programming AtSamD10D13 by SAM D10 Xplained Mini ?
3 posts / 0 new
hi ! guys, i can using the integrate debugging in SAM D10 Xplained Mini to debug or programming my AtSamD10D13 ? i can't find document or tutorial about this issue ever.
thanks for hearing
luuhuong. Regards
Might be possible. You need the swdclk and swdio pins from edbg to your d10. There is a swd connector on board so check the schematic for jumper to remove swdio from onboard d10.
very for yours help, i will to try
luuhuong. Regards
