ms */ token = xchg_spi(0xFF); } while ((token == 0xFF) && Timer1); if (token != 0xFE) return 0; /* If not valid data token, retutn with error */ rcvr_spi_multi(buff, btr); /* Receive the data block into buffer */ xchg_spi(0xFF); /* Discard CRC */ xchg_spi(0xFF); return 1; /* Return with success */ } /*-----------------------------------------------------------------------*/ /* Send a data packet to MMC */ /*-----------------------------------------------------------------------*/ #if _USE_WRITE static int xmit_datablock ( const BYTE *buff, /* 512 byte data block to be transmitted */ BYTE token /* Data/Stop token */ ) { BYTE resp; if (!wait_ready(500)) return 0; /* Leading busy check: Wait for card ready to accept data block */ xchg_spi(token); /* Xmit data token */ if (token == 0xFD) return 1; /* Do not send data if token is StopTran */ xmit_spi_multi(buff, 512); /* Data */ xchg_spi(0xFF); xchg_spi(0xFF); /* Dummy CRC */ resp = xchg_spi(0xFF); /* Receive data resp */ return (resp & 0x1F) == 0x05 ? 1 : 0; /* Data was accepted or not */ /* Busy check is done at next transmission */ } #endif /*-----------------------------------------------------------------------*/ /* Send a command packet to MMC */ /*-----------------------------------------------------------------------*/ static BYTE send_cmd ( /* Returns R1 resp (bit7==1:Send failed) */ BYTE cmd, /* Command index */ DWORD arg /* Argument */ ) { BYTE n, res; if (cmd & 0x80) { /* ACMD<n> is the command sequense of CMD55-CMD<n> */ cmd &= 0x7F; res = send_cmd(CMD55, 0); if (res > 1) return res; } /* Select the card and wait for ready except to stop multiple block read */ if (cmd != CMD12) { deselect(); if (!select()) return 0xFF; } /* Send command packet */ xchg_spi(0x40 | cmd); /* Start + Command index */ xchg_spi((BYTE)(arg >> 24)); /* Argument[31..24] */ xchg_spi((BYTE)(arg >> 16)); /* Argument[23..16] */ xchg_spi((BYTE)(arg >> 8)); /* Argument[15..8] */ xchg_spi((BYTE)arg); /* Argument[7..0] */ n = 0x01; /* Dummy CRC + Stop */ if (cmd == CMD0) n = 0x95; /* Valid CRC for CMD0(0) + Stop */ if (cmd == CMD8) n = 0x87; /* Valid CRC for CMD8(0x1AA) Stop */ xchg_spi(n); /* Receive command response */ if (cmd == CMD12) xchg_spi(0xFF); /* Skip a stuff byte when stop reading */ n = 10; /* Wait for a valid response in timeout of 10 attempts */ do res = xchg_spi(0xFF); while ((res & 0x80) && --n); return res; /* Return with the response value */ } /*-------------------------------------------------------------------------- Public Functions ---------------------------------------------------------------------------*/ /*-----------------------------------------------------------------------*/ /* Initialize Disk Drive */ /*-----------------------------------------------------------------------*/ DSTATUS mmc_disk_initialize (void) { BYTE n, cmd, ty, ocr[4]; power_off(); /* Turn off the socket power to reset the card */ for (Timer1 = 10; Timer1; ) ; /* Wait for 100ms */ if (Stat & STA_NODISK) return Stat; /* No card in the socket? */ power_on(); /* Turn on the socket power */ FCLK_SLOW(); for (n = 10; n; n--) xchg_spi(0xFF); /* 80 dummy clocks */ ty = 0; if (send_cmd(CMD0, 0) == 1) { /* Put the card SPI mode */ Timer1 = 100; /* Initialization timeout of 1000 msec */ if (send_cmd(CMD8, 0x1AA) == 1) { /* Is the card SDv2? */ for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF); /* Get trailing return value of R7 resp */ if (ocr[2] == 0x01 && ocr[3] == 0xAA) { /* The card can work at vdd range of 2.7-3.6V */ while (Timer1 && send_cmd(ACMD41, 1UL << 30)); /* Wait for leaving idle state (ACMD41 with HCS bit) */ if (Timer1 && send_cmd(CMD58, 0) == 0) { /* Check CCS bit in the OCR */ for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF); ty = (ocr[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2; /* Check if the card is SDv2 */ } } } else { /* SDv1 or MMCv3 */ if (send_cmd(ACMD41, 0) <= 1) { ty = CT_SD1; cmd = ACMD41; /* SDv1 */ } else { ty = CT_MMC; cmd = CMD1; /* MMCv3 */ } while (Timer1 && send_cmd(cmd, 0)); /* Wait for leaving idle state */ if (!Timer1 || send_cmd(CMD16, 512) != 0) /* Set R/W block length to 512 */ ty = 0; } } CardType = ty; deselect(); if (ty) { /* Initialization succeded */ Stat &= ~STA_NOINIT; /* Clear STA_NOINIT */ FCLK_FAST(); } else { /* Initialization failed */ power_off(); } return Stat; } /*-----------------------------------------------------------------------*/ /* Get Disk Status */ /*-----------------------------------------------------------------------*/ DSTATUS mmc_disk_status (void) { return Stat; } /*-----------------------------------------------------------------------*/ /* Read Sector(s) */ /*-----------------------------------------------------------------------*/ DRESULT mmc_disk_read ( BYTE *buff, /* Pointer to the data buffer to store read data */ DWORD sector, /* Start sector number (LBA) */ UINT count /* Sector count (1..128) */ ) { BYTE cmd; if (!count) return RES_PARERR; if (Stat & STA_NOINIT) return RES_NOTRDY; if (!(CardType & CT_BLOCK)) sector *= 512; /* Convert to byte address if needed */ cmd = count > 1 ? CMD18 : CMD17; /* READ_MULTIPLE_BLOCK : READ_SINGLE_BLOCK */ if (send_cmd(cmd, sector) == 0) { do { if (!rcvr_datablock(buff, 512)) break; buff += 512; } while (--count); if (cmd == CMD18) send_cmd(CMD12, 0); /* STOP_TRANSMISSION */ } deselect(); return count ? RES_ERROR : RES_OK; } /*-----------------------------------------------------------------------*/ /* Write Sector(s) */ /*-----------------------------------------------------------------------*/ #if _USE_WRITE DRESULT mmc_disk_write ( const BYTE *buff, /* Pointer to the data to be written */ DWORD sector, /* Start sector number (LBA) */ UINT count /* Sector count (1..128) */ ) { if (!count) return RES_PARERR; if (Stat & STA_NOINIT) return RES_NOTRDY; if (Stat & STA_PROTECT) return RES_WRPRT; if (!(CardType & CT_BLOCK)) sector *= 512; /* Convert to byte address if needed */ if (count == 1) { /* Single block write */ if ((send_cmd(CMD24, sector) == 0) /* WRITE_BLOCK */ && xmit_datablock(buff, 0xFE)) { count = 0; } } else { /* Multiple block write */ if (CardType & CT_SDC) send_cmd(ACMD23, count); if (send_cmd(CMD25, sector) == 0) { /* WRITE_MULTIPLE_BLOCK */ do { if (!xmit_datablock(buff, 0xFC)) break; buff += 512; } while (--count); if (!xmit_datablock(0, 0xFD)) count = 1; /* STOP_TRAN token */ } } deselect(); return count ? RES_ERROR : RES_OK; } #endif /*-----------------------------------------------------------------------*/ /* Miscellaneous Functions */ /*-----------------------------------------------------------------------*/ #if _USE_IOCTL DRESULT mmc_disk_ioctl ( BYTE cmd, /* Control code */ void *buff /* Buffer to send/receive control data */ ) { DRESULT res; BYTE n, csd[16], *ptr = buff; DWORD *dp, st, ed, csize; #if _USE_ISDIO SDIO_CTRL *sdi; BYTE rc, *bp; UINT dc; #endif if (Stat & STA_NOINIT) return RES_NOTRDY; res = RES_ERROR; switch (cmd) { case CTRL_SYNC : /* Make sure that no pending write process. Do not remove this or written sector might not left updated. */ if (select()) res = RES_OK; deselect(); break; case GET_SECTOR_COUNT : /* Get number of sectors on the disk (DWORD) */ if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) { if ((csd[0] >> 6) == 1) { /* SDC ver 2.00 */ csize = csd[9] + ((WORD)csd[8] << 8) + ((DWORD)(csd[7] & 63) << 16) + 1; *(DWORD*)buff = csize << 10; } else { /* SDC ver 1.XX or MMC*/ n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2; csize = (csd[8] >> 6) + ((WORD)csd[7] << 2) + ((WORD)(csd[6] & 3) << 10) + 1; *(DWORD*)buff = csize << (n - 9); } res = RES_OK; } deselect(); break; case GET_BLOCK_SIZE : /* Get erase block size in unit of sector (DWORD) */ if (CardType & CT_SD2) { /* SDv2? */ if (send_cmd(ACMD13, 0) == 0) { /* Read SD status */ xchg_spi(0xFF); if (rcvr_datablock(csd, 16)) { /* Read partial block */ for (n = 64 - 16; n; n--) xchg_spi(0xFF); /* Purge trailing data */ *(DWORD*)buff = 16UL << (csd[10] >> 4); res = RES_OK; } } } else { /* SDv1 or MMCv3 */ if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) { /* Read CSD */ if (CardType & CT_SD1) { /* SDv1 */ *(DWORD*)buff = (((csd[10] & 63) << 1) + ((WORD)(csd[11] & 128) >> 7) + 1) << ((csd[13] >> 6) - 1); } else { /* MMCv3 */ *(DWORD*)buff = ((WORD)((csd[10] & 124) >> 2) + 1) * (((csd[11] & 3) << 3) + ((csd[11] & 224) >> 5) + 1); } res = RES_OK; } } deselect(); break; case CTRL_TRIM: /* Erase a block of sectors (used when _USE_TRIM in ffconf.h is 1) */ if (!(CardType & CT_SDC)) break; /* Check if the card is SDC */ if (mmc_disk_ioctl(MMC_GET_CSD, csd)) break; /* Get CSD */ if (!(csd[0] >> 6) && !(csd[10] & 0x40)) break; /* Check if sector erase can be applied to the card */ dp = buff; st = dp[0]; ed = dp[1]; /* Load sector block */ if (!(CardType & CT_BLOCK)) { st *= 512; ed *= 512; } if (send_cmd(CMD32, st) == 0 && send_cmd(CMD33, ed) == 0 && send_cmd(CMD38, 0) == 0 && wait_ready(30000)) { /* Erase sector block */ res = RES_OK; /* FatFs does not check result of this command */ } break; /* Following commands are never used by FatFs module */ case MMC_GET_TYPE : /* Get card type flags (1 byte) */ *ptr = CardType; res = RES_OK; break; case MMC_GET_CSD : /* Receive CSD as a data block (16 bytes) */ if (send_cmd(CMD9, 0) == 0 && rcvr_datablock(ptr, 16)) { /* READ_CSD */ res = RES_OK; } deselect(); break; case MMC_GET_CID : /* Receive CID as a data block (16 bytes) */ if (send_cmd(CMD10, 0) == 0 && rcvr_datablock(ptr, 16)) { /* READ_CID */ res = RES_OK; } deselect(); break; case MMC_GET_OCR : /* Receive OCR as an R3 resp (4 bytes) */ if (send_cmd(CMD58, 0) == 0) { /* READ_OCR */ for (n = 4; n; n--) *ptr++ = xchg_spi(0xFF); res = RES_OK; } deselect(); break; case MMC_GET_SDSTAT : /* Receive SD statsu as a data block (64 bytes) */ if (send_cmd(ACMD13, 0) == 0) { /* SD_STATUS */ xchg_spi(0xFF); if (rcvr_datablock(ptr, 64)) res = RES_OK; } deselect(); break; case CTRL_POWER_OFF : /* Power off */ power_off(); Stat |= STA_NOINIT; res = RES_OK; break; #if _USE_ISDIO case ISDIO_READ: sdi = buff; if (send_cmd(CMD48, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) { for (Timer1 = 100; (rc = xchg_spi(0xFF)) == 0xFF && Timer1; ) ; if (rc == 0xFE) { for (bp = sdi->data, dc = sdi->ndata; dc; dc--) *bp++ = xchg_spi(0xFF); for (dc = 514 - sdi->ndata; dc; dc--) xchg_spi(0xFF); res = RES_OK; } } deselect(); break; case ISDIO_WRITE: sdi = buff; if (send_cmd(CMD49, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) { xchg_spi(0xFF); xchg_spi(0xFE); for (bp = sdi->data, dc = sdi->ndata; dc; dc--) xchg_spi(*bp++); for (dc = 514 - sdi->ndata; dc; dc--) xchg_spi(0xFF); if ((xchg_spi(0xFF) & 0x1F) == 0x05) res = RES_OK; } deselect(); break; case ISDIO_MRITE: sdi = buff; if (send_cmd(CMD49, 0x84000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | sdi->ndata >> 8) == 0) { xchg_spi(0xFF); xchg_spi(0xFE); xchg_spi(sdi->ndata); for (dc = 513; dc; dc--) xchg_spi(0xFF); if ((xchg_spi(0xFF) & 0x1F) == 0x05) res = RES_OK; } deselect(); break; #endif default: res = RES_PARERR; } return res; } #endif /*-----------------------------------------------------------------------*/ /* Device Timer Interrupt Procedure */ /*-----------------------------------------------------------------------*/ /* This function must be called in period of 10ms */ void mmc_disk_timerproc (void) { BYTE n, s; n = Timer1; /* 100Hz decrement timer */ if (n) Timer1 = --n; n = Timer2; if (n) Timer2 = --n; s = Stat; if (MMC_WP) { /* Write protected */ s |= STA_PROTECT; } else { /* Write enabled */ s &= ~STA_PROTECT; } if (MMC_CD) { /* Card inserted */ s &= ~STA_NODISK; } else { /* Socket empty */ s |= (STA_NODISK | STA_NOINIT); } Stat = s; /* Update MMC status */ }
Lastly, this is my main.c
// ATMEGA328P, 16MHz XTal // No WP. Card Detect is on CS. // PD4: SD_CS; // PB3: SD_DI; // PB4: SD_DO; // PB5: SD_CLK. // External 16MHz crystal #define F_CPU 16000000UL #include <avr/io.h> // Device specific declarations #include "diskio.h" // Declarations of device I/O functions #include "ff.h" // Declarations of FatFs API FATFS FatFs; // FatFs work area needed for each volume FIL Fil; // File object needed for each open file DWORD get_fattime(void) { return ((DWORD)(2017-1980)<<25) | ((DWORD) 1 << 21) | ((DWORD) 1 << 16) | ((DWORD) 0 << 11) | ((DWORD) 0 << 5) | ((DWORD) 0 << 1); } int main(void) { UINT bw; // Give a work area to the default drive f_mount(&FatFs, "", 0); if (f_open(&Fil, "newfile.txt", FA_WRITE | FA_CREATE_ALWAYS) == FR_OK) { // Create a file // Write data to the file f_write(&Fil, "It works!\r\n", 11, &bw); // Close the file f_close(&Fil); } // Replace with your application code while (1) { } }
I hard set the get_fattime, as in this case, I do not have an RTC on this circuit.
It will not write to the SD-Card or even create the file. What am I doing incorrectly?
