Atmel Start bug generating code for driver TC:LITE:Timer with 8 bits counter mode
13 posts / 0 new
Atmel start write in generate code 0x02 for TC_CTRLA_MODE_Pos (as you can see below) although you select 8 bits counter mode in driver TC:LITE:Timer, as you can see in the photo
code extract ...
int8_t TIMER_0_init()
    hri_tc_wait_for_sync(TC0);
    if (hri_tc_get_CTRLA_ENABLE_bit(TC0)) {
        return ERR_DENIED;
    hri_tc_write_CTRLA_reg(TC0,
                           0 << TC_CTRLA_PRESCSYNC_Pos       /* Prescaler and Counter Synchronization: 0 */
                               | 0 << TC_CTRLA_RUNSTDBY_Pos  /* Run in Standby: disabled */
                               | 0 << TC_CTRLA_PRESCALER_Pos /* Setting: 0 */
                               | 0 << TC_CTRLA_WAVEGEN_Pos   /* Waveform Generation Operation: 0 */
                               | 0x2 << TC_CTRLA_MODE_Pos);  /* Operating Mode: 0x2 */
    // hri_tc_write_CTRLB_reg(TC0,0 << TC_CTRLBSET_CMD_Pos /* Command: 0 */
    //         | 0 << TC_CTRLBSET_ONESHOT_Pos /* One-Shot: disabled */
thanks
regards
Is this a new Atmel Start project or did you change the setting and forget to generate the new code?  What chip are you using?
first of all, thank you por your answer
chip: atsamd20g16.
It also happens with new projects.
regards
Latest datasheet for the ATSAMD20 http://ww1.microchip.com/downloa...
See page 490;
Bits 3:2 – MODE[1:0] Timer Counter Mode
These bits select the counter mode.
These bits are not synchronized.
Value Name Description
0x0 COUNT16 Counter in 16-bit mode
0x1 COUNT8 Counter in 8-bit mode
0x2 COUNT32 Counter in 32-bit mode
0x3 - Reserved
The code
selects "COUNT32 Counter in 32-bit mode" by setting Bit 1 of the Timer Counter Mode Bits
Edit: OP is correct there is a bug and should be reported as such.
OP note my edit above.  Missing a bit in the bucket.
Testing indicates that the COMPONENT SETTINGS Mode: drop down menu selections are ignored as the same code is produced for all of the counter modes ( 8, 16 and 32 Bit).
Hi. Please create a microchip support ticket on this...
:: Morten
I am opening one now to address what I found in post #6 above.  This will cover the OP bug report as well.
Edit: Support case number is 00271476
You are right, I forget to say that bug happens for all mode but 32 bits counter (0x02 mode) although I'm interested in 8 bits counter mode.
How can I follow bug resolution, I've tried to find in microchip website for support case number 00271476
Thank you for your time!
regards
Support cases are associated to the customer account on Microchip Support, so it looks like I am the only one that can track it.
I filed the case with an Urgency of Critical and it is already marked as In Progress.  I will post updates here as I receive them to keep you in the loop.
You are welcome, thanks for finding the bug!
Received two responses from support;
Thanks for contacting Microchip Technical Support Team.
The Atmel Start driver part should take MODE as a input from front end. But current driver is not supported for this.
This is confirmed as a bug and we understand the priority of this issue. We have reported this issue to our internal team.
This will be fixed in the future.
Thanks for reporting this issue to us.
Proposed Resolution
Issue has been identified in Lite TC driver. We have reported this issue to our internal team. This will be fixed in the future.
Thanks for reporting this issue.
Thank you Larry,
Basically, Microchip has said: May be in the future! as my wife said ;-)
I hope Microchip has in mind a little few weeks for "Future".
regards
p.s. Could it be because it's a Atmel product?
Latest news from support;
***** AUTOMATED MESSAGE - DO NOT RESPOND *****
Hello Larry,
There has been no communication on your case 00271476 for more than 14 days after we proposed a resolution, and the case has therefore been closed. Please open a new support case if you have further request about our products.
