CTC timer question
6 posts / 0 new
I am using the ATMEGA328P datasheet for my question.  I understand that the CTC timer will reset the timer on a match, but it seems from the datasheet this only happens on value OCRA.  (Table 19-9 mode 2) If I were to also use OCRB could I also trigger that interrupt, Timer/Counter0 Compare Match B, as long as the match value for OCRB was less than OCRA.  I am thinking that the B timer would trigger at the lower value but the timer keep on going until it "matched" the higher value and then reset.  I would suppose this is why you can't have 2 CTC values on the same timer because both can't be used to reset.  I assume also that were I to use the CTC timer but had a value of OCRB > OCRA then it would simply never be reached and nothing would happen.
I hope this doesn't seem a lazy question.  I know I could simply try it, but the responses I get here are often quite enlightening and teach me more than I would simply learn by roughing out my own ideas.  Thanks in advance for the help.
Andrew
Sounds like you understand it correctly!
Great.  Thanks.  It must be a first.  I am getting better at all this!  :)
Andrew
I have also used Timer1 in one of the PWM modes where ICR1 is used for TOP and both OCR1A and OCR1B are generating interrupts...
And I was not doing any sort of PWM.
David (aka frog_jr)
As David hinted at, have you looked at mode 12 CTC with ICR1 as TOP?
Interesting.  Thanks guys.  I always learn something.
Andrew
