Driving xmega with 26MHz source to XTAL1
8 posts / 0 new
I'm using an XMEGA128A3U.  Had a lot of trouble finding out if I can drive the thing with an external clock source at 26MHz (note: not external crystal, which goes up to 16MHz).  Is this possible?  There isn't even an option for it in Atmel Start.
Ben
I KNEW I’d read it somewhere! Thanks for confirming. How do you get round this not being in Atmel Start as an option?
Easy answer would be to not bother with Atmel Start/ASF ;-)
+1.  Atmel START (ASF4) has lots of support for the various SAM families, significantly less support for XMEGA families, and, with a few exceptions, no support for for the MEGA/TINY families.
If you want to use ASF with an XMEGA use ASF3 (the ASF Wizard built into Atmel Studio).  Unless you have a compelling reason to use ASF, I would follow Cliff's "easy answer."
Greg Muth
Portland, OR, US
    I do it the old fashioned way:
- read datasheet about the peripheral in question from the beginning to end. It is not much.
- take each register / bit and if I am not happy with the default values, I write to it accordingly. Atmel lists nicely all registers related to a particular peripheral at the end of that peripheral description.
    Job done. This way:
- I am familiar with the peripheral
- I am aware what it can do and what it cannot
- I take the most of it
- I do not need to ask anybody for help
- I do not ask in forums about it and I do not need to wait for answers
- Most of the time I no need to debug that code
- Nothing keeps me from going forward.
It is that simple.
Total votes: 2
I started to make a comment on that, but decided that it would be inefficacious...
David (aka frog_jr)
Yeah, given up with ASF. Gone back to a bare setup and writing my own libraries. It’s somewhat easier even if I don’t seem to be able to properly simulate external clock detection/selection in Studio 7
