Suggested production programmer for AVRDUDE/ATmega328(p,b)?
17 posts / 0 new
We've been doing production programming for years with the MKII and custom scripts with AVRDUDE (mostly to burn a serial number automatically).  It worked great for a long time, but these MKii's are starting to flake out, and are no longer being manufactured.  I'm uncertain if the clones will work reliably.
What's the go-to programmer these days that's reliable, and plays well with avrdude?  We'll be using atmega328, sometimes the -p and/or -pb variants.  6 pin ISP header on-board for in-system programming, 3.3V. Cost really isn't an issue.  Probably windows XP if that matters, but we can get a new PC for Win10 if it helps.  Thanks!
Win10 + Atmel ICE
Ditch the MKIIs and Windows XP!
ki0bk wrote:
Win10 + Atmel ICE
+1
Excellent, thanks, already on order.  I wasn't sure if avrdude worked well with Win10 but I'm glad it does.
For production I use a number of Kanda keyfob units.
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
jrs454 wrote:
We've been doing production programming...
Brian Fairchild wrote:
For production...
blush​Don't know how I missed "production" when it was in so many places including the thread title.  I'll blame it on not having had enough coffee.
Now I do have some reservations about the recommendation of the Atmel-ICE for use in production but only in regard with the delicate connectors and jumpers (squibs) that it comes with.  I have seen adapters that can make the Atmel-ICE more rugged and those may be necessary for your production use case.  The Atmel-ICE does work very well for the programming task.
EDIT: Link to an adapter https://atoomnet.net/atmel-ice-header-adapter/ Eagle schematic and board layout is there.  The designer may have some bare boards left and will ship worldwide.
Atmel ICE with header adapter
Can answer that by trying the clone, one of the function-likes (LUFA AVRISP2), or revert to STK500.
ATmega328PB is one of the AVR that can be programmed by Microchip.
Once the bootloader or monitor or application is programmed then can burn the serial number via those.
This method will be unwieldy if there's a significant number of combinations (multiple bootloaders, multiple monitors, multiple applications) as each is on its own reel.
https://www.waveshare.com/wiki/USB_AVRISP_XPII
http://www.fourwalledcubicle.com/AVRISP.php
https://www.pololu.com/product/3170
http://www.microchipdirect.com/AVR-SAM-Programming.html
AvrDUDE also runs wel  on Linux.
Linux prevents a lot of licence and update headaches.
Small linux boxes also support nice small LCD's.
For example Combination of the Hardkernel Odroid C3 with a 3.2" LCD (Picture below) costs < USD100
It also has extra I/O pins which can be used in a shell script to start avrdude with a foot pedal  proximity switch or whatever.
http://www.hardkernel.com/main/p...
The above is just an example.
Similar combinations are possible with Raspaberry Pi, Beaglebone or other small Linux Boxes.
Hardkernal also has battery packs, which would turn it in a stand alone mobile unit.
Paul van der Hoeven.
http://www.hoevendesign.com
Thanks!  The 6-pin connector actually goes to pogo-pins on a fixture that program the main board, so there's no worry about robustness of the ICE.
Also a nice solution.  I think that using Windows 10 and disconnecting it from the internet entirely will probably be fine.  Then there's no update problems.
The last time I had anything to do with Widows it was on the PC connected to a big CNC router.
It was running a 6 hour job and you had to press cancel every half hour or windows would reboot the thing and ruin the CNC job.
The Widows 10 rant is the longest running thread here on AVR freaks I believe:
https://www.avrfreaks.net/forum/a...
Alan's simple Atmel-ICE target pitch adaptor :
https://www.avrfreaks.net/forum/atmelice-rats#comment-2026396
who also has a ISP & PDI programmer :
https://www.avrfreaks.net/forum/wts-standalone-pdiisp-auto-programmers
One could create a pogo pin adaptor for production such that don't have to replace the 23USD Atmel-ICE target cable as it wears out (IDC flexes)
The Tag-Connect pogo has stainless steel pins (IDC has strain relief)
If can move to edge connectors then Tag-Connect Edge-ConnectTM is an alternate to automated pogo.
http://new.microchipdirect.com/product/search/all/ATATMEL-ICE-CABLE
http://www.tag-connect.com/what-is-tag-connect
http://www.tag-connect.com/EdgeConnectIntro
Just remembered:
AvrDUDE can bitbang on almost any Linux computer with readily accessible I/O pins.
Just like the very old LPT programmers.
But those pins would need extra protection, maybe a level converter.
Bit of a DIY mess, doe not seem "professional".
gchapman wrote:
Alan's simple Atmel-ICE target pitch adaptor : https://www.avrfreaks.net/forum/a... who also has a ISP & PDI programmer : https://www.avrfreaks.net/forum/w...
If the target is powered during programming, I also would highly recommend Alan's Autoprogrammer.yes
David (aka frog_jr)
Absolutely!  This tool can also be configured to automatically program 'variants' of a device (i.e. m324p, m324pa, etc.)
Tom Pappano
Tulsa, Oklahoma
Autoprogrammer is pretty cool but I don't think it will support our scripts (serial number burning and recording with software version, etc.)
ATMEL-ICE is working well though.
Tag-Connect Edge-ConnectTM appears to be in-stock though may have a short backlog (parts: EC-06, EC-10, EC-14)
An alternative are the Atmel-ICE specific ISP cables (parts: TC2030-ICESPI, TC2030-ICESPI-NL)
Tag-Connect
What's New!
http://www.tag-connect.com/new
